<on air> Faux Pas Quartet and friends Music From Last Thursday [rebroadcast]
EChucK Design Files
Page 1 of 1 [7 Posts]
Inventor
Audio files: 258
PostPosted: Wed Mar 25, 2009 8:40 am    Post subject:  EChucK Design Files
Subject description: Open Source Repository
This sticky topic is intended to be a repository for EChucK design files. Please only post to this thread with a design file as an attachment, that way folks can peruse the files without having to scroll through lots of posts in-between the files. I'll start things off with the Eagle CAD files for the first circuit board, shown below.
Les
echuck4.sch
The Schematic File for the first EChucK PCB
 Filename:  echuck4.sch
 Filesize:  171.9 KB
 Downloaded:  460 Time(s)
echuck4.brd
The Board file for the first EChucK PCB
 Filename:  echuck4.brd
 Filesize:  40.15 KB
 Downloaded:  234 Time(s)
Inventor
Audio files: 258
PostPosted: Wed Mar 25, 2009 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the first EChucK dsPIC program. It uses timer2 and output compare 1 to create a square wave, not sure what the frequency is though, heh! Smile
TestCode1.c
Test Code 1: Makes a square wave
 Filename:  TestCode1.c
 Filesize:  9.43 KB
 Downloaded:  568 Time(s)
Inventor
Audio files: 258
PostPosted: Wed Mar 25, 2009 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a ChucK program I put together quickly last night that implements a Fuzz guitar synth. It is an initial shot at creating that "Matt Belamy of Muse" guitar sound that someone on another forum likes a lot. I like it too.
The program features AGC followed by soft distortion (AKA fuzz). The program uses only simple ChucK UGens that are implementable in EChucK dsPIC processors. If you don't have a guitar to plug into your line in jack, just use the microphone and talk into it - you'll sound like a distorted guitar!
LievenDV_Fuzz1.ck
ChucK program that implements a fuzz guitar pedal
 Filename:  LievenDV_Fuzz1.ck
 Filesize:  544 Bytes
 Downloaded:  182 Time(s)
Inventor
Audio files: 258
PostPosted: Tue May 19, 2009 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
In an effort to partner up with the Lunetta folks and do a joint project, and also because I was up late/early in the wee hours without much to do, I simulated a Lunetta. It is a 4094 circuit with feedback logic, very interesting. I wasn't able to get any really complex patterns from it but the sound is nice. Below you will find the ChucK source and the audio sample. Enjoy!
Les
4094_1.ck
The 4094 source code
 Filename:  4094_1.ck
 Filesize:  3.99 KB
 Downloaded:  200 Time(s)
4094_1.mp3
The 4094 audio sample
 Filename:  4094_1.mp3
 Filesize:  318.77 KB
 Downloaded:  390 Time(s)
Inventor
Audio files: 258
PostPosted: Wed Jun 17, 2009 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alright, I think that maybe I have finally decided what to do for the next eChucK board. It will be a boolean sequencer with karplus-strong string synthesis output circuit. My next step os to obtain the chips so that I can construct a prototype.
The ChucK file attached is a ChucK simulation of that eChucK board. You can change the numbers in the program to vary the song or the string synthesis parameters, varying the guitar's sound. I enjoy it and I'll be featuring it on the next ChucK Show.
Les
booleansequencerlunetta2.ck
ChucK simulation of eChucK circuit
 Filename:  booleansequencerlunetta2.ck
 Filesize:  937 Bytes
 Downloaded:  190 Time(s)
Inventor
Audio files: 258
PostPosted: Sun Nov 29, 2009 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I was asked to provide the eChucK Lunetta board files so that people can draw out their circuits on them, so here they are. I had 100 of these little breakout boards made and sold about 60 of them, leaving me with plenty to play around with in my lab.
Les
eChucKLunetta.zip
eChucK Lunetta schematic, board, and library files
 Filename:  eChucKLunetta.zip
 Filesize:  10.56 KB
 Downloaded:  235 Time(s)
Inventor
Audio files: 258
PostPosted: Fri Sep 17, 2010 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have decided to make the eChucK Karplus Strong design files public domain so that they can be put to best use. I'm ready to move on to the Credit Card Synth project now, so best thing to do is set this little bird free. If you make use of the files and profit from them or end up making music that you enjoy using this design, please consider making a donation of any amount to electro-music.com - Thanks!
KS11 design files.zip
KS11 design files
 Filename:  KS11 design files.zip
 Filesize:  128.37 KB
 Downloaded:  188 Time(s)
mps board
