 Forum index » Instruments and Equipment » Reaktor
Audio Tables
Page 1 of 1 [3 Posts]
"Minks"
PostPosted: Tue Sep 01, 2009 8:13 am    Post subject: Audio Tables
Subject description: Sample Rate or Control Rate?
I was trying to generate the sine/cosine of an audio signal, so I used the sin/cos module.
The signal sounded heavily aliased - I realised it was because this module deals in events, so its sample rate is very low compared to an audio one.
I then tried the same with an Audio Table loaded with a single cycle of a sine wave (1Hz), but it still gives the same aliased sound.
Is there a way around this?
http://www.myspace.com/abattleshipcalledquotminksquot
Chet
G2 patch files: 35
PostPosted: Tue Sep 01, 2009 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
An audio table loaded with a sine wave will not alias unless the frequency is very high. If there's low-freqency aliasing going on, there's something else misbehaving.
"Minks"
PostPosted: Tue Sep 01, 2009 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I opened the file up again and realised I had Audio to Event convertors on the inputs to the macro (a legacy from when I tried it with the Sin/Cos module).
I'm an idiot sometimes. It works fine now.
emSynth
