Posted: Mon Aug 17, 2009 11:56 am Post subject:
adambee7 wrote: | yep! that's made my mind up. I'll def have 2. I've built four lpgs so two will have this I think. |
good to know. the response has been a little bit weak, seems there is not that much interest in a PCB for this. however it is summer time... anyways, i will order the 2nd prototype board soon (made some minor changes), build it, and then ask for interest in professional manufactured PCBs for this project.
meanwhile i will work on the SDS3 single voice PCB _________________
Tech Buddy at Random*Source |
janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
gwaidan
Joined: Mar 07, 2009 Posts: 53 Location: Sydney, Australia
Posted: Mon Aug 17, 2009 3:03 pm Post subject:
Just a question-are the mounting holes on the board the same width apart as on the 292c so it can piggyback on the board using a couple of spacers? It would be really cool if it didn't need a separate mounting bracket |
Junk Rhythm
Joined: Jan 07, 2008 Posts: 81 Location: San Francisco, CA
gwaidan
Posted: Mon Aug 17, 2009 7:33 pm Post subject:
I'd be up for at least two, possibly 6 |
Posted: Tue Aug 18, 2009 6:06 am Post subject:
gwaidan wrote: | Just a question-are the mounting holes on the board the same width apart as on the 292c so it can piggyback on the board using a couple of spacers? It would be really cool if it didn't need a separate mounting bracket |
that's the idea, and that's exactly how i did it. i am currently waiting for the exact data from thomas, since my prototype does not fit exactly (due to odd distance?). _________________
gwaidan
Posted: Tue Aug 18, 2009 6:34 am Post subject:
fonik wrote: | gwaidan wrote: | Just a question-are the mounting holes on the board the same width apart as on the 292c so it can piggyback on the board using a couple of spacers? It would be really cool if it didn't need a separate mounting bracket |
that's the idea, and that's exactly how i did it. i am currently waiting for the exact data from thomas, since my prototype does not fit exactly (due to odd distance?). |
Well in that case I'd be up for 6! |
intercorni
Posted: Wed Aug 19, 2009 3:07 am Post subject:
@Fonik: I take two! |
pcp2020
Posted: Wed Aug 19, 2009 2:10 pm Post subject:
Holy Crap! this thing sounds awesome!
being a newbie I dont really understand what this does but i do know I want one.
count me in for four. I have four 292 boards so i figure I should get four of your boards. |
TheAncientOne
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Posted: Fri Aug 21, 2009 8:26 am Post subject:
Lovely work Fonik. If you do go ahead with a run, I would like two.
Thanks _________________ Mike |
ach_gott
Posted: Thu Aug 27, 2009 9:09 am Post subject:
Updated for pre-order as listed by Matthias below: I am ordering 4. Last edited by ach_gott on Wed Sep 02, 2009 1:58 pm; edited 1 time in total |
kitsch-bent
Posted: Sat Aug 29, 2009 8:20 pm Post subject:
i'd be up for at least 6 of these (: |
haricots
Posted: Mon Aug 31, 2009 11:26 am Post subject:
Fonik, I'll take one for sure (maybe 2) if you promise to help us relative newbs out and supply a nice list of parts and wiring diagram so I don't screw it up. |
Posted: Mon Aug 31, 2009 12:21 pm Post subject:
sure!
the 2nd proto is supposed to arrive this week. i will build it up, test it, and then set pricing and a deadline for advance orders. so there is enough time for me to come up with nice building docs. _________________
Posted: Wed Sep 02, 2009 1:25 am Post subject:
the prototype is tested now and it works fine. you could mount it piggyback style on your TH LPG 292c PCB, even the mode switch pads are in the correct position, so one could use long pins instead of headers/cables to connect the boards.
however, i brought the actual switch terminals of the IC to pads, so this board could be used as gate controlled 3-pol on-off-on switch for other projects.
switching audio can always be a problem, i believe. so it is here: you might experience little pops when switching audio, depending on the signals you are switching. you will have experienced this with professional modules, too.
i will write up some building docs soon, boards should be available end of september.
i am taking advance orders until 16 SEP 09, 12:00 UTC
PRICING:
(under the assumption of minimum advance orders for 50+ PCBs):
PCB 7.-USD/5.-EUR
+ packaging & postage
deutschland: 2.-EUR
europe: 3.-EUR
worldwide: 1 PCB 4.-USD, more than 1 PCB 8.-USD[/b]
ChrisR
Joined: Feb 22, 2009 Posts: 24 Location: Dark side of the room
Posted: Wed Sep 02, 2009 2:27 am Post subject:
Great! I'll take two boards.
What's the "correct" way to order, Matthias? PM, email?
Chris |
Posted: Wed Sep 02, 2009 2:31 am Post subject:
there is no incorrect way actually. email, PM, post here... whatever serves you the best. _________________
magman
Joined: Feb 04, 2009 Posts: 363 Location: Liverpool, UK
Posted: Wed Sep 02, 2009 4:04 am Post subject:
Fonik,
Can you out me down for 2 boards as well please.
Regards
Magman |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Wed Sep 02, 2009 4:38 am Post subject:
oh what the hell matthias i'll go for 4 instead of 2 boards please.
cheers man
adam
monokinetic
Posted: Wed Sep 02, 2009 9:15 am Post subject:
Hi matthias,
great news, thanks for another great project
Please put me down for three PCBs.
David |
clickmrmike
Posted: Thu Sep 03, 2009 7:07 pm Post subject:
Yep, two here as well!
clickmrmike |
jojjelito
Joined: Jun 27, 2007 Posts: 50 Location: Stockholm, Sweden
Posted: Fri Sep 04, 2009 1:59 am Post subject:
Hi Matthias, two PCBs for me please! This will make the LPG top dog for chopping things up. Thanks for a great mini-project |
gwaidan
Posted: Sat Sep 05, 2009 5:14 pm Post subject:
Six for me! |
LektroiD
Joined: Aug 23, 2008 Posts: 1018 Location: Scottish Borders
Posted: Tue Sep 15, 2009 7:30 am Post subject:
2 for me please _________________ LektroiD |
creatorlars
Posted: Tue Sep 15, 2009 8:33 am Post subject:
I'd like 2 as well, please! |
