LetterBeacon
Posted: Tue Jun 09, 2009 2:22 pm Post subject:
ADSR Pots Subject description: To log or not to log.... |
I can't get 1Meg log taper pots in the size that I need for my knobs (the Futurlec ones I use have a slightly shorter shaft length to the ones from Rapid), so I need to make a decision. Do I:
a) Use 1Meg linear pots
b) Use 1Meg linear pots and use a resistor to turn it into a reverse log pot
Which one will give me the best amount of control (although neither will be perfect)?
Thanks! |
yusynth
Posted: Wed Jun 10, 2009 2:36 am Post subject:
Re: ADSR Pots Subject description: To log or not to log.... |
LetterBeacon wrote: | I can't get 1Meg log taper pots in the size that I need for my knobs (the Futurlec ones I use have a slightly shorter shaft length to the ones from Rapid), so I need to make a decision. Do I:
Thanks! |
Why not using 1M log pots ? These are easily sourceable at other places than futurlec I think.
a) 1M lin is a very bad solution
b) you are not getting a reverse log curve as you write, but a log curve, which is fortunate because that is what you are actually looking for. By the way, you'll need a pot with a value bigger than 1M lin because the use of a taper resistor reduces the overal resistor : Rt = (Rpot + Rtapper)/(Rpot x Rtapper) _________________ Yves |
scriptstyle
Posted: Wed Jun 10, 2009 7:54 am Post subject:
a 5m lin pot and a 1.25m tapper should do the trick... |
LetterBeacon
Posted: Wed Jun 10, 2009 11:41 am Post subject:
yusynth wrote: | Why not using 1M log pots ? These are easily sourceable at other places than futurlec I think. |
The pots from Futurlec seem to have a slightly smaller shaft than the ones I can get from elsewhere. Unfortunately the pots that I have designed the panel around require this slightly smaller shaft.
Quote: | b) you are not getting a reverse log curve as you write, but a log curve, which is fortunate because that is what you are actually looking for. By the way, you'll need a pot with a value bigger than 1M lin because the use of a taper resistor reduces the overal resistor : Rt = (Rpot + Rtapper)/(Rpot x Rtapper) |
Thanks for that. I think I'm going to have to do some more reading! |
LetterBeacon
Posted: Wed Jun 10, 2009 2:12 pm Post subject:
You'll have to bear with me here because I'm sure this is basic stuff, but I'm a bit confused!
In this article, near the bottom, it says the following:
The Secret Life Of Pots wrote: | In the two terminal connection, the resistance through the pot is what we're interested in, not the voltage divider ratio.
It turns out that the tapering trick works here, but only partially. If we want to make a reverse log tapering pot, we're in! However, there is no way to get a simulation of a log taper pot in the two terminal connection. For that we have to buy real audio taper pots. |
On the ADSR module, all three log taper pots are two terminal connections. So how can I make a log taper pot if the pots in the circuit are two terminal connections?
Thanks for your patience! |
yusynth
Posted: Thu Jun 11, 2009 9:53 am Post subject:
LetterBeacon wrote: | yusynth wrote: | Why not using 1M log pots ? These are easily sourceable at other places than futurlec I think. |
The pots from Futurlec seem to have a slightly smaller shaft than the ones I can get from elsewhere. Unfortunately the pots that I have designed the panel around require this slightly smaller shaft.! |
Have thought of sawing them ? _________________ Yves |
yusynth
Posted: Thu Jun 11, 2009 10:01 am Post subject:
LetterBeacon wrote: | You'll have to bear with me here because I'm sure this is basic stuff, but I'm a bit confused!
OK then, take a lin pot and a resitor taper, and check what you eventually obtain ... Nothing replaces experimentation, and let us know what you get.
Quote: | On the ADSR module, all three log taper pots are two terminal connections. So how can I make a log taper pot if the pots in the circuit are two terminal connections? |
the resistor is to be connected in parallel with the two connectors.
Quote: | Thanks for your patience! |
No problem, you're welcome. _________________ Yves |
