What "chipset" would you like to see in a Dim D PCB |
Original chips. They are still out there. |
76% |
[ 39 ] |
Low voltage BBDs - easier to get, probably more noisy. Takes longer to design. |
5% |
[ 3 ] |
Make a PCB that allows both options. Will be more expensive (more PCB area required!), and will take the longest to design. |
13% |
[ 7 ] |
Not interested. (Who needs a Dim D? And isn't there another Dim D project on the way?!) |
3% |
[ 2 ] |
Total Votes : 51 |
lexvortex
Posted: Thu May 21, 2009 9:43 pm Post subject:
Calibration of DimD |
Hi JH,
I just powered up my DimD and it seems to function OK How should I calibrate this? There are a number of trim pots but I didn't see any instructions on what to do with them. Right now I've got them all set to mid point.
Thanks,
Dave |
jhaible
Posted: Fri May 22, 2009 12:54 am Post subject:
Re: Calibration of DimD |
lexvortex wrote: | Hi JH,
Thanks,
Dave |
http://www.jhaible.de/subtle_chorus/subtle_chorus_main_board_sch_dwg2.pdf
CMR means common mode rejection - put trimmers in position where CMR is best. (Signal applied to positive and negative input.)
http://www.jhaible.de/subtle_chorus/jh_subtle_chorus_BBD_Board_sch_page1.pdf
R15 and R82 set for symmetrical clipping of BBD.
R24 and R65 set for best clock suppression
http://www.jhaible.de/subtle_chorus/subtle_chorus_main_board_sch_dwg1.pdf
Tau Bias: set by ear for pleasant sound in Dim T mode.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
numbertalk
Posted: Fri May 22, 2009 7:36 am Post subject:
This is moving up in my build queue and I've been wondering about the calibration process as well.
jhaible wrote: | CMR means common mode rejection - put trimmers in position where CMR is best. (Signal applied to positive and negative input.) |
Could you explain a little more what exactly Common Mode Rejection is and how we measure this exactly, and what we're ideally looking for? Also where on the board do we put our probes to measure?
[quote="jhaible]R15 and R82 set for symmetrical clipping of BBD.[/quote]
Is this where we, for example, feed in a sine wave and adjust for the most amplitude with no clipping? What are the test points we should take our measurements from?
jhaible wrote: | R24 and R65 set for best clock suppression |
How do we measure this exactly - what are we looking for and where on the board do we measure this (test point)?
Thanks! |
jhaible
Posted: Fri May 22, 2009 9:07 am Post subject:
CMR: On the balanced input, feed the same signal to both input wires (the "positive" and the "negative" polarity). Ideally, there should be no signal at the output of the input amplifier. In paractice, set the trimmer to the position where the remaining signal is at its minimum.
Clock suppression: After the first opamp, following the BBD.
Ideally: no high frequency signal from BBD clock.
In practice, set trimmer such that the remaining HF signal is minimal.
numbertalk
Posted: Fri May 22, 2009 10:19 am Post subject:
jhaible wrote: | CMR: On the balanced input, feed the same signal to both input wires (the "positive" and the "negative" polarity). Ideally, there should be no signal at the output of the input amplifier. In paractice, set the trimmer to the position where the remaining signal is at its minimum. |
If we're not planning to use the balanced input does this stillt need to be set?
jhaible wrote: | Clock suppression: After the first opamp, following the BBD.
In practice, set trimmer such that the remaining HF signal is minimal. |
So this is with no input or does that not matter - we're just looking at the clock signal, right? How do we distinguish "HF signal"? Will this be the presence of *any* signal or will the trimmer filter out the HF signal and will we see a lower frequency signal present?
Thanks! |
jhaible
Posted: Fri May 22, 2009 11:34 am Post subject:
numbertalk wrote: |
For unbalnced signals, you can just ignore the trimmer.
No signal applied, just looking for remnants of the clock.
You know it as HF by measuring the period on the oscilloscope.
if you don't have a scope, don't worry. Just leave these trimpots in mid position. Many BBD devices don't use a trimpot for this at all.
numbertalk
Posted: Fri May 22, 2009 3:36 pm Post subject:
jhaible wrote: | No signal applied, just looking for remnants of the clock.
if you don't have a scope, don't worry. Just leave these trimpots in mid position. Many BBD devices don't use a trimpot for this at all. |
I do have a scope. So I would just trim for the lowest frequency of this signal it sounds like (in other words I will see it slow down rather than diminish as I trim)?
Thanks! |
jhaible
Posted: Fri May 22, 2009 11:50 pm Post subject:
numbertalk wrote: | jhaible wrote: | No signal applied, just looking for remnants of the clock.
Thanks! |
Lowest Level, not lowest frequency.
Put the probe on the wiper of the trimmer first, and you see the offender, unfiltered. There shouldn't be much of it after the first opamp - but if you see something, the trimmer will minimize it. You won't *hear* it, anyway.
numbertalk
Posted: Sat May 23, 2009 5:32 am Post subject:
Thanks! |
JoeMorris
Posted: Tue Jun 09, 2009 4:24 am Post subject:
After successful triple chorus and tau builds, the inevitable has struck and I have hit a stumbling block - my dim d build doesnt make a sound when I plug it in......
ouch.
