Controlling Macbeth M3X via midi out G2 engine
Page 1 of 1 [16 Posts]
Zone
PostPosted: Fri Sep 18, 2009 6:07 am    Post subject: Controlling Macbeth M3X via midi out G2 engine
Subject description: Using the G2 as a sequencer for external synths
Hello,
I am trying to control my Macbeth M3X synth via the midi output of a Clavia G2 Engine. I would like to use the G2 Engine as an external sequencer and employ the huge (sequencing and modulation) possibilities of the G2 the control the M3X. Due to inexperience I can't get it to work properly. I have used a very basic sequencer patch (please see picture) from the manual to start with, and I have set the midi channel on both devices on 16: I have done this on my M3X with is built-in Kenton and on my G2 (synth settings, midi send + CtrlSend module channel on 16), but it doesn't work. I hope someone here could give me some advice concerning what I might be forgetting or doing wrong? Thanks in advance!
Best wishes, Z.
 Filesize:  120.87 KB
 Viewed:  5327 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Fri Sep 18, 2009 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Basically this should just work, can you post the actual patch you work on?
Zone
PostPosted: Fri Sep 18, 2009 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell thank you for your reply! Here is the actual (basic) patch I used as a starting point. The midi receive channel of the Macbeth M3X is set to 16.
External Control.pch2
 Filename:  External Control.pch2
 Filesize:  1.12 KB
 Downloaded:  438 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Fri Sep 18, 2009 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
The patch should be OK ... in Synth Settings (in the NM editor) you have checkboxes for Controllers one for Receive and one for Send, you checked those?
Audio files: 150
PostPosted: Fri Sep 18, 2009 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
your patch doesn't appear to be sending any gate information
music | adventures in sound
Audio files: 116
G2 patch files: 317
PostPosted: Fri Sep 18, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
The patch uses a CTRL send module, which will send whenever the input value changes.
Zone
PostPosted: Fri Sep 18, 2009 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell wrote: The patch should be OK ... in Synth Settings (in the NM editor) you have checkboxes for Controllers one for Receive and one for Send, you checked those?
Yes (please see attachment). If the settings of the G2 are correct, then it must be the Macebth M3X I guess
 Filesize:  86.4 KB
 Viewed:  5284 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Fri Sep 18, 2009 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks good to me, one thing you can try ... you use midi channel 16 which also is the global channel, maybe try to turn global off, for a test at least (off = 16 + 1).
Audio files: 150
PostPosted: Fri Sep 18, 2009 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I always use a Note Send module for external sequencing, it needs a gate
Here's a sequencer I setup for external control of my SE-1
I had to put an Env module in to extend the gate signal as the standard one was too short
midi_seq_F#m.pch2
 Filename:  midi_seq_F#m.pch2
 Filesize:  1.55 KB
 Downloaded:  714 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Fri Sep 18, 2009 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing which makes sense if you want to play notes ... I assumed the control send module to be intentional here, but maybe that was wrong.
it needs a gate
Yup.
Audio files: 150
PostPosted: Fri Sep 18, 2009 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
True, I just sort of assumed that's what the original poster meant, but I may be wrong Wink
Zone
PostPosted: Fri Sep 18, 2009 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
modulator_esp, thank you very much for your patch! I hooked an LFO into the clock input of the level sequencer and everything works just fine now! Thanks for all the help!
Audio files: 150
PostPosted: Fri Sep 18, 2009 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
obviously there are a few extra bits in there like the key quantise and offsets you might not need, but it's a start
Audio files: 116
G2 patch files: 317
PostPosted: Fri Sep 18, 2009 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
But you were not Cool
Audio files: 150
PostPosted: Fri Sep 18, 2009 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile
cappy2112
PostPosted: Sun Sep 20, 2009 4:21 pm    Post subject: Re: Controlling Macbeth M3X via midi out G2 engine
Zone wrote:
Hello,
Best wishes, Z.
Another option, although expesive (but probably more satisfying)..
http://electro-music.com/article.php?t=9118
Niio1
