Resonator Section of Polymoog ...
Page 1 of 6 [129 Posts]
Interested?
Interested
95%
 95%  [ 43 ]
Not intersted
4%
 4%  [ 2 ]
Total Votes : 45
jhaible
PostPosted: Mon Feb 16, 2009 4:44 pm    Post subject: Resonator Section of Polymoog ...
Subject description: ... as a standalone module?
Evaluating this ...
JH.
Complex filter courves - a lot more complex than your ordinary parametric EQ, I'd say ...
 Filesize:  103.58 KB
 Viewed:  762 Time(s)
fluxmonkey
PostPosted: Mon Feb 16, 2009 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
the curves look cool, but i've never played a polymoog so i'm not sure what the sound would be like. is this at all akin the korg ps3000 resonator that was cloned by fonik? samples, or pointers to samples of the thing in use would help.
b
www.fluxmonkey.com
jhaible
PostPosted: Tue Feb 17, 2009 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
b
I don't know about fonik's clone, but I can assure you the Polymoog Resonators are very different from the PS3100 Resonators that I cloned, once upon a time. Smile
I don't habe any samples yet.
But I'm sure there are Polymoog demos out there, that feature the resonator section.
Does anybody have any links?
JH.
numbertalk
PostPosted: Tue Feb 17, 2009 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm building Fonik's PS3100 resonators as well but would be curious to hear/learn more about these and how they differ from the Korg resonators. Could be on board for this.
machine.cuisine
PostPosted: Mon Mar 09, 2009 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in getting info on it...I have a Polymoog which has been completely taken apart.
I've thought about trying to take the Resonator section out and use it stand-alone, but I don't have any service docs.
guitarfool
PostPosted: Mon Mar 09, 2009 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
That wouldn't happen to be the MOTM 410, would it? Anyway, I agree that it's not the same as your plot for the Polymoog. If you decide to do it, I'm in for a couple Very Happy
mono-poly
PostPosted: Mon Mar 09, 2009 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I want Smile
Spratty
PostPosted: Mon Mar 09, 2009 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm rather curious about the polymoog resonator - I've read about the thing a few times on the web. Resonators in general sound interesting, but I'd be curious to know how this one sounds. As per JH's previous post, if someone has some clips or knows a link, I'd appreciate it (even if I don't buy a board!)
Spratty Wink
Electronicant
PostPosted: Wed Aug 05, 2009 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I´m interested too. Some of you may saw this post from Kenneth Elhardt: http://www.moogmusic.com/forum/post-55621.html#55621
Seems like a very nice module Smile
TekniK
PostPosted: Thu Aug 06, 2009 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
something like this ,yes but with 8 bands on one pcb. Very Happy
yusynth
PostPosted: Fri Aug 07, 2009 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Ken Elhardt 's just posted a video demonstrating the possibilities of this filter section :
http://www.youtube.com/v/_XUiJi5153Y
Yves
Electronicant
PostPosted: Fri Aug 07, 2009 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I was just about to post it Smile
Beautiful sounds!!
TekniK
PostPosted: Fri Aug 07, 2009 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
If only he could have switched of that verb then WE REALY could hear how this filter sounds,because a typical (dry) JP-8 brass sound does not sound like that at all...
Funky40
G2 patch files: 5
PostPosted: Sat Aug 08, 2009 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
yup, why allways "just" cloning ?
1 vote for 5 Bands, but i take it also with 8 Laughing , ................ or 3 Wink, or 12 Laughing
jhaible
PostPosted: Sat Aug 08, 2009 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll make it stackable. Buy 2 PCBs for 6 bands etc. No problem - its' DIY !!
JH.
TekniK
PostPosted: Sat Aug 08, 2009 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
great am in for some for sure
jhaible
PostPosted: Sun Aug 09, 2009 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've started making the PCB layout!
JH.
TekniK
PostPosted: Sun Aug 09, 2009 11:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Cool
you r brilliant
numbertalk
PostPosted: Mon Aug 10, 2009 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Woo hoo!
jhaible
PostPosted: Tue Aug 11, 2009 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
This was an easy one to layout.
And it will be an easy project to solder, this time!
And unexpensive, too. Depends on the potentiometers or sliders you're going to use. PCB will be 27 Euros as usual. Electronic
components will be very unexpensive. Potentiometers, enclosure etc will make the biggest part of the bill here.
I've painstakingly taken care to preserve the character of the original, using the same low slewrate opamps, MOSFET switches, and DC
bias (which results in very unsymmetric headroom) as the original.
You can use modern opamps instead, of course. And there is plenty of space to use whatever capacitors you like, in the filter
sections. No problem to go for a High End version with polystyrene caps and modern audio opamps, if you like. But you can - and I
will, for my self - just build it like the original.
Send me an email if you're interested in this. If I get enough "resonance", I will start a PCB run in a month or so.
(No audio demos yet - I must first have one prototype made for myself!)
JH.
 Filesize:  363.96 KB
 Viewed:  830 Time(s)
TekniK
PostPosted: Tue Aug 11, 2009 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
wunderbahr
yes am interested,will buy 2 or 3 pcb's
if u could tell whats going on the panel i can start designing already my frontpanels Cool
The Alison Project
PostPosted: Tue Aug 11, 2009 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in.
The Alison Project
www.thealisonproject.com
adambee7
PostPosted: Wed Aug 12, 2009 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
i'll have 2 for def please. Very Happy Very Happy
numbertalk
PostPosted: Wed Aug 12, 2009 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Email sent - count me in!
a100user
PostPosted: Wed Aug 12, 2009 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested too
Thanks
