Headphone routing
Page 1 of 1 [5 Posts]
AngusHastie
PostPosted: Tue Nov 16, 2004 10:41 am    Post subject: Headphone routing Reply with quote  Mark this post and the followings unread
If I assign a sound to output 3/4, it comes out of the 3/4 outputs ok but you can't hear it through the headphone jack. I want to be able to assign a metronome click to 3/4 and front-of-house sounds to the 1/2 output pair to go through the PA, with our drummer getting both in a headphones mix. Is this possible to do without resorting to an external hardware mixer?
Cheers, Angus
Fozzie
G2 patch files: 49
PostPosted: Tue Nov 16, 2004 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
AFAIK, it is a fixed hw routing of outputs 1&2 to the headphones. So for your problem, wouldn't it be possible to permanently switch the use of your outputs: 1&2 click for drummer, 3&4 to FOH?
Edit: didn't read well Embarassed , you should mix output 3&4 signals in your patch with the click on 1&2, and feed this through the headphone out to the drummer. That way you have a mix with click for the drummer, FOH signal on 3&4 w/o click, and no hardware mixer. It does involve a little repatching.
AngusHastie
PostPosted: Tue Nov 16, 2004 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
So if I understand correctly, in order to give my drummer some of the actual FOH sounds as well as the click, I'd have to add a mixer module to my patches that take some of the 3/4 mix and mix it with the click on 1/2, right? Or alternatively, I suppose I could get a mono jack for the headphones, route the click to say 3 and just plug the phones into 3 and also add another output module to my patches to send a copy of the FOH sounds to 3...
Or maybe just record the whole lot on mini disc and hit play! Confused
jamos
G2 patch files: 37
PostPosted: Tue Nov 16, 2004 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you're going to have your drummer use headphones, it makes sense to have a separate headphone mixer and amp. Because -
- The level of the G2's phone output may not be high enough. I know that it isn't for me; I use my external mixer when I use headphones.
- The drummer probably will want to adjust the click volume independently of the synth volume.
AngusHastie
PostPosted: Wed Nov 17, 2004 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Good points. I think you're right. Simplifies the whole patching process too.
