magman
Joined: Feb 04, 2009 Posts: 264 Location: Liverpool, UK
Posted: Fri Jun 05, 2009 12:54 am Post subject:
I think this is the tool you are looking for.
http://www.mouser.com/Search/Refine.aspx?Keyword=571-598031
You shouldn't have to bend the wire at all, just rest it on top of the connector and push down with the insertion tool. You also have to be careful not to use too thick a gauge of wire, or this can splay the connector and give an unreliable connection.
These connectors are known as IDC's, or Insulation Displacement Connectors, the idea being that when you push the wire down into the connector, the sharp edges of the connector cut through the insulation and make contact with the conductor inside the wire. It is actually a very good method of connection in some ways. Apart from being very quick in a production environment, the insulation is displaced by the connection process, which gives a gas tight seal between the conductor and the contact, which reduces the oxidation of the contact leading to a relatively long lived connection.
Regards
Magman |
hendrixworkshop
Posted: Fri Jun 05, 2009 6:28 am Post subject:
Thanks for the clarification Magman |
Magman,
Thanks for the quick answer. I'm ordering that tool now.
Andy |
hendrixworkshop
Posted: Tue Jun 16, 2009 12:34 pm Post subject:
...yet another bug related (front panel) question |
I'm assuming that the input/output jacks in these pics are banana plugs? I've seen how partial bugbrand is to these.
The parts list off the Stites website calls for "1/4 " phone jack, n.c.". The Mankato calls for 1/8" jacks. And here I see the banana jacks on the Bug MPS. Am I caught up in what boils down to different preferences? I'm planning on building 2 MPSs, a TH101, TH201 and a TH301. Should I be putting 1/8" jacks in all of them?
I'm almost ready to wire up the panels (still designing MPS front panel ala the Bug MPS 3 space frac). I think this is the point in which I should standardize (if need) for the future.
I appreciate any help on this subject.
Andy
| Description: |
| Filesize: |
115.95 KB |
| Viewed: |
71 Time(s) |
| Description: |
| Filesize: |
154.26 KB |
| Viewed: |
59 Time(s) |
wmonk
Joined: Sep 15, 2008 Posts: 235 Location: Utrecht, the Netherlands
Posted: Tue Jun 16, 2009 2:46 pm Post subject:
Hi Andy,
it all depends on your taste. If you like 1/4" jacks, use them on all panels, if you like bananas, use bananas. You can use different connectors in one project, but most people out here standardize to their preference.
It doesn't really matter which type you use, but when using bananas you must sometimes add a switch to get the same results. On the other hand, with bananas you don't need multiples in a modular system.
Hope it's clear,
Thomas Peter |
nadafarms
Posted: Fri Jun 26, 2009 4:46 pm Post subject:
if anyone has a finished mps drum synth I'll buy it! I'm in Berkeley, CA
I can't even tighten screws... but I want one of these bad. |
Funky40
G2 patch files: 5
Posted: Mon Jun 29, 2009 8:23 am Post subject:
Hello:
my MPS Boards are in progress, two things:
1. the 820pF cap is poly. Whats meant ? polystyrene ? ( or polypropylen)
2. Has somebody tips how to group the knobs ?
what belongs together ? ( I must admit that i havn't had a closer look exept of following thiis thread back then, but infos where not much )
thanks |
hendrixworkshop
Posted: Mon Jun 29, 2009 8:43 am Post subject:
Source/part number for "L" bracket |
Does anyone know a source/part number for the "L" brackets (and hardware) used to anchor the pcb to the front panel? I need a few sets for all the Thomas Henry modules I have in the works, but mainly to finish my 2 MPSs.
Thanks,
Andy |
Joined: Jul 11, 2005 Posts: 4145 Location: Nambucca Heads, Australia
Audio files: 36
Funky40
G2 patch files: 5
Posted: Tue Jun 30, 2009 11:08 am Post subject:
| Thanks uncleK |
funkyfarm
Audio files: 36
Posted: Tue Jun 30, 2009 3:17 pm Post subject:
Sorry funkyfarm,
I can't read .fpd s  _________________ Once you believe in a God you'll believe anything. |
funkyfarm
Posted: Tue Jun 30, 2009 4:15 pm Post subject:
you know what ? you're lucky !
I came to see if swiss Funky40 was still awake in the night and to know if he saw the .fpd and
I've just imported a screeprint of it in illustrator to play with colors
it will lie in a box (to put on a table...next to the klee seq) |
funkyfarm
Posted: Tue Jun 30, 2009 4:17 pm Post subject:
I said "colours" ?
(okay, that's too much and awfull) |
funkyfarm
Posted: Tue Jun 30, 2009 4:23 pm Post subject:
For the SHELL section, can I put X PITCH (for main pitch) Y PITCH, Y DEPTH and X/Y BALANCE (and X SWEEP and X DECAY...) ? or Carrier and modulator ? that is it ?
That's really hard to get clear distinct sections...
creatorlars
funkyfarm
Posted: Wed Jul 01, 2009 1:55 pm Post subject:
| (this is real art !) |
Funky40
G2 patch files: 5
Posted: Thu Jul 09, 2009 11:15 am Post subject:
hey, thanks for posting
I just came back now to this to start now my Frontpanel.
I have two Boards populated, some more in backlog.
My plan is to build two modules with all the Pots and jacks, and patch then with those,
and then to work out some "preset Sounds" so that i can make some of my modules with much less pots.
I guess i will make trimmers in the back of the Module so that i can change Presets
mods ? uff, too much of a thinking for me now.
i'll follow you with much interest french funkyfarm  |
Funky40
G2 patch files: 5
Funky40
G2 patch files: 5
Posted: Thu Jul 09, 2009 11:22 am Post subject:
Re: Source/part number for "L" bracket |
| funkyfarm wrote: | | (this is real art !) |
yup. some guys here turn out as real artists.
| hendrixworkshop wrote: | Does anyone know a source/part number for the "L" brackets (and hardware) used to anchor the pcb to the front panel? I need a few sets for all the Thomas Henry modules I have in the works, but mainly to finish my 2 MPSs.
Thanks,
Andy |
I just know the Motm style brackets.
i guess you would have to drill them by yourself that they suite.
check out www.bridechamber.com and maybe contact Scott ( see parts ) |
Funky40
G2 patch files: 5
Posted: Thu Jul 09, 2009 11:46 am Post subject:
I had a look to the panels, now i'm puzzled.
So much different all your Panels  |
hway23
Posted: Thu Jul 09, 2009 1:50 pm Post subject:
| I just ordered a board yesterday. Really looking forward to building it out! |
Funky40
G2 patch files: 5
Posted: Sat Jul 18, 2009 4:55 pm Post subject:
concerning all the connectors:
is the square pad the Pad #1 ?
thanks |
Funky40
G2 patch files: 5
Posted: Tue Jul 21, 2009 11:04 am Post subject:
| funny, whenever i say thanks in advance i get no answer. |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1172 Location: Telford, PA USA
Posted: Tue Jul 21, 2009 2:36 pm Post subject:
| Funky40 wrote: | concerning all the connectors:
thanks |
That should be the case. Without having mine to look at readily, I would say it is a safe bet that it is indeed Pin #1. |
Funky40
G2 patch files: 5
Posted: Wed Jul 22, 2009 7:48 am Post subject:
| Danno Gee Ray wrote: | | Funky40 wrote: | concerning all the connectors:
thanks |
yup it is, thanks.
I finished wiring now.
I thought it is #1, but then i thought it would be stupid if it isn't , so i asked |
