Inventor
Audio files: 267
Inventor
Audio files: 267
Inventor
Audio files: 267
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
Inventor
Audio files: 267
Inventor
Audio files: 267
Posted: Tue Aug 25, 2009 3:29 pm Post subject:
OK folks, I'm ready for a design review. The attached files are the schematic and board files for the BSG board, or BSKS as I've been calling it. I'd appreciate if anyone could review them and let me know what you think.
Thanks,
Les
Description: |
Download |
Filename: |
BSKS4.sch |
Filesize: |
154.67 KB |
Downloaded: |
916 Time(s) |
Description: |
Download |
Filename: |
BSKS4.brd |
Filesize: |
56.36 KB |
Downloaded: |
891 Time(s) |
_________________ "Let's make noise for peace." - Kijjaz |
Dan Lavin
Audio files: 21
Posted: Wed Aug 26, 2009 5:49 am Post subject:
Les,
these are Eagle files? Just checking.
regards, Dan |
Inventor
Audio files: 267
Posted: Wed Aug 26, 2009 5:54 am Post subject:
antman49443 wrote: | Les,
regards, Dan |
Yes they are Eagle CAD files.
toad008
Joined: Sep 01, 2007 Posts: 30 Location: maryland/usa
Posted: Wed Aug 26, 2009 6:56 pm Post subject:
yo inventor |
dude i like the pictures! Where do i apply to be your lab studio slave? haha serious ... droooollllll
Toadie |
Dan Lavin
Audio files: 21
Posted: Wed Aug 26, 2009 7:15 pm Post subject:
Les,
If you can wait until the weekend, I'll see what I can do to review. Too many pushy customers are driving me crazy right now. State Machine can vouch for my pcb work.
regards, Dan |
Joined: Jan 31, 2003 Posts: 18198 Location: Durham, NC
Audio files: 213
Posted: Wed Aug 26, 2009 9:20 pm Post subject:
On your boolean sequencer, what effect would using binary counters instead of decimal counters? _________________ --Howard
my music and other stuff |
Inventor
Audio files: 267
Posted: Thu Aug 27, 2009 10:10 am Post subject:
antman, sure I'm happy to wait for the weekend, I'm a little burned out after all that work.
Howard, This thing needs a binary counter, yes. I changed the counter from a 4017 decade counter to a 4040 binary counter for just that reason, it's what I need for the job. I had misunderstood and thought that a 4017 was a 10-bit binary counter, but now that I've seen it used in the baby 10, I realize my mistake.
To all, some issues I am concerned with are: will the new LEDIL really work? I have just thought it out and not constructed it. Also will the Karplus-Strong circuit work with this very simple implementation? I'm concerned about the HF pulsed input burst not doing the job and also the AC and DC bias are tied together. Maybe we can work out these details somehow and make this thing the DIY project it really should be!
Inventor
Audio files: 267
Posted: Thu Aug 27, 2009 10:11 am Post subject:
Re: yo inventor |
toad008 wrote: | dude i like the pictures! Where do i apply to be your lab studio slave? haha serious ... droooollllll
Toadie |
Toad, you are so funny, great sense of humor!
Audio files: 213
Posted: Thu Aug 27, 2009 5:32 pm Post subject:
I usually drive LEDs with a buffer chip of some sort. It looks like your circuit can present some very large and quite variable loads on the counter. It's been a while since I worked with CMOS, but if I remember correctly, most logic devices aren't designed to drive loads. They look to drive very hi Z lines. _________________ --Howard
Inventor
Audio files: 267
Posted: Thu Aug 27, 2009 7:35 pm Post subject:
mosc wrote: | I usually drive LEDs with a buffer chip of some sort. It looks like your circuit can present some very large and quite variable loads on the counter. It's been a while since I worked with CMOS, but if I remember correctly, most logic devices aren't designed to drive loads. They look to drive very hi Z lines. |
Hi Howard, you're right, and Dan noticed it too (sent me a message in pm). So now I need a work-around or else I go to surface mount or else get a new CAD tool. Good thing I asked for a design review!
