davep
Joined: Jul 05, 2004 Posts: 467 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Tue Jun 16, 2009 3:53 pm Post subject:
Wonderful new phase shifter module |
Hi all,
I have a fairly large Dotcom/MOTM modular synth and I have been on the hunt for some of the more unusual modules, and I have just found something really special.
I have been looking at the various phase shifter modules available from different manufacturers but IMO they are all missing important features - some only do positive-mix phasing, some only do negative, some just don't sound so great. Last year I was discussing this with a friend of ours, Rob Hordijk from The Netherlands. For those who don't know Rob, he's a synth genius (check out his amazing tutorials for tips & tricks on the Nord G2 Modular) and he has now gotten interested in producing some unusual and high-quality boutique analog synth modules and his Dual Phaser module is the first in a series of new devices.
A few specs:
It's a double-wide MOTM format module and works with MOTM or DOTCOM power systems, and the final production version may also have Doepfer power connectors as well.
It consists of two identical 8-stage phasers with some tricky routing and patching between them using switched jacks - patch audio into phaser 1 and out of phaser 2 and the two phasers will be routed in parallel but the second one will be inverted, which gives you all sorts of cool effects (more later). Also, patch a control signal into the phaser 1 1V/OCT input and nothing into the second phaser's 1V/OCT input and the first signal gets routed to both phasers' control inputs.
Perhaps the coolest feature - the MOD input has three functions, determined by a three position toggle switch:
1. SWEEP MODE - Standard frequency sweep, like other phasers, where all peaks sweep up & down as a group.
2. SPREAD MODE - The upper peaks and the lower peaks are spread apart & pulled closer together and cross over each other ( ! ) This produces amazing vocal timbres and all sorts of complex filter effects and sounds really wonderful.
3. HALF-SPREAD MODE - the upper peaks move further away & closer to the lower peaks and the lower peaks are not affected.
There is a second MOD input that is calibrated to 1V/OCT and this always acts as a SWEEP mode for all peaks, so you can SWEEP the peaks with one LFO and SPREAD the peaks with a different LFO at a different rate, which creates some really complex shifting timbres.....
The MIX control is bi-polar which adds even more sonic possibilities. Set straight up at 12 O'Clock you get dry only, no phaser (bypass mode). Turn it clockwise and you increase the phaser mix, and the phased output is positive. Turn it counter-clockwise and you increase the phaser mix, but now the phased signal is inverted which sounds very different from positive phasing.
The resonance control always provides positive (non-inverted) feedback, regardless if the mix control is set to positive or negative. By setting the MIX to negative and using an external feedback loop, you can easily get negative mix with negative feedback, so you have lots of sonic possibilities with pos & neg mix and pos or neg feedback. These combinations all sound different and this flexibility gives you a lot of options.
I'm attaching some photos here and I'll attach some short audio clips in some follow-up posts.
Description: |
Filesize: |
103.43 KB |
Viewed: |
357 Time(s) |
Description: |
Filesize: |
85.89 KB |
Viewed: |
469 Time(s) |
Description: |
Filesize: |
58.87 KB |
Viewed: |
339 Time(s) |
Description: |
Filesize: |
226.41 KB |
Viewed: |
335 Time(s) |
_________________ Dave Peck |
davep
Audio files: 10
G2 patch files: 73
davep
Audio files: 10
G2 patch files: 73
Posted: Tue Jun 16, 2009 4:08 pm Post subject:
These are all one sawtooth oscillator, no other filtering or any other effects, just the phaser module. And in these clips, you are hearing only ONE of the two phasers. Some clips are positive mix, some are negative. You can hear the cool vocal-type sounds created by modulating both the frequency sweep and the peak spread.
Description: |
 Download |
Filename: |
1phaser neg sweep & spread more res.mp3 |
Filesize: |
492.39 KB |
Downloaded: |
842 Time(s) |
Description: |
 Download |
Filename: |
1phaser neg sweep & spread hi res.mp3 |
Filesize: |
654.41 KB |
Downloaded: |
792 Time(s) |
Description: |
 Download |
Filename: |
1phaser pos sweep & fade more res.mp3 |
Filesize: |
454.11 KB |
Downloaded: |
793 Time(s) |
Description: |
 Download |
Filename: |
1phaser pos sweep & spread.mp3 |
Filesize: |
313.62 KB |
Downloaded: |
751 Time(s) |
seraph
Editor
Joined: Jun 21, 2003 Posts: 12269 Location: Firenze, Italy
Audio files: 33
Posted: Tue Jun 16, 2009 4:11 pm Post subject:
davep wrote: | I think this thing sounds amazing! |
it does but how come the audio file is much longer than the example?  _________________ homepage - blog - forum - youtube
Quote: | The man that hath no music in himself, nor is not mov'd with concord of sweet sounds, is fit for treasons, stratagems and spoils; the motions of his spirit are dull as night and his affections dark as Erebus: Let no such man be trusted. - W. Shakespeare |
davep
Audio files: 10
G2 patch files: 73
seraph
Editor
Audio files: 33
Posted: Tue Jun 16, 2009 4:13 pm Post subject:
davep wrote: | complex growling distortion. |
holy cow  _________________ homepage - blog - forum - youtube
davep
Audio files: 10
G2 patch files: 73
Posted: Tue Jun 16, 2009 4:14 pm Post subject:
seraph wrote: | davep wrote: | I think this thing sounds amazing! |
it does but how come the audio file is much longer than the example?  |
That was my mistake, only the first clip is like that. There was an extra muted track in the same DAW project that was longer than the audio track and it caused the entire MP3 clip to be as long as the muted track. _________________ Dave Peck |
davep
Audio files: 10
G2 patch files: 73
davep
Audio files: 10
G2 patch files: 73
davep
Audio files: 10
G2 patch files: 73
davep
Audio files: 10
G2 patch files: 73
TekniK
Posted: Sun Jun 21, 2009 9:43 am Post subject:
This phaser sounds indeed very good.
