paugui
Joined: Jun 28, 2008 Posts: 555 Location: Marinha Grande, Portugal / Oslo, Norway
G2 patch files: 37
Posted: Tue Jul 28, 2009 2:01 pm Post subject:
Reliability Problems with Blofeld Keyboard |
Hi
I was wondering if the Waldorf Keyboard has the same reliability problems the Desktop version has?
Also, is the actual OS stable enough?
Thanks in advance,
Best regards
Paugui |
BobTheDog
Posted: Tue Aug 04, 2009 8:16 am Post subject:
My desktop isn't unreliable! |
pizzamon
Posted: Thu Aug 06, 2009 11:29 am Post subject:
Mine is...just this afternoon I finally picked it back up, hoping for the best. I used midi. I started building a nice patch, and decided to use the velocity modifier. Assigned velocity to (w) modifier and poof! the whole fucking patch was lost. I get frustrated every time I pick it up. |
BobTheDog
Posted: Thu Aug 06, 2009 11:45 am Post subject:
Are you using USB midi? |
pizzamon
Posted: Thu Aug 06, 2009 7:26 pm Post subject:
I was using an edirol usb to midi adapter at the time...I have been using it for many years with no problems. I usually use midi to midi though. I get instabilities all the time with the blofeld. |
BobTheDog
Posted: Thu Aug 06, 2009 11:09 pm Post subject:
HI,
I meant the actual usb port on the back of the blofeld.
I have found it can be a bit dodgy if using the blofeld usb port to send midi while editing patches but very reliable using a midi cable. I spoke to Waldorf about it and they said it was because they run the UI on the blofeld at a low priority when midi is being received on the usb.
Maybe you have a bad unit, have you spoken to Waldorf maybe they can replace it.
Andy |
pizzamon
Posted: Fri Aug 07, 2009 5:17 am Post subject:
Thanks and all. There is nothing wrong with my unit though...it's just dodgy. Shame really. I understand that it's waldorf's intro back into the market. It's a cheap build is the problem. Either the dsp, or the on board memory, or something in the blo is of a cheaper variety which has proven itself unreliable. Hopefully they are making good money on it, and can bring out a proper stromberg. |
BobTheDog
Posted: Fri Aug 07, 2009 5:28 am Post subject:
As I said before mine is totally reliable, the build quality on mine is also good. |
Joined: Apr 24, 2009 Posts: 2492 Location: Bristol UK
Audio files: 495
Posted: Fri Aug 07, 2009 10:11 am Post subject:
There have been some reports of unreliable parts on the unofficial waldorf mailing list, but it is difficult to say exactly how widespread those problems are. Most users are definitely happy.
As for the software, be sure that waldorf is working on it. They have had some problems in the past, and still have some bugs here and there, but in that respect they are not much different from the vast majority of hardware manufacturers. The wonderful thing about waldorf is that they have unique ideas and a great sounding synth.
For the price of a New Blofeld some corners have to be cut. IMO it is a very potent machine, and stands up well compared to similar synths in the same price range, both as far as hardware and software is concerned.
My advice is buy it new, not second hand. If there are any problems you will be covered by the warranty and can send it back in the unlikely case of something going wrong. _________________ Muied Lumens Sub Forum
Bandcamp |
Synthluver
Posted: Tue Aug 18, 2009 5:48 pm Post subject:
I wanted the keyboard version (back in december). I had to settle with the desktop version, which was a good thing in a way since the keyboard only appeared in store 6 months later.
I was not all that pleased at first, but the more I use it the more I find it has a few good tricks up it's sleeve. Only things bothering me is the high noise level on headphone output and no midi out. The diminutive interface (only 7 knobs) combined with its graphic LCD are first class... much easier to use and effective than I expected.
However, I went into shock when I finally put my hands down on the key version. Incredibly beautiful, a feel of overall sturdiness, good material and workmanship hardly matched by any other synth I have seen with the exception of the Little Phatty. Still, the keys of the Blofeld are superior IMO to that of the Phatty.
Unfortunately, this does not say anything about long term reliability, but the feel was so good and I was so impressed, I am probably get one before the year is over.
Hope this helps. |
Synthluver
Posted: Tue Aug 18, 2009 5:49 pm Post subject:
Edit : Ooops, double post (sql error, server has vanished)...deleted... it's all into message above
But I will add the I have not had reliabilities issues or major bugs so far. Maybe I am not the heaviest user around, but i am a happy camper with it. |
Wan
Joined: Mar 31, 2004 Posts: 259 Location: Netherlands, Ugchelen
G2 patch files: 46
Posted: Wed Aug 19, 2009 12:23 am Post subject:
Same story here, i first had a Blofeld desktop, but have changed that for a Blofeld keyboard. And indeed that are nice keys to me. The sample option is a bit basic and slow in communication, but it does work allright. So no problems for me:) _________________ Grtz Wan |
fky
Posted: Thu Aug 20, 2009 2:03 am Post subject:
Unfortunately I ecountered a display issue on my desktop unit, the text will fade after several minutes' warming up. I saw a famous musician in HK had the same issue on its new bought blofeld keyboard. Now I am asking for warranty repair. Hopefully it is just a exceptional case.
Germany should produce the best quality in the world. My micro Q & access are very solid though after so many years. ... _________________ http://soundcloud.com/fkyfkyfky |
