AUTUMNAL EQUINOX 2009 STREAMING CONCERT Sept.19 Sat.
Page 4 of 7 [167 Posts]
shanemorris
Audio files: 83
PostPosted: Fri Aug 28, 2009 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
FKY
unlike a physical concert... there is no gear to move, or staging to set up between acts. It takes less than one minute to switch between performers.
So, each performer is essentially given 29 minutes to play. Because this is an international event, we have to adhere closely to the schedule... so it is crucial that each artist be on time in the chatroom at least 60 minutes before their set. Of course, we would hope that musicians/listeners will hang out for the entire event. Very Happy
A quick sound/streaming check will be done for each performer during the set preceding.
This check entails that the musician(s) are connected to our server, audio is present, volume levels are sufficient, and overall "quality" of the stream/audio mix sounds good.
This sound/streaming check will not cover EQ, Compression, EFX, etc. The shape of the sounds are entirely up to the performers.
ElectroCasa
Audio files: 22
PostPosted: Fri Aug 28, 2009 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, shaping up real nice !!! Thanks Shane for putting myself and NEOREV back to back Cool
Of course I will be available for switching duties. Thus far, radio op duties are Jan, Shane, and myself? If so, were you whipping up the stream op schedule? If I am wrong, then please correct me. Very Happy I will assume for now we will be using the usual interface for switching? Sorry for all the questions .... Embarassed I knwo there was talk in private Stream-Op's sub-forum about using a different interface.
This will be fun !!!
Bill
shanemorris
Audio files: 83
PostPosted: Fri Aug 28, 2009 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Stream Operatives:
Jan, Bill, Les, and myself... plus Paul, Rob, and Jason as well
Yeah ... was going to put an OP schedule together this weekend. Very Happy
ElectroCasa
Audio files: 22
PostPosted: Fri Aug 28, 2009 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Stream Operatives:
Nice to see the participation Very Happy OK then, will await the schedule, thanks !
Bill
PS: I will be listening in on the radio shows this evening so see you in the chat Wink
Bill
Muied Lumens
Audio files: 204
PostPosted: Fri Aug 28, 2009 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
shanemorris wrote:
Stream Operatives:
I'm quite excited about AE09, and happy to put some work in too! Smile
Muied Lumens Base Star
Inventor
Audio files: 256
PostPosted: Sat Aug 29, 2009 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I've decided to play something a little bit upbeat and active to kind of wake folks up before Howard's final message and performance. Something cheerful, sort of a pick-me-up kind of show for all to enjoy...
Les
Audio files: 69
PostPosted: Mon Sep 07, 2009 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Quick question.....
Will the event run as one complete broadcast show, tuning in to E M radio once or will we have to re-tune in per artist start time, with a few "please stand by's" as we do on a friday night where 3 shows run together ???
www.myspace.com/skrogproductions
Audio files: 22
PostPosted: Mon Sep 07, 2009 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
For now, the streaming event will run like it does on Friday's but for 12 hours instead of 4. So, you will get those PSB's Wink
Howard has been working hard to change this but ran into some technical issues with some trans-coding software he has been working with. I am optimistic that by winter, shows will be more "fluid" with no, or very little, gaps between performances.
Bill
Audio files: 69
PostPosted: Mon Sep 07, 2009 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Bill, a few psb's will not dampen the spirits Smile
mono-poly
PostPosted: Mon Sep 07, 2009 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I made a time mistake people Sad
I really need to switch with someone from the start.
16:00 Plastixman
16:30 FKY
17:00 Alphacore
17:30 Muied Lumens
18:00 Mr. Cold
18:30 Acoustic Interloper
19:00 Ambiencellist
Because i must go to work at 20:00 GMT Sad
Anyone wanna do a set at 20:00 ?
Muied Lumens
Audio files: 204
PostPosted: Mon Sep 07, 2009 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I can switch if you want. Smile
mono-poly
PostPosted: Mon Sep 07, 2009 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok Rob.
That's perfect man!
Thank you!
