shanemorris
Audio files: 92
Posted: Fri Aug 28, 2009 3:54 am Post subject:
FKY
unlike a physical concert... there is no gear to move, or staging to set up between acts. It takes less than one minute to switch between performers.
So, each performer is essentially given 29 minutes to play. Because this is an international event, we have to adhere closely to the schedule... so it is crucial that each artist be on time in the chatroom at least 60 minutes before their set. Of course, we would hope that musicians/listeners will hang out for the entire event.
A quick sound/streaming check will be done for each performer during the set preceding.
This check entails that the musician(s) are connected to our server, audio is present, volume levels are sufficient, and overall "quality" of the stream/audio mix sounds good.
This sound/streaming check will not cover EQ, Compression, EFX, etc. The shape of the sounds are entirely up to the performers. _________________ ElectroCasa |
Posted: Fri Aug 28, 2009 6:57 am Post subject:
Wow, shaping up real nice !!! Thanks Shane for putting myself and NEOREV back to back
Of course I will be available for switching duties. Thus far, radio op duties are Jan, Shane, and myself? If so, were you whipping up the stream op schedule? If I am wrong, then please correct me. I will assume for now we will be using the usual interface for switching? Sorry for all the questions .... I knwo there was talk in private Stream-Op's sub-forum about using a different interface.
This will be fun !!!
Bill |
shanemorris
Audio files: 92
Posted: Fri Aug 28, 2009 8:14 am Post subject:
Stream Operatives:
Jan, Bill, Les, and myself... plus Paul, Rob, and Jason as well
Yeah ... was going to put an OP schedule together this weekend. _________________ ElectroCasa |
Posted: Fri Aug 28, 2009 12:03 pm Post subject:
Yeah ... was going to put an OP schedule together this weekend |
Nice to see the participation OK then, will await the schedule, thanks !
Bill
PS: I will be listening in on the radio shows this evening so see you in the chat
Bill |
Joined: Apr 24, 2009 Posts: 2492 Location: Bristol UK
Audio files: 495
Posted: Fri Aug 28, 2009 3:39 pm Post subject:
shanemorris wrote: | Stream Operatives:
Yeah ... was going to put an OP schedule together this weekend. |
I'm quite excited about AE09, and happy to put some work in too! _________________ Muied Lumens Sub Forum
Bandcamp |
Inventor
Audio files: 267
Posted: Sat Aug 29, 2009 12:32 am Post subject:
I've decided to play something a little bit upbeat and active to kind of wake folks up before Howard's final message and performance. Something cheerful, sort of a pick-me-up kind of show for all to enjoy...
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Posted: Mon Sep 07, 2009 10:18 am Post subject:
Quick question.....
Will the event run as one complete broadcast show, tuning in to E M radio once or will we have to re-tune in per artist start time, with a few "please stand by's" as we do on a friday night where 3 shows run together ??? |
Posted: Mon Sep 07, 2009 10:40 am Post subject:
Quote: | Will the event run as one complete broadcast show, tuning in to E M radio once or will we have to re-tune in per artist start time, with a few "please stand by's" as we do on a friday night where 3 shows run together ???
For now, the streaming event will run like it does on Friday's but for 12 hours instead of 4. So, you will get those PSB's
Howard has been working hard to change this but ran into some technical issues with some trans-coding software he has been working with. I am optimistic that by winter, shows will be more "fluid" with no, or very little, gaps between performances.
Bill |
Audio files: 155
Posted: Mon Sep 07, 2009 10:54 am Post subject:
Thanks Bill, a few psb's will not dampen the spirits |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Mon Sep 07, 2009 11:07 am Post subject:
I made a time mistake people
I really need to switch with someone from the start.
16:00 Plastixman
16:30 FKY
17:00 Alphacore
17:30 Muied Lumens
18:00 Mr. Cold
18:30 Acoustic Interloper
19:00 Ambiencellist
Because i must go to work at 20:00 GMT
Anyone wanna do a set at 20:00 ? |
Audio files: 495
mono-poly
Posted: Mon Sep 07, 2009 3:20 pm Post subject:
Ok Rob.
That's perfect man!
Thank you! |
Audio files: 495
Joined: Feb 04, 2005 Posts: 2844 Location: Nottingham, UK
Audio files: 275
Ganzha
Audio files: 27
Jason
Joined: Aug 12, 2004 Posts: 466 Location: Los Angeles, CA. USA
Posted: Sat Sep 12, 2009 9:17 pm Post subject:
modulator_esp wrote: | I've modified the posters to take account of the change in running order
I replaced the ones I uploaded originally, but the forum software seems to have changed the names, so any links will now be broken
If anyone has posted any elsewhere linking directly back to the forum the links will need updating
portrait version is now
http://electro-music.com/forum/phpbb-files/emautumnalequinox09_01_139.jpg
l |
Jez,
I noticed an odd horizontal line on http://electro-music.com/forum/phpbb-files/emautumnalequinox09_01_139.jpg wasn't sure if it was intentional or got corrupted.
Thanks,
J |
Jason
Posted: Sat Sep 12, 2009 9:22 pm Post subject:
Re: Ganzha Subject description: I would love to participate! |
Ganzha wrote: | 1.Preferred Start Time (Please use GMT/UTC): between 12:00pm and 15:00am (GMT+6)
2.Name (stage name if there is one): Ganzha
3.Location: Almaty, Kazakstan
4.Real name: Vadim Ehrlich (Ganzha)
5.Username: Ganzha
6.One or Two Paragraph Description: in live electronic sound paintings
by self made modular synths - in style Electroabsurd
www.myspace.com/loonmoon
_________________ |
Not sure if the event is full yet or not. We always try to accommodate, though it is getting a bit down to the wire so we need to see what the schedule is like and check with the others. Since you haven't streamed before you also would need to be prepared to test this in advance as well with us in the chat room.
Jason |
Audio files: 275
shanemorris
Audio files: 92
Posted: Sun Sep 13, 2009 5:43 am Post subject:
5.Username: Ganzha
_________________ |
Greetings Ganzha!
Its been a while since I last heard from you! Hope things are well in Kazakstan.
We are currently at full capacity on performances.
You are first on the list of alternates at this time. There is always a strong possibility that someone will not be able to play for whatever reason.
So, there is a potential likelihood that we can squeeze you in!
I would appreciate it if you could confirm your available time in GMT calculated by yourself, in order to avoid any problems or errors with timing, time zones. _________________ ElectroCasa |
shanemorris
Audio files: 92
Posted: Mon Sep 14, 2009 3:38 am Post subject:
WOO HOO!!!
Just 5 days away now!!!
fky
Posted: Mon Sep 14, 2009 4:19 am Post subject:
Look forward to the show.
just wonderign whether the comming New Year 2010 celebration would be the next big event? _________________ http://soundcloud.com/fkyfkyfky |
shanemorris
Audio files: 92
Posted: Mon Sep 14, 2009 4:32 am Post subject:
Yes undoubtedly we will be having the traditional New Year's Eve Streaming concert.
Also looking at beginning to have smaller weekend events in the future. _________________ ElectroCasa |
ambiencellist
Jason
Posted: Tue Sep 15, 2009 6:05 am Post subject:
Calling all streamers that have not tested their connection.
Please do so ahead of time and not wait until the last minute.
Thanks |
shanemorris
Audio files: 92
Posted: Tue Sep 15, 2009 8:13 am Post subject:
ambiencellist wrote: | excellent smilie party you started there Shane
Looking forward to it ! |
Thanks Claire!
Will you be around on Saturday some? or AFK? _________________ ElectroCasa |
