Modifying Arpeggiator sequence ?
Page 1 of 1 [4 Posts]
steampump
G2 patch files: 14
PostPosted: Sat Nov 13, 2004 2:21 pm    Post subject: Modifying Arpeggiator sequence ? Reply with quote  Mark this post and the followings unread
We have an Arpeggiator in the G2 Engine with mode UP, Down, UpDown, and a 4th who seems like a short sequence.
Can this last sequence be changed or modified ? And if yes how Question happy smoker
Artworks Music Computer
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Sat Nov 13, 2004 8:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it is just a random pattern.
Audio files: 107
PostPosted: Sun Nov 14, 2004 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I haven't got an example, unfortunately, but you can patch up a midi processor in the G2 to do any arpeggio you want, Try using the keyboard in or midi in module and then trigger a sequence you program with the arpeggio you want. Do this isn the poly area. Use a mixer to scale the output of the sequence by a derivitave of the note coming in.
PostPosted: Sun Nov 14, 2004 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's also the "voice #" which I think is geared for this specifically: I believe it tells each voice *which* voice it is (ie- "You are the 3rd voice played from this patch!").
Niio1
