softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
Funky40
G2 patch files: 5
Posted: Wed Jul 29, 2009 1:08 pm Post subject:
you messed here something up softfin
thanks for posting the picture.
Hope to get some comments on the motm panels |
Joined: Jan 31, 2003 Posts: 18198 Location: Durham, NC
Audio files: 213
Posted: Thu Jul 30, 2009 9:31 am Post subject:
Funky40 wrote: | you messed here something up softfin |
With my unlimited moderator powers I accidentally messed up Softfin's message while trying to reply to it.
_________________ --Howard
my music and other stuff |
Funky40
G2 patch files: 5
Posted: Thu Jul 30, 2009 10:13 am Post subject:
thanks for clarification mosc. |
softfin
Posted: Thu Jul 30, 2009 10:18 am Post subject:
mosc wrote: |
No prob. |
Funky40
G2 patch files: 5
Posted: Thu Aug 06, 2009 5:37 pm Post subject:
Hello Jürgen,
I like to have the mic Gainstage, but i will use the FS-1A mostly with modularsynth signals.
how should i setup input1 to have both ? ( the aux input is preserved for the Feedbackpath. seems to be very useful ). |
jhaible
Posted: Thu Aug 06, 2009 11:33 pm Post subject:
Funky40 wrote: | Hello Jürgen,
Add two 22k resistors between the input jack and the board input.
Compare http://www.jhaible.de/fs1a/jh_fs1a_schematics_board_2.pdf with the input of my old Frequency Shifter: http://www.jhaible.de/tonline_stuff/hjfs5_ia.gif and you get the idea.
The old one didn't have a Gain pot; it hat a 3-pole, 4-position rotary switch instead. In two of the four positions, the 22k resistors are in the circuit, like a "Pad" function in a mixing console. Of course you can combine that Pad function with a gain potentiometer, or just build the input circuit from the old FS-1.
Or you can omit the whole SSM Preamp and use the two pins (GND and middle pin) of the "Mic Level" board connector as a second High-Level input. Look at http://www.jhaible.de/fs1a/jh_fs1a_schematics_board_2.pdf - it's the same as the AUX input, after that connector!
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
Funky40
G2 patch files: 5
Posted: Sat Aug 08, 2009 8:02 am Post subject:
jhaible wrote: | Add two 22k resistors between the input jack and the board input.
JH. |
ahh , i was not aware that this is "only" a Levelshift.
Thanks Jürgen |
Funky40
G2 patch files: 5
Posted: Mon Aug 10, 2009 10:12 am Post subject:
In Feedback mode, which output is for Deep mode, sum or diff ?
( i like to have the FB switch matching with the Sum and diff outs ) |
jhaible
Posted: Mon Aug 10, 2009 10:27 am Post subject:
Funky40 wrote: | In Feedback mode, which output is for Deep mode, sum or diff ?
Doesn't matter. Both change their function when the modulation oscillator runs backwards. And both sound interesting!
Funky40
G2 patch files: 5
Posted: Mon Aug 10, 2009 10:42 am Post subject:
sorry, the question was anyway put wrong. total confusion, but i got it:
1. i make SUM and Diff outs. I like to have the position of the switch matching with the sockets.
Which out relates to which position in normal ( positiv) mode ? Sum = up ?
2. Modcan has a Feedback output on his module.
would it make sense to make a Feedback output ? ( i'm now very short in space, but maybe i could manage it to plöace another socket ) |
jhaible
Posted: Mon Aug 10, 2009 12:13 pm Post subject:
Funky40 wrote: | sorry, the question was anyway put wrong. total confusion, but i got it:
Sum is *down* - when the Oscillator runs "forward", i.e. sin is sin and cos is cos.
Sum is *up* - when the Oscillator runs "backwards", i.e. sin is -sin and cos is still cos.
Funky40
G2 patch files: 5
Posted: Mon Aug 10, 2009 9:34 pm Post subject:
Thank you Jürgen. |
janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
Posted: Sun Aug 16, 2009 5:43 am Post subject:
HELP!
My FS-1a is not working as expected. I could need some help ( or somebody in Europe i can ship my FS1a to debug/fix it).
Problem (when doing calibration):
Step1 works
Step2 fails.