Any hints for a novice troubleshooter? |
JoeMorris
Posted: Thu Jun 11, 2009 7:07 am Post subject:
Ive checked all the component positions and polarity and everything checks out.... except one of the tl072s on the main board was in the wrong way round which ive now sorted (could this have damaged the chip?). But still no sound, even in bypass mode. the led does turn on, however. Where can I start looking for suitable values for testing purposes? I couldnt get the 27nf caps on the main board, so I soldered in 22nf and 4.7nf into the same holes, is this cool?
Any pointers would be massively appreciated, Im a bit lost on where to start. I only have a multimeter, no scope unfortunately. |
jhaible
Posted: Sun Jun 14, 2009 7:57 am Post subject:
JoeMorris wrote: | .. except one of the tl072s on the main board was in the wrong way round which ive now sorted (could this have damaged the chip?). |
Definitely, yes.
Replace opamp, check supply voltages at every chip (pins. see schematics).
Then trace signal path with a scope from input to output - the usual procedure.
JH.
(just back from Italy) _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
JoeMorris
Posted: Mon Jun 15, 2009 8:32 am Post subject:
Thanks for the reply JH...
I will try this. Unfortunately I dont have a scope... will this ruin my chances of diagnosis? Or is there any other way..?
Joe |
ognam
Posted: Mon Jun 15, 2009 8:59 am Post subject:
Hello everybody. I´m on the way for my Dim D
I have nearly every parts, but I don´t know where to get the BBD-Stuff...
I still need:
-MN3007
-MC14069UB
-NE 570N
-LM13600
I live in Berlin. Where can I get this stuff here in Germeny?
And what about HA1457W? What is the difference between using this and TL071/72 like the footprints on the pcb are saying?
Thanks for this awsome project!
Jonas |
jhaible
Posted: Mon Jun 15, 2009 12:15 pm Post subject:
JoeMorris wrote: | Thanks for the reply JH...
Joe |
I hate to say this, but a scope really *is* helpful here. Maybe you have a friend with a scope locally, who will trace signals with you?
jhaible
Posted: Mon Jun 15, 2009 12:20 pm Post subject:
ognam wrote: | Hello everybody. I´m on the way for my Dim D
I still need:
-MN3007
-MC14069UB
-NE 570N
-LM13600
Jonas |
LM13600 can be replaced with LM13700. Should be available at www.reichelt.de . Same for MC14069 ("MOS4069" should be the Reichelt number.)
The rest is NOS only. I think Tobias provides kits that include these chips (Tobias?). And there are special music electronics dealers like vintageplanet in NL and small bear in the USA.
HA1457? - I don't hear a difference; others might.
numbertalk
Posted: Fri Jun 19, 2009 8:25 am Post subject:
Subject description: XLR jacks from Mouser? |
If I wanted to include balanced inputs and outputs for my Dim-TD could anyone give me a Mouser part # or a link to what I'd want exactly from a U.S. supplier? Would this one work:
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMuCv89HBVkAk8rw6%252bQLRk9c
If so, any concerns with how these are mounted to the panel or enclosure? Are they usually threaded on the back and take a nut inside the unit that fastens against the back of the panel?
Thanks! |
numbertalk
Posted: Fri Jun 19, 2009 4:16 pm Post subject:
Ok, I got the XLR jacks figured out, but Juergen, could you tell me if heat sinks I have left over extra from the Krautrock Phaser project would also fit the footprint on the Main Board for this project?
Also, on the BOM for the BBD Board, there's a section of components called just "Capacitors", between the polyester section and the ceramic section. Based on the values it seems these could/should be ceramic (150pf, 330pf for example) but wanted to make sure before I ordered parts.
Thanks! |
JoeMorris
Posted: Sat Jun 20, 2009 12:51 am Post subject:
my understanding is that these shouldnt be ceramic, but dont take my word for it. |
numbertalk
Posted: Sat Jun 20, 2009 3:57 am Post subject:
JoeMorris wrote: | my understanding is that these shouldnt be ceramic, but dont take my word for it. |
I thought so too but wasn't seeing film caps with some of those values.
Also regarding heat sinks I finally found my stash of ones I used on the compact phasing so will see how those fit here.
Thanks. |
jhaible
Posted: Sat Jun 20, 2009 5:21 am Post subject:
numbertalk wrote: | JoeMorris wrote: | my understanding is that these shouldnt be ceramic, but dont take my word for it. |
Thanks. |
Just try them and then feel if they don't get too hot. (Depends on many factors, mainly on the voltage pre-regulator, and air circulation.
numbertalk
Posted: Sat Jun 20, 2009 8:10 am Post subject:
Thanks JH. I found some polyesters in these values, so long as 50V is ok for these particular caps.
jhaible wrote: | numbertalk wrote: | JoeMorris wrote: | my understanding is that these shouldnt be ceramic, but dont take my word for it. |
Thanks. |
JH. |
jhaible
Posted: Sat Jun 20, 2009 8:32 am Post subject:
50V is plenty.
JH.
numbertalk wrote: | Thanks JH. I found some polyesters in these values, so long as 50V is ok for these particular caps.
Thanks. |
JH. |
numbertalk
Posted: Sat Jun 20, 2009 4:25 pm Post subject:
Great thanks!
jhaible wrote: | 50V is plenty.
JH.
Thanks. |
JH. |
numbertalk
Posted: Mon Jun 22, 2009 6:01 pm Post subject:
Hi JH,
The only trimmer I don't see any instructions on how to calibrate is the LFO Offs trimmer on the BBD board - what is this one exactly and how is this one set?
Thanks! |
