nobody
Posted: Thu Sep 17, 2009 2:02 pm Post subject:
Triton Extreme sampling Subject description: Extreme issues. Extreme fun. |
I can't quite seem to get sampling working on my Triton Extreme. I know I'm getting a signal into it, because I can trigger the ADC overload warning, but the record level meters show nothing.
My setup: Mic plugged into Mackie Onyx 1640. Aux send 1 goes to Triton in 1. Master gain is turned up, master send 1 knob up, send 1 knob on mic channel is up. Whether I have the Triton set to line or mic doesn't change anything.
Perusing the manual, but it looks like I shouldn't need to do anything more to get the signal to show up in the meters on the Triton's screen in sampling mode.
nobody
Posted: Thu Sep 17, 2009 2:10 pm Post subject:
Aha. I used the auto setup and then you have to *drum roll* press the record button before a level will appear in the meter.
EdisonRex
Audio files: 172
Posted: Thu Sep 17, 2009 2:47 pm Post subject:
That's sorted then. _________________ Garret: It's so retro.
nobody
Posted: Thu Sep 17, 2009 3:23 pm Post subject:
Yeah.
But!
What's the deal with saving samples? I don't see a way to save samples except to external media (I say this keeping in mind the manual is not an easy read). Convert MS to program doesn't save the actual sound data. I don't have a flash card, and I'm NOT going to load sample data every time I want a patch I created from a sample.
I HAVE to be missing something. There HAS to be a way to save my sample on-board, just like any modern, competent sampler does. No way is Korg THAT retarded. |
nobody
Joined: Apr 24, 2009 Posts: 2492 Location: Bristol UK
Audio files: 495
Posted: Thu Sep 17, 2009 7:25 pm Post subject:
Did you check if the answer is there?
Doh! I posted in that thread, not this one! _________________ Muied Lumens Sub Forum
Bandcamp |
Joined: Feb 04, 2005 Posts: 2845 Location: Nottingham, UK
Audio files: 276
Posted: Fri Sep 18, 2009 2:06 am Post subject:
From the Korg product page for the Triton extreme it looks like the internal RAM is not battery backed up and that all samples have to be save to external CF or microdrive
Hopefully you will be able to play them direct from this drive, rather than have to load them into the internal memory first _________________ Jez
music | adventures in sound | gear for sale |
nobody
Posted: Fri Sep 18, 2009 7:11 am Post subject:
Yeah. I caved on my threat against never loading samples.
So I'm looking for a micro-drive. According to the manual, I can do the most with a MD (more than a CF or HD). Any recommendations on a brand/model? The manual says max=1GB. |
Audio files: 276
Posted: Fri Sep 18, 2009 10:11 am Post subject:
I'd be surprised if the manual doesn't offer suggestions, most stuff I have that uses SD or CF cards has a list of cards that are known to work _________________ Jez
nobody
Posted: Fri Sep 18, 2009 10:17 am Post subject:
Not that I could see. They left it very general. I'll email my contact at my local supplier. He's pretty knowledgeable. |
Audio files: 276
nobody
Audio files: 276
Posted: Fri Sep 18, 2009 2:05 pm Post subject:
Amazon isn't always cheaper
If you get the other you could always make a donation to electro-music.com via Paypal _________________ Jez
nobody
Posted: Fri Sep 18, 2009 2:09 pm Post subject:
modulator_esp wrote: | Amazon isn't always cheaper |
Holy crap, you don't say!
modulator_esp wrote: | If you get the other you could always make a donation to electro-music.com via Paypal |
I might do that. |
Audio files: 276
nobody
Posted: Fri Sep 18, 2009 2:29 pm Post subject:
Does the Ultra II work with the Extreme? I didn't see it in the list Korg put out. |
Audio files: 276
Posted: Fri Sep 18, 2009 2:43 pm Post subject:
The 1Gb Ultra II is listed, can't say for sure if the 2Gb one will also work
but then the list only includes cards up to 1Gb so may be out of date if a later update allows the use of 2Gb cards _________________ Jez
nobody
Posted: Fri Sep 18, 2009 5:27 pm Post subject:
Thanks. I appreciate your chiming in. |