Any ideas / testing helps ? I do got a dual Channel Oscilloscope as well as a Voltmeter (and of course soldering stuff) ?
Any help greatly appreciated! _________________ Homepage - http://www.czmok.de
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me |
Funky40
G2 patch files: 5
Posted: Tue Aug 18, 2009 11:32 am Post subject:
R9 on main Board:
is this 39K or 43K ?
on the PCB is written 43K.
on the overlay it is written 39K.
On the schematic 43K.
ok i guess 43K is right |
jhaible
Posted: Tue Aug 18, 2009 11:43 am Post subject:
Funky40 wrote: | R9 on main Board:
Right.
Funky40
G2 patch files: 5
Posted: Sat Aug 29, 2009 3:07 pm Post subject:
Trimmer R127,
I soldered it in reverse according to the layout,
can i leave it ?
( guess it just changes the direction in which to turn, right ? ) |
Funky40
G2 patch files: 5
Posted: Sat Aug 29, 2009 3:15 pm Post subject:
I'm allready in progress of wiring the module.
I have two Jacks for each output.
Usually i solder a bridge instead of the Outresistor to the PCB ( respectivly have to desolder the outresistor... )
putting then the outresistors directly to the jacks.
I'm not shure what i should do on this Board.
As the outresistors are 620R, i thought i maybe just could add another outresistor with 330R to each outjack to decouple those.
Or would it be an Idea to replace the 620R with a 330R and then add the mentioned 330R per outjack ?
( this way i have no blank bridge, but i'm not shure if 330R is enough to decouple the dual-ouitjacks from each other )
and thanks for all the previous help. |
jhaible
Posted: Sun Aug 30, 2009 12:17 am Post subject:
You can switch the cw and ccw end of a trimmer, as long as you keep the middle pin where it belongs.
Output resistors: These are merely there to prevent the opamps from oscillation due to capacitive load. If you use short, *unshielded* wire from the board to the jacks, you can place 620R directly at each jack.
Funky40
G2 patch files: 5
Posted: Mon Aug 31, 2009 9:33 am Post subject:
jhaible wrote: |
JH. |
I have 12cm wire. dual wire with ground going "around" the signal ( like a old telephone cable.
I kept the 620R on Board and added a 330R to each outjack.
Hope thats ok.
Thanks again Jürgen ! |
Funky40
G2 patch files: 5
Posted: Mon Aug 31, 2009 9:52 am Post subject:
Beeing in "calibrationmode" allready:
( finished wiring yesterday )
Calibration step 1 was not good.
Turning R28 Osc Level Balance changes the Osc Level of both waveforms ( same levelshift ). One Wave has less level.
The one Waveform with less Level has a nice sine allready.
It seemed that later calibration did not changed anything to this sinewave.
I went thru till step5 then and found now out that U6( TL071 near Tempco) is becoming very Hot.
Too hot to keep a finger on it long.
Guess there's something wrong
( i checked all IC Pins( sockets) with a Voltmeter before putting the ICs in, but doe to having Voltages on many Pins on board1,
i could not see if something is wrong.
It looked somewhat logic as some ICs were same as others )
( checked also the Board by Eye with a Halogenlamp ) |
jhaible
Posted: Mon Aug 31, 2009 3:10 pm Post subject:
Funky40 wrote: |
Definitely!
Funky40
G2 patch files: 5
Posted: Mon Aug 31, 2009 3:22 pm Post subject:
jhaible wrote: | Funky40 wrote: |
Definitely!
JH. |
ok, U6 had a TL 072 in there.
now it's the question how big the risk is that this caused other damage.
I checked all the ICs after putting them in btw. but
i'll see... |
jhaible
Posted: Mon Aug 31, 2009 3:27 pm Post subject:
Funky40 wrote: | jhaible wrote: | Funky40 wrote: |
Definitely!
JH. |
i'll see... |
If supply voltages are still ok everywhere, it's likely that just hat single chip was damaged.
Funky40
G2 patch files: 5
Posted: Mon Aug 31, 2009 5:20 pm Post subject:
I went thru calibration inclouding step 5
At step 5 i got 3V out for the comp output. Trimmer is in endposition.
Not measured any Frequenzys, so i could have been aside.
( The calibratioon was also more meant to to be able to see if the module works. )
so far the 3V cmp-out seem to be the only Problem. |
