 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
5.4 seconds looper
Page 1 of 1 [3 Posts]
Burp
G2 patch files: 7
PostPosted: Fri Aug 21, 2009 12:51 pm    Post subject: 5.4 seconds looper
Subject description: A looper 'pedal' with max 5,4sec
An easy to use looper, like AKAI's headrush.
Loop length is as long as you press RECORD, with a max of 5,4 secs.
How to use:
Press the RECORD button as long as you like (max 5,4s). At the moment you release the button, the recorded loop starts playing.
Press RECORD again to take a new loop (with a new length).
Press START to stop or start the loop, you can also set the volume with the knop above it.
You can change the speed of the loop if you like.
Many thanks to Tim Kleinert for his non drifting sampling circuit !!!
http://electro-music.com/forum/topic-18566.html
If you put the patch in Slot D (or change the midi sends to the correct slot) the speed and start/stop knobs will reset.
There seems to be one problem, if you listen carefully to the loop, half of the time the sound is somewhat distorted. I assume it is the part that comes from the delay that sits in the FX area. Someone has an idea to overcome this?
5.4s Looper (D).pch2
 Filename:  5.4s Looper (D).pch2
 Filesize:  4.24 KB
 Downloaded:  772 Time(s)
if you don't know where you're going, you will allways arrive
iPassenger
G2 patch files: 78
PostPosted: Wed Sep 09, 2009 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is cool been meaning to try it out for ages, nice that you got the the loop to kick straight in after recording.
iP (Ross)
Burp
G2 patch files: 7
PostPosted: Sat Sep 12, 2009 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I'm working on a slightly better version, when it's ready i will post it.