Muied Lumens
Audio files: 204
PostPosted: Mon Sep 07, 2009 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problem. Smile
Audio files: 150
PostPosted: Tue Sep 08, 2009 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've modified the posters to take account of the change in running order
I replaced the ones I uploaded originally, but the forum software seems to have changed the names, so any links will now be broken Sad
If anyone has posted any elsewhere linking directly back to the forum the links will need updating
portrait version is now
http://electro-music.com/forum/phpbb-files/emautumnalequinox09_01_139.jpg
landscape version with times is now
http://electro-music.com/forum/phpbb-files/emautumnalequinox09_02_131.jpg
music | adventures in sound
Ganzha
PostPosted: Sat Sep 12, 2009 8:10 pm    Post subject: Ganzha
Subject description: I would love to participate!
1.Preferred Start Time (Please use GMT/UTC): between 12:00pm and 15:00am (GMT+6)
2.Name (stage name if there is one): Ganzha
3.Location: Almaty, Kazakstan
4.Real name: Vadim Ehrlich (Ganzha)
5.Username: Ganzha
6.One or Two Paragraph Description: in live electronic sound paintings
by self made modular synths - in style Electroabsurd
www.myspace.com/loonmoon
Ganzha in Vienna Fest this summer
 Filesize:  82.46 KB
 Viewed:  182 Time(s)
http://ziart.kz
Jason
PostPosted: Sat Sep 12, 2009 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
l
Jez,
I noticed an odd horizontal line on http://electro-music.com/forum/phpbb-files/emautumnalequinox09_01_139.jpg wasn't sure if it was intentional or got corrupted.
Thanks,
J
Jason
PostPosted: Sat Sep 12, 2009 9:22 pm    Post subject: Re: Ganzha
5.Username: Ganzha
Not sure if the event is full yet or not. We always try to accommodate, though it is getting a bit down to the wire so we need to see what the schedule is like and check with the others. Since you haven't streamed before you also would need to be prepared to test this in advance as well with us in the chat room.
Jason
Audio files: 150
PostPosted: Sun Sep 13, 2009 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Jez,
Thanks,
J
no idea what happened there, have re-uploaded
new link is
http://electro-music.com/forum/phpbb-files/emautumnalequinox09_01_194.jpg
shanemorris
Audio files: 83
PostPosted: Sun Sep 13, 2009 5:43 am    Post subject: Re: Ganzha
5.Username: Ganzha
Greetings Ganzha!
Its been a while since I last heard from you! Hope things are well in Kazakstan. Wink
We are currently at full capacity on performances.
You are first on the list of alternates at this time. There is always a strong possibility that someone will not be able to play for whatever reason.
So, there is a potential likelihood that we can squeeze you in!
I would appreciate it if you could confirm your available time in GMT calculated by yourself, in order to avoid any problems or errors with timing, time zones. Very Happy
ElectroCasa
shanemorris
Audio files: 83
PostPosted: Mon Sep 14, 2009 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
WOO HOO!!!
Just 5 days away now!!!
party! party time! beer Theremin respect dancing Ohm... truus afro dasz batman spiderman Shocked I smell a rat wave wave wave wave wave
ElectroCasa
fky
PostPosted: Mon Sep 14, 2009 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Look forward to the show. alien
just wonderign whether the comming New Year 2010 celebration would be the next big event?
http://soundcloud.com/fkyfkyfky
shanemorris
Audio files: 83
PostPosted: Mon Sep 14, 2009 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes undoubtedly we will be having the traditional New Year's Eve Streaming concert. Very Happy
Also looking at beginning to have smaller weekend events in the future.
ElectroCasa
ambiencellist
PostPosted: Tue Sep 15, 2009 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
excellent smilie party you started there Shane Cool
Looking forward to it !
www.ambiencellist.com
www.myspace.com/ambiencellist
www.virb.com/ambiencellist
Jason
PostPosted: Tue Sep 15, 2009 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Calling all streamers that have not tested their connection.
Please do so ahead of time and not wait until the last minute.
Thanks
shanemorris
Audio files: 83
PostPosted: Tue Sep 15, 2009 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Claire! Laughing
Will you be around on Saturday some? or AFK?
ElectroCasa
