VCA PCB Layout link down
Page 1 of 1 [10 Posts]
Cardinen
PostPosted: Tue Sep 15, 2009 6:42 am    Post subject: VCA PCB Layout link down Reply with quote  Mark this post and the followings unread
first post here, but i've read this forum sooo many times... Smile
I'm not able to open the PCB layout of the yusynth VCA.
Please, can you fixes it ??
Tank's Yves, your projects are just incredible!
yusynth
PostPosted: Thu Sep 17, 2009 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Which link are you mentionning ? I checked the PCB file links and all is working fine here.
May be there was traffic jam on the server when you tried? Try again and let me know if you still encounters difficulties I will email you the PCB file.
Yves
Cardinen
PostPosted: Thu Sep 17, 2009 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Yves,
I've try so many times since 2 weeks, but is always the same, and only whit the VCA layout (the PCB ready to print for p'n'p). I know, is strange, but this is the only one i can't open; maybe is a my problem.
Please if you send me it i'll be very glad.
unpobubba (at) yahoo.it
TANK'S
magman
PostPosted: Thu Sep 17, 2009 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yves,
I've just check as well, out of interest.
For the VCA PCB Design I just get a filename displayed (http://www.yusynth.net/Modular/Commun/VCA/VCA-PCB.jpg) rather than the image being displayed. All other images on the page appear to display correctly.
Regards
Magman
yusynth
PostPosted: Thu Sep 17, 2009 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
magman wrote:
Yves,
Regards
Magman
Weird... I copy-pasted the url in your message into my web browser and after a few seconds the image popped up normally !
May be something wrong in the encoding of the image that makes it not compatible with some browsers. I will create a new file and see if the problem is still there.
Yves
yusynth
PostPosted: Thu Sep 17, 2009 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
OK I created a new file, can you retry and let me know if it works now. In the meantine I email the file to Cardinen
Yves
Cardinen
PostPosted: Thu Sep 17, 2009 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I still have the problem whit firefox but not whit safari (i'm on mac).
Weird Rolling Eyes
However tank's for the mail and for the support.
...is soldering time.. Laughing
magman
PostPosted: Thu Sep 17, 2009 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yves,
Never thought of the potential browser issues, just tried it in IE and the link works, but it still doesn't work in Firefox.
I don't profess to be an expert in HTML, but I just had a quick look at the code via Firefox and I spotted one difference that may be relevant.
The following is the source for the VCA frame in question
Code:
style="text-align: center; vertical-align: middle; color: rgb(255, 255, 255); width: 150px;">
            <center><b>PCB design</b><br>
            <br>
            <span><a href="../../Commun/VCA/VCA-PCB.jpg"><img alt="" src="../../Commun/VCA/VCA-PCB-thumb.gif"></a></span><a href="../../Commun/STEINERVCF/VCF-PCB-3096.jpg"><br>
            </a><a href="../../Commun/VCA/VCA-PCB.jpg"><img alt="" src="../../../images/loupe.gif"></a><br>
            <br>
            </center>
            </td>
            <td
For comparison, here's the similar source code for the Dual Pulse Delay frame:
Code:
 style="text-align: center; vertical-align: middle; color: rgb(255, 255, 255); width: 170px;">
            <br>
            <a href="../../Commun/PULSEDELAY/pulsedelay-PCB.jpg"><img alt="" src="../../Commun/PULSEDELAY/pulsedelay-PCB-thumb.gif"></a><br>
            <a href="../../Commun/PULSEDELAY/pulsedelay-PCB.jpg"><img alt="" src="../../../images/loupe.gif"></a></center>
            </td>
            <td
It looks like a href for another image has snuck into the code for VCA and apparently the other browsers are ignoring it.
Hope this helps clear the issue.
Regards
Magman
yusynth
PostPosted: Thu Sep 17, 2009 11:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
magman wrote:
Yves,
Regards
Magman
Thanks a lot Magman, I did not check the html code since it was working on all the browser I am using. I will remove this hidden reference to a phantom image and it should fix the problem.
Regards
Yves
Yves
Cardinen
PostPosted: Fri Sep 18, 2009 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, now it work !
mps board
