  bingsatellites Mostly Ambient
 Forum index » DIY Hardware and Software » Musical Interfaces
x/y touch controller?
Page 1 of 1 [4 Posts]
moodchannel
PostPosted: Sat Jul 18, 2009 7:15 pm    Post subject: x/y touch controller? Reply with quote  Mark this post and the followings unread
I am looking for an x/y touch controller... er... a 2D ribbon? like a kaoss pad? but I'm looking for just the component so I can hook it up to a miditron or phidget board.
any ideas? googling for this turns up a lot of red herrings...
hway23
PostPosted: Sat Jul 18, 2009 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sparkfun has some neat resistive touch elements. here is one of them. http://www.sparkfun.com/commerce/product_info.php?products_id=8977
dshay
PostPosted: Sat Aug 25, 2012 6:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've played around with a 4 Wire resistive touchscreen. You could hook one of these up to a microcontroller (arduino...) and output a MIDI signal on the micro's UART.
4 Wire Resistives are interesting, you have to toggle your X and Y readings to change from Inputs to Outputs. There's tutorials out there that are Arduino based for using these, I don't know if anybody has canned code for the MIDI application however.
Audio files: 151
PostPosted: Sat Aug 25, 2012 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a midi library for the arduino. http://arduino.cc/playground/Main/MIDILibrary Or, you could create your own midi code.
While the arduino is certainly one route, I assume there are other options as well.
Steve
Niio1
