<on air> Various Artists March Equinox 2017 streaming concert
Dim D
Page 9 of 13 [313 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, 12, 13 Next
What "chipset" would you like to see in a Dim D PCB
Original chips. They are still out there.
76%
 76%  [ 39 ]
Low voltage BBDs - easier to get, probably more noisy. Takes longer to design.
5%
 5%  [ 3 ]
Make a PCB that allows both options. Will be more expensive (more PCB area required!), and will take the longest to design.
13%
 13%  [ 7 ]
Not interested. (Who needs a Dim D? And isn't there another Dim D project on the way?!)
3%
 3%  [ 2 ]
Total Votes : 51
lexvortex
PostPosted: Thu May 21, 2009 9:43 pm    Post subject: Calibration of DimD Reply with quote  Mark this post and the followings unread
Hi JH,
I just powered up my DimD and it seems to function OK Smile How should I calibrate this? There are a number of trim pots but I didn't see any instructions on what to do with them. Right now I've got them all set to mid point.
Thanks,
jhaible
PostPosted: Fri May 22, 2009 12:54 am    Post subject: Re: Calibration of DimD Reply with quote  Mark this post and the followings unread
lexvortex wrote:
Hi JH,
Thanks,
http://www.jhaible.de/subtle_chorus/subtle_chorus_main_board_sch_dwg2.pdf
CMR means common mode rejection - put trimmers in position where CMR is best. (Signal applied to positive and negative input.)
http://www.jhaible.de/subtle_chorus/jh_subtle_chorus_BBD_Board_sch_page1.pdf
R15 and R82 set for symmetrical clipping of BBD.
R24 and R65 set for best clock suppression
http://www.jhaible.de/subtle_chorus/subtle_chorus_main_board_sch_dwg1.pdf
Tau Bias: set by ear for pleasant sound in Dim T mode.
JH.
numbertalk
PostPosted: Fri May 22, 2009 7:36 am    Post subject: Re: Calibration of DimD Reply with quote  Mark this post and the followings unread
This is moving up in my build queue and I've been wondering about the calibration process as well.
Could you explain a little more what exactly Common Mode Rejection is and how we measure this exactly, and what we're ideally looking for? Also where on the board do we put our probes to measure?
[quote="jhaible]R15 and R82 set for symmetrical clipping of BBD.[/quote]
Is this where we, for example, feed in a sine wave and adjust for the most amplitude with no clipping? What are the test points we should take our measurements from?
How do we measure this exactly - what are we looking for and where on the board do we measure this (test point)?
jhaible
PostPosted: Fri May 22, 2009 9:07 am    Post subject: Re: Calibration of DimD Reply with quote  Mark this post and the followings unread
CMR: On the balanced input, feed the same signal to both input wires (the "positive" and the "negative" polarity). Ideally, there should be no signal at the output of the input amplifier. In paractice, set the trimmer to the position where the remaining signal is at its minimum.
Clock suppression: After the first opamp, following the BBD.
Ideally: no high frequency signal from BBD clock.
In practice, set trimmer such that the remaining HF signal is minimal.
JH.
numbertalk
PostPosted: Fri May 22, 2009 10:19 am    Post subject: Re: Calibration of DimD Reply with quote  Mark this post and the followings unread
If we're not planning to use the balanced input does this stillt need to be set?
So this is with no input or does that not matter - we're just looking at the clock signal, right? How do we distinguish "HF signal"? Will this be the presence of *any* signal or will the trimmer filter out the HF signal and will we see a lower frequency signal present?
jhaible
PostPosted: Fri May 22, 2009 11:34 am    Post subject: Re: Calibration of DimD Reply with quote  Mark this post and the followings unread
For unbalnced signals, you can just ignore the trimmer.
No signal applied, just looking for remnants of the clock.
You know it as HF by measuring the period on the oscilloscope.
if you don't have a scope, don't worry. Just leave these trimpots in mid position. Many BBD devices don't use a trimpot for this at all.
JH.
numbertalk
PostPosted: Fri May 22, 2009 3:36 pm    Post subject: Re: Calibration of DimD Reply with quote  Mark this post and the followings unread
I do have a scope. So I would just trim for the lowest frequency of this signal it sounds like (in other words I will see it slow down rather than diminish as I trim)?
jhaible
PostPosted: Fri May 22, 2009 11:50 pm    Post subject: Re: Calibration of DimD Reply with quote  Mark this post and the followings unread
Lowest Level, not lowest frequency.
Put the probe on the wiper of the trimmer first, and you see the offender, unfiltered. There shouldn't be much of it after the first opamp - but if you see something, the trimmer will minimize it. You won't *hear* it, anyway.
