  bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » Kyma » Tutorials
Hard Sync
Page 1 of 1 [9 Posts]
BobTheDog
PostPosted: Tue Jun 30, 2009 9:18 am    Post subject: Hard Sync
Subject description: How to hard sync an oscillator with another oscillator.
Rob was interested in how to do this, so here is our first tutorial:
1. Create A new Sound
2. Drag an Oscillator into your sound and double click it.
3. Change the Frequency field to !Freq1smoothed
4. Now we need another Osc for syncing, lets copy the one we have:
Select the oscillator and copy it with CMD/CTRL C
Now click in the Reset field of the original oscillator and paste with CMD/CTRL V
5. Double click the background to refresh the sound and click on the input dots to expand.
6. Select the first OSC in the chan and set Frequency to !Freq2 smoothed
Play the sound and muck about with the frequencies.
HardSync.kym
Example Hard Sync Sound.
 Filename:  HardSync.kym
 Filesize:  47.41 KB
 Downloaded:  115 Time(s)
Muied Lumens
Audio files: 209
PostPosted: Tue Jun 30, 2009 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you kindly.
I will have a play with it and also replace the master oscillator with a live input to see how that works.
Muied Lumens Base Star
driskel
PostPosted: Wed Jul 01, 2009 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, being new to Kyma and this website I appreciate the tutorials.
How about now controlling the sound with an ADSR triggered by !KeyDown and the base oscillator's pitch via !KeyPitch?
BobTheDog
PostPosted: Thu Jul 02, 2009 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Driskel and welcome to the forum.
I will knock something up and post here.
BobTheDog
PostPosted: Thu Jul 02, 2009 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually I am beginning to think what I said above is incorrect Embarassed
The Reset field of the oscillator is not acting how I thought it should.
I Am thinking about it..
driskel
PostPosted: Thu Jul 02, 2009 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not a problem, I appreciate the successes as well as failures. Regardless of whether you achieved your goal, I came across some interesting sounds due to your tutorial.
The miss-steps are as important as the steps.
Thank you.
driskel
PostPosted: Thu Jul 02, 2009 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now in terms of the ADSR question. This is from memory. If I make a mistake I will correct.
1) Command/Apple b and search for product
2) Drag it onto the line exiting the oscillator on the right. Make sure that you do not drag it to the + symbol.
3) Command/Apple b and search for ADSR, and drag onto the oscillator that was created when added the product prototype
4) Click on the ADSR and if "!KeyDown" is not in the gate field add it.
4) If you are using a wacom tablet and want the gate to be triggered via PenDown use "!PenDown" instead of "!KeyDown"
BobTheDog
PostPosted: Fri Jul 03, 2009 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys,
The problem may be the reset field not running at audio rate, not quite sure yet.
I have asked on the SymbolicSound forum, you can follow this at  http://www.symbolicsound.com/cgi-bin/forumdisplay.cgi?action=displayprivate&number=7&topic=000301
P.S. We are all beginners here!
Andy
Muied Lumens
Audio files: 209
PostPosted: Fri Jul 03, 2009 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
The control rate in Kyma is somewhere around 1 kHz IIRC, so if that is the only barrier it should work in some cases, but I have not yet had time to look deeper into this specific problem. Still going through the manual, learning the specifics of the timeline.
AmbiphonicDSP