wmonk
Joined: Sep 15, 2008 Posts: 528 Location: Enschede, the Netherlands
Audio files: 15
Posted: Fri Aug 28, 2009 3:57 am Post subject:
Isn't panel mounting the LEDs and switches an option? You save a lot of space on the PCB if you do so. Or make 2 PCBs, one for the LEDs and switches, and one for the other parts, en connect them with a few ribbon cables. |
Inventor
Audio files: 267
Posted: Fri Aug 28, 2009 4:47 am Post subject:
wmonk wrote: | Isn't panel mounting the LEDs and switches an option? You save a lot of space on the PCB if you do so. Or make 2 PCBs, one for the LEDs and switches, and one for the other parts, en connect them with a few ribbon cables. |
Yes, I had thought of making the single board as a panel mount dealie, but your idea of two boards with one as a panel mount seems more interesting now. The idea is to make it a stand-alone board or panel mount, your choice. If I have to add buffers for LEDs and more parts for Karplus-Strong, then I'll definitely need two boards. Thanks for the suggestion, wmonk.
Inventor
Audio files: 267
Posted: Sat Aug 29, 2009 1:20 am Post subject:
Actually, another option is to do separate Boolean Sequencer and Karplus-Strong boards. This alternative makes some sense because modular synthesis folks might want to make only a K-S or only a BS board for panel mounting.
Certainly a K-S board does not seem to exist and with a whole board for K-S, we could have lots of features like pseudo-random noise burst and other input styles, filter options, etc. Besides, I do like the idea of an extended board pair for the stand-alone version rather than a sandwich board pair.
Just tossing ideas around. Clearly the board needs major revisions and I'm looking forward to reading more design review comments.
Inventor
Audio files: 267
Posted: Sat Aug 29, 2009 2:23 am Post subject:
Also, another thing I'm not too hot about with the LEDIL is that it shows inverted bits. You see blinky lights according to your switch selections, but the lights are "on" when the logic is "off", so you only get a note when nothing blinks. This is counter-intuitive, though it still makes for a nice light show.
I'd prefer to just do it with standard LED outputs on resistors, and with a dual board approach that would work.
droffset
wmonk
Audio files: 15
Posted: Sat Aug 29, 2009 3:43 am Post subject:
Inventor wrote: |
I like the idea of a separate K-S board. You can easily add an interesting option for the modular guys: filter replacement. You add a standard 1-pole low pass filter to the board, and one can 'replace' this filter with switching sockets. I think there are many possibilities here to get all kinds of crazy sounds using different filters.
Inventor wrote: | Also, another thing I'm not too hot about with the LEDIL is that it shows inverted bits. You see blinky lights according to your switch selections, but the lights are "on" when the logic is "off", so you only get a note when nothing blinks. This is counter-intuitive, though it still makes for a nice light show. |
Inverters are the solution. Or use LED bargraph displays. (http://futurlec.com/LED/LEDBARRED.shtml) They're easy to fit and save a lot of space. |
Posted: Sat Aug 29, 2009 4:51 am Post subject:
Jesus H Christ Les!!@!
Are you criminially insane or what?!?!
Love your work dude.
It's gonna be a week or two before I work out what the hell is goin on here!! _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Sun Aug 30, 2009 2:50 am Post subject:
Thanks wmonk, that's just the LED bargraph part I've been looking for!
I also like the notion of a separate KS board, and with a filter option - whoot! This will go into the plans for sue!
JovianPyx
Audio files: 224
Posted: Sun Aug 30, 2009 3:21 pm Post subject:
How many strings will the KS board support? Is it polyphonic? _________________ FPGA, dsPIC and Fatman Synth Stuff
Inventor
Audio files: 267
Posted: Sun Aug 30, 2009 4:57 pm Post subject:
ScottG wrote: | How many strings will the KS board support? Is it polyphonic? |
Hey ScottG, actually it's monophonic. It only does one string.