JH.
numbertalk
PostPosted: Sat May 23, 2009 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
JoeMorris
PostPosted: Tue Jun 09, 2009 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
After successful triple chorus and tau builds, the inevitable has struck and I have hit a stumbling block - my dim d build doesnt make a sound when I plug it in......
ouch.
Any hints for a novice troubleshooter?
JoeMorris
PostPosted: Thu Jun 11, 2009 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Ive checked all the component positions and polarity and everything checks out.... except one of the tl072s on the main board was in the wrong way round which ive now sorted (could this have damaged the chip?). But still no sound, even in bypass mode. the led does turn on, however. Where can I start looking for suitable values for testing purposes? I couldnt get the 27nf caps on the main board, so I soldered in 22nf and 4.7nf into the same holes, is this cool?
Any pointers would be massively appreciated, Im a bit lost on where to start. I only have a multimeter, no scope unfortunately.
jhaible
PostPosted: Sun Jun 14, 2009 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Definitely, yes.
Replace opamp, check supply voltages at every chip (pins. see schematics).
Then trace signal path with a scope from input to output - the usual procedure.
JH.
(just back from Italy)
JoeMorris
PostPosted: Mon Jun 15, 2009 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply JH...
I will try this. Unfortunately I dont have a scope... will this ruin my chances of diagnosis? Or is there any other way..?
Joe
ognam
PostPosted: Mon Jun 15, 2009 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello everybody. I´m on the way for my Dim D Smile
I have nearly every parts, but I don´t know where to get the BBD-Stuff...
I still need:
-MN3007
-MC14069UB
-NE 570N
-LM13600
I live in Berlin. Where can I get this stuff here in Germeny?
And what about HA1457W? What is the difference between using this and TL071/72 like the footprints on the pcb are saying?
Thanks for this awsome project!
Jonas
jhaible
PostPosted: Mon Jun 15, 2009 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Joe
I hate to say this, but a scope really *is* helpful here. Maybe you have a friend with a scope locally, who will trace signals with you?
JH.
jhaible
PostPosted: Mon Jun 15, 2009 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I still need:
-MN3007
-MC14069UB
-NE 570N
-LM13600
Jonas
LM13600 can be replaced with LM13700. Should be available at www.reichelt.de . Same for MC14069 ("MOS4069" should be the Reichelt number.)
The rest is NOS only. I think Tobias provides kits that include these chips (Tobias?). And there are special music electronics dealers like vintageplanet in NL and small bear in the USA.
HA1457? - I don't hear a difference; others might.
JH.
numbertalk
PostPosted: Fri Jun 19, 2009 8:25 am    Post subject:
Subject description: XLR jacks from Mouser?
If I wanted to include balanced inputs and outputs for my Dim-TD could anyone give me a Mouser part # or a link to what I'd want exactly from a U.S. supplier? Would this one work:
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMuCv89HBVkAk8rw6%252bQLRk9c
If so, any concerns with how these are mounted to the panel or enclosure? Are they usually threaded on the back and take a nut inside the unit that fastens against the back of the panel?
numbertalk
PostPosted: Fri Jun 19, 2009 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I got the XLR jacks figured out, but Juergen, could you tell me if heat sinks I have left over extra from the Krautrock Phaser project would also fit the footprint on the Main Board for this project?
Also, on the BOM for the BBD Board, there's a section of components called just "Capacitors", between the polyester section and the ceramic section. Based on the values it seems these could/should be ceramic (150pf, 330pf for example) but wanted to make sure before I ordered parts.
JoeMorris
PostPosted: Sat Jun 20, 2009 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
my understanding is that these shouldnt be ceramic, but dont take my word for it.
numbertalk
PostPosted: Sat Jun 20, 2009 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought so too but wasn't seeing film caps with some of those values.
Also regarding heat sinks I finally found my stash of ones I used on the compact phasing so will see how those fit here.
Thanks.
jhaible
PostPosted: Sat Jun 20, 2009 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
Just try them and then feel if they don't get too hot. (Depends on many factors, mainly on the voltage pre-regulator, and air circulation.
JH.
numbertalk
PostPosted: Sat Jun 20, 2009 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks JH. I found some polyesters in these values, so long as 50V is ok for these particular caps.
Thanks.
JH.
jhaible
PostPosted: Sat Jun 20, 2009 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
50V is plenty.
JH.
Thanks.
JH.
numbertalk
PostPosted: Sat Jun 20, 2009 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great thanks!
jhaible wrote:
50V is plenty.
JH.
Thanks.
JH.
numbertalk
PostPosted: Mon Jun 22, 2009 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
The only trimmer I don't see any instructions on how to calibrate is the LFO Offs trimmer on the BBD board - what is this one exactly and how is this one set?
