ordering parts in the EU?
Page 1 of 1 [6 Posts]
wishniak
PostPosted: Fri Jun 12, 2009 6:25 am    Post subject: ordering parts in the EU?
Subject description: (knobs / switches / potis / switches / etc)
i just ordered some module kits and need to order parts to complete them. wondering where most people order their bits and bobs from.
i used to go to conrad (here in berlin), but am tired of the grumpy electromeisters and realizing some things get to be expensive there.
any other good sources for ordering components like knobs/switchs/pots/etc? thanks in advance.
Audio files: 211
G2 patch files: 92
PostPosted: Fri Jun 12, 2009 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe a long shot: I order from swedish online stores - it might currently be a good deal for you because of the poor value of the swedish crown (causing me grief with my current order for a modular system from Curetronic), even though you'll get to pay german VAT on your orders. Looking at Electrokit's web page it seems like they ship abroad:
http://www.electrokit.se/
..though it might be a bit of an issue that everything is in swedish Wink Maybe try sending them an email? They're based here in Malmö at the southern tip of Sweden, so the shipping distance isn't very great.
Another swedish store I've used is Elfa, but that seems to be part of something with a german branch (https://www.distrelec.de).
/Stefan
wishniak
PostPosted: Fri Jun 12, 2009 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
hehe - the kits i ordered are from curetronic. Cool
thanks for the tip. ill check it out.
Funky40
G2 patch files: 5
PostPosted: Mon Jun 15, 2009 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Look at Banzai ( berlin), there is another one, forgot the name.
Banzai is anyway best for capacitors.
you get also pots ( aplha) and knobs, but on this Musikding is better.
reichelt is cheapest, and as a german you have not the problems we forreigners have.
some parts are crap from reichelt
those sources should give you nearly all you need.
If more special parts are needed, then in the US: Mouser, small bear and some others.
6110 for example you get from small bear
http://www.banzaieffects.com/
http://www.musikding.de/
http://ch.mouser.com/Home.aspx
http://www.smallbearelec.com/Projects/ProjandProd.html
wishniak
PostPosted: Mon Jun 15, 2009 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks -
some told me about musicding, like, an hour ago!
and ive noticed that about reichelt. . sort of like the supermarket of the same name here.
ill check out the other ones for sure.
thanks!
oisin
PostPosted: Wed Jun 17, 2009 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
just put in an order with musikding. thanks for the tip.
