<on air> Muied Lumens Frequencies
Proto type boards from Radio Shack any good ?
Page 1 of 1 [4 Posts]
acidblue
PostPosted: Thu Aug 20, 2009 6:31 pm    Post subject: Proto type boards from Radio Shack any good ? Reply with quote  Mark this post and the followings unread
Any body use these proto type boards from Radio Shack?
http://www.radioshack.com/product/index.jsp?productId=2102845
http://www.radioshack.com/product/index.jsp?productId=2102844
They seem like a cross between a Perf and Vero board
They have copper fills that the Perf boards don't, but not all holes/fills are connected.
The 276-150 has 2 rails going down the center that are connected, that you could
use for power.
The 276-149 doesn't have any connected holes/fills, this seems like this would
eliminate the need to scour out connected fills that you would have to do on Vero.
or at lest reduce the amount you would have to do.
They also have this one for IC's
http://www.radioshack.com/product/index.jsp?productId=2103799
They seem like a good idea and have good reviews.
Just want to know if anyone here has any experience with them?
droffset
PostPosted: Thu Aug 20, 2009 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The one in the first link looks great because it resembles a breadboard, easy transition from the breadboard to the prototype.
This is the one I get locally, which is pretty similar:
http://www.dse.com.au/cgi-bin/dse.storefront/4a8dfccf12580fb2273fc0a87e0106ec/Product/View/H5605
hway23
PostPosted: Thu Aug 20, 2009 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have used all three boards, and they are ok quality and will definately work for most projects, but the second link perf boards I have had pads* lift. (probably due to poor soldering techniques back in the day.)
Rolling Eyes
But now I use allelectronics.com strip boards because they are much easier to use and a little bit better quality imo.
Link -> http://www.allelectronics.com/make-a-store/category/455/Perf-Boards/1.html
Good Luck!
Inventor
Audio files: 267
PostPosted: Fri Aug 21, 2009 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I have used the one that droffset links with good success. As mentioned, the transition from breadboard to protoboard is easy. I used to see large card-slot sized boards with that pattern but I haven't seen them that way in a while.
