  bingsatellites Mostly Ambient
audio to midi?
Page 1 of 1 [8 Posts]
laurentius
PostPosted: Sun Aug 16, 2009 11:07 am    Post subject: audio to midi? Reply with quote  Mark this post and the followings unread
hi there everybody!
i am curious if anybody has an idea about my following plan: i would love to triger clips/midinotes (in ableton live) via incoming audio (voice for instance). i don't really need audio pitch to corresponding midi pitch - much better could work something like different input volume creates different midi-events (some kind of accidental).
i thought that maybe my nord modular g2 (which i haven't used in ages and somehow forgot about how to program it) could help me with that. is there a way to plug my guitar or mic in and have my desired result? to not create midi chaos (in case there are six string ringing at the same time) i though of a kinf of theshold - below it no midi note being created, above it depending on the volume dirfferent midi notes...
do i sound realisitic? Wink
any hints highly appreceated!
lars
BobTheDog
PostPosted: Sun Aug 16, 2009 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
HI,
Have a look at:
http://electro-music.com/forum/viewtopic.php?highlight=guitar+midi&t=25395
laurentius
PostPosted: Mon Aug 17, 2009 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah thanks.
still this looks very complicated. all i need is some audio to cc that works more velocity-orientated without exact pitch tracking, you know.
laurentius
PostPosted: Tue Aug 18, 2009 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
ok folks,
i attached a simple patch explaining my needs. it is just made up very roughly. i just need your advise now concerning velocity control. it would be great to have different incoming velocities transforming into different midinotes. any ideas?
thanks alot,
laurentius
audio to cc.pch2
 Filename:  audio to cc.pch2
 Filesize:  1.33 KB
 Downloaded:  609 Time(s)
mush
PostPosted: Tue Aug 18, 2009 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
A couple of window-switches should do this job for you! Just rectify the signal first so it is just positive. Just put it in parallel after the envelope-follower.
Audio files: 211
G2 patch files: 92
PostPosted: Tue Aug 18, 2009 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or just pipe the EnvFollow output straight into the velocity input. Smile That's always positive. I also inserted a delay - there may be a little while before the signal reaches its peak amplitude, and <10 ms may go by unnoticed. I fiddled with the channel too for testing, you need to change it back to 1.
/Stefan
audio_to_cc_378_sbt.pch2
 Filename:  audio_to_cc_378_sbt.pch2
 Filesize:  1.38 KB
 Downloaded:  704 Time(s)
laurentius
PostPosted: Sat Aug 29, 2009 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your answers.
still needed: the midi note output shoul be influenced by the incoming velocities. like low velocitiy triggers midinote c, and high velocity triggers midinote d.
what also doesnt work for me yet is that a midisignal is sent constantly when there is audioinput. what i would need is a kind of "one shot" that only triggers once with each peak and then waits for a break before the next peak....
laurentius
x_x
PostPosted: Sat Aug 29, 2009 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
get pure data (open source version of maxmsp), and search for an object called "fiddle". that works for converting audio to midi... I believe it uses a fast fourier transform... for the velocities you will have to code it... or in this case draw the diagrams or whatever they call it with that program....
I think that's the easiest way.
The other way would be to code it from scratch using chuck, sc3, java ... babalablabalabalbala
cheers
Niio1