What fx box did u use for the chorus and reverb Dave? |
mono-poly
Joined: Jul 07, 2004 Posts: 935 Location: Rotterdam, Netherlands
Posted: Sun Jun 21, 2009 4:14 pm Post subject:
Awesome Dave and Rob! |
davep
Audio files: 10
G2 patch files: 73
Posted: Sun Jun 21, 2009 5:43 pm Post subject:
TekniK wrote: | This phaser sounds indeed very good.
I used a Nord G2 Engine for the chorus and a Lexicon PCM70 for the reverb. _________________ Dave Peck |
terjewinther
Joined: Aug 31, 2004 Posts: 65 Location: Nesodden, Norway
Posted: Sat Jun 27, 2009 2:19 pm Post subject:
Re: Wonderful new phase shifter module |
So when & where will this module be available? |
davep
Audio files: 10
G2 patch files: 73
Posted: Mon Jul 06, 2009 11:45 am Post subject:
terjewinther wrote: | So when & where will this module be available? |
Sorry for the late response, I was in China on a business trip from June 26 until today and was not checking this site.
The module should be available now. I posted some comments about it on another site and some folks over there have already contacted him to arrange purchase. You can contact Rob directly and he can provide all the info:
rhordijk ( AT ) xs4all (DOT) nl _________________ Dave Peck |
russma
Posted: Mon Aug 10, 2009 9:23 am Post subject:
I don't even have a dotcom system, and I want this phaser.
Nice going, Rob. |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Fri Jan 22, 2010 9:43 am Post subject:
I've got to bump this thread because this is the sweetest phaser I've ever heard. Ever.  |
stuadh
Posted: Tue Mar 02, 2010 1:00 pm Post subject:
I want!!!
I have contacted Rob about costs and availability and I eagerly await his response. I have just started to make the leap from Eurorack to 5U format after discovering Moon Modular's stuff.
Yours Aye
Stuadh |
davep
Audio files: 10
G2 patch files: 73
stuadh
Posted: Tue Mar 02, 2010 11:25 pm Post subject:
I hope Rob doesn't mind me saying this, but rather than have lots of people ask the same question, the Dual Phaser costs 385 euro plus shipping and is available in MOTM and Dotcom format. He requests payment on completion of the module and at the moment, there is a four to five week wait. I'm sure Rob reserves the right to change any of these facts and this is just a guide - please contact him directly if you are interested.
I'm going to start saving (having just spent all my pocket-money on Moon Modular stuff).  |
demi
Posted: Wed Apr 28, 2010 11:24 am Post subject:
Subject description: with A-sys or Doepfer |
would there be any connection issues racking this up alongside any A-sys or Doepfer set ups out of curiosity ?? the clips i've heard sound great.. |
stuadh
Posted: Wed Apr 28, 2010 2:26 pm Post subject:
DotCom and MOTM (5U) are both very different formats to Eurorack (3U) (A Sys and Doepfer). Look here for a starter http://www.modularsynth.com/chart.html. My synth has been exclusively Eurorack until now but I've recently prepared an 8 space row for MOTM format. In addition to the physical different, there is a voltage difference (±12V v ±15V). I have a homemade cabinet with lots of space so conversion was easy, but you would not be able to convert a Doepfer or a Sys case without doing some serious metalwork and electronics. |
davep
Audio files: 10
G2 patch files: 73
Posted: Wed Apr 28, 2010 5:24 pm Post subject:
stuadh is correct, you'll need a +15/-15/+5V power supply for Dotcom or MOTM format modules. There are several cheap ways to do this, like the Dotcom QPS2 described here:
http://www.synthesizers.com/q101.html . Note that this power supply has Dotcom style DC power connectors and Rob's module has MOTM style, so you can use an MOTM power system or a cheaper Dotcom system like in the link along with the simple & cheap MOTM 995 power adapter board, shown here:
http://www.synthtech.com/testcart/forums.html?main_page=product_info&cPath=67&products_id=183
...but I think maybe your question was just about patching the two different module types together, and if that's the case, then it's simple. You'll need adapters to go from the tiny minijacks of euro stuff to the 1/4" jacks on the phaser, but it will work fine. _________________ Dave Peck |
emdot_ambient
Posted: Thu Apr 29, 2010 8:52 am Post subject:
Dose this phaser require a +5V power supply? Most dotcom and MOTM don't need the 5V supply, only some of the modules with more digital components like sequencers, clock dividers, MIDI-CV converters and the like require the triple supply. |
