 Forum index » Instruments and Equipment » DSI Synths
Dave Smith Instruments - tetra 4 (new synth)
Page 1 of 1 [6 Posts]
wave
PostPosted: Sat Sep 19, 2009 9:10 am    Post subject: Dave Smith Instruments - tetra 4 (new synth)
Subject description: some questions / users here ?
Hi forum,
I`m very interested in the new tetra-synth by DSI - I see the web-videos and read the pdf-manual ... I think the tetra is worth the price.
Question to tetra-users: I plan to use the synth without the editor (I`m not working with winXP) - is it possible to edit all kinds of parameter, especially the sequencer from the front panel ? Or there are some parameters I can`t use/change without the editor ?
Thanks for your help !
wave ...
BobTheDog
PostPosted: Wed Sep 23, 2009 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm pretty sure that you need the editor to have full edit ability, email DSI about it or look at the manuel http://www.davesmithinstruments.com/downloads/docs/Tetra_Manual_v.1.1.pdf
dorremifasol
Audio files: 6
G2 patch files: 47
PostPosted: Wed Sep 30, 2009 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I owned the Mopho, and I suppose the Tetr4 is almost the same in editing.
You can edit all the parameters from the control surface, without exception, but it's not easy or comfortable.
Albert
wave
PostPosted: Thu Oct 01, 2009 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Meanwhile I`ve read the manual and it seems that it is possible to edit the whole unit without restrictions (incl. the sequencer).
Yes - this seems to be not very comfortable - unfortunately.
Maybe I`ll run XP on a second pc (only for the editor) - I have to think about that ...
Thanks for the tips & info.
renegadebliss
PostPosted: Tue Oct 13, 2009 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
What about using a midi controller instead? You can find a BCR2000 for $70 - $80 used, which is much cheaper then a second copy of Windows XP Smile
wave
PostPosted: Tue Oct 20, 2009 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
"What about using a midi controller instead? You can find a BCR2000 for $70 - $80 used, which is much cheaper then a second copy of Windows XP"
Maybe a good idea - but I think this isnt comfortable and needs a lot of time to match all the parameters to midi-cc ...
I have already a second notebook (for my NM G1) - so I will update it to win xp and run the editor - I think thats the most comfortable way in my situation.
Niio1
