OS/Editor repository
Page 2 of 2 [44 Posts]
Goto page: Previous 1, 2
Static Motion
PostPosted: Mon Apr 20, 2009 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Where can I find 1.40 for osx ?
Oli
PostPosted: Mon Apr 20, 2009 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
gomidas wrote:
Old Mac version are here : http://www.macmusic.org/software/view.php/lang/fr/id/2825/
If anybody want them... Wink
Hi Static Motion. If you are able to verify the files provided at the site linked to above, would you please upload them to this thread?
Good good study, day day up!
gomidas
G2 patch files: 6
PostPosted: Mon Apr 20, 2009 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
>>> OSX PPC <<< Nord Modular G2 Editor v1.40
+ G2 Synth Update v1.40
MAC INTEL SHOULD USE IT FOR G2 SYNTH OS v1.40 UPDATE...
IT IS MORE STABLE THAN v1.62 Embarassed
...You can use Mac INTEL G2 Editor v1.62 with OS v1.40, they work well together. Wink
Best
Gomi
NordModularG2_V140.dmg
OSX PPC Nord Modular G2 Editor 1.40
+ G2 Synth update v1.40
 Filename:  NordModularG2_V140.dmg
 Filesize:  7.13 MB
 Downloaded:  566 Time(s)
Oli
PostPosted: Mon Apr 20, 2009 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
+ G2 Synth Update v1.40...i
So the files linked to won't work with current Intel Macs?
Perhaps someone here has a copy of the appropriate files, backed up somewhere?
gomidas
G2 patch files: 6
PostPosted: Tue Apr 21, 2009 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Intel Mac G2 Editor v1.62 @ Clavia http://www.clavia.se/main.asp?tm=Support&clsm=Downloads
>>>DON'T USE SYNTH OS UPDATE V1.62, ONLY THE EDITOR<<<
BobTheDog
PostPosted: Tue Apr 21, 2009 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not the synth update?
Static Motion
PostPosted: Tue Apr 21, 2009 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Because it can corrupt internal memory patches !
http://electro-music.com/forum/post-240360.html#240360
doctorno
G2 patch files: 8
PostPosted: Thu Oct 15, 2009 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much for this advice. Now with Synth OS 1.4 and Editor 1.62 it seems that my G2 works again. The editor broke down every few minutes if it worked at all, when I had Synth OS 1.62 installed.
Neon Sega
PostPosted: Thu Oct 15, 2009 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's great i can cure it! Last month I've had a lot of patching and had some freeze affairs. I've minded on some XP or OS X causes, but I see I was mistaken. Thank you, community! I'm on 1.4+1.62Editor know.
nicolaschenard
PostPosted: Tue May 11, 2010 12:31 am    Post subject: Re: OS/Editor repository
Subject description: Repository of old versions of OS, editor, and USB driver
Oli wrote:
I wondered if it may be worthwhile storing the 1.40 versions online here. I
thank you so much for posting OS 1.4 Smile
right now i'm trying to get back from my buggy 1.62 to the 1.4
the probleme is :
the 1.40 updater says : "current statuts : no nord modular connected" so i can't apply the update, whereas the 1.62 updater recognizes the g2 perfectly.
i tryed on windows 7 and xp, both in 64 bits. could it work if i try the 1.4 update on a 32 bits system?
help anyone? Wink thank you Nicolas
Xp
PostPosted: Wed Apr 06, 2011 12:12 pm    Post subject: Re: OS/Editor repository
the probleme is :
I also have the most problem.
tell me please - how to get back to OS version 1.4? I installed Editor 1.4 and ran UpDate, but this program does not see the G2. No connection. Although UpDate 1.6 works well
goinz
PostPosted: Mon Jun 13, 2011 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
please respond to the last both threads... i also can not rollback to 1.4, no chance. i get rid of that usb trouble with g2 engine (os 1.62).
i tried alot troubleshoting on 4 differnent computers win7 or xp, latop or desktop, all doesnt run propper.
Oli
PostPosted: Mon Jun 13, 2011 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm guessing no one has done this successfully. Have you contacted Clavia?
goinz
PostPosted: Tue Jun 14, 2011 3:02 am    Post subject: Reply with quote  Mark this post and the followings unread
ok folks... after a frustrating 12 hours "g2 engine must work" session yesterday with 5 different computers and a bottle of wine i got the silly solution. (The g2 engine wasnt in use for more then 1 year because i was really sad about the connection dropouts.)
After 8 hours testing on 4 PC's with winxp and win7 and several reinstallation of all drivers and editor versions, i had the situation that my g2 engine works on no PC anymore so i was 1 second before throwing it out of my window.
But then comes the BAAMM. I took a shorter usb cable (dont know if that was important) and I gave Windows Vista a chance and i took my girlfriends notebook running 2.16 usb and 1.62 editor. It was working fine with no dropouts after 1hour test. Getting her notebook was not the best way for the future, so i put again from her vista laptop the os 1.62 into the g2 engine. I dont know why but I did it.
Then I took my (cleaned up from all clavia driver and Software waste, registry etc.) winxp sp2 laptop again, putting 1.62 and 2.16usb on it and now its running!!!! -since 3 hours without any dropout.
isnt it stupid???
p.s.: It was the first time it makes me happy that my girlfriend has a Windows Vista Laptop running.
goinz
PostPosted: Tue Jun 14, 2011 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
grrr.... 5 minutes after writing this I put the running g2 engine back on its old place on my table and then i got the first connection dropout. Restarting all and it works again. Reinserting the usb cable brings nothing because my winxp laptop says "unknown device". For me it looks a bit like a usb problem in the g2 engine chip.
One note may be interisting for someone, I have an extra laptop to have the editor and the g2 engine running. I dont use my music computer for the G2 engine usb connection. Only midi is connected to the g2 engine from my music PC.
Damn... while writing this i get the 2nd dropout....
drumfish
PostPosted: Thu Oct 18, 2012 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
i sent a mail to clavia asking if they think of an other update or a bug fix release ... i got : discontinued product but we think about every & the lot of request we've had about the g2 ... apparently they don't leave aside the g2 ... fingers crossed
LektroiD
PostPosted: Sat Mar 16, 2013 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Best
Gomi
This doesn't work... I can't connect the Nord, it says "No Nord Modular G2 connected" on the updater... So, I switch the G2 off and on and says "Found Nord Modular G2", but nothing happens... The "Update" button is greyed out and the only option is to Quit... When I do that I'm back to square 1 saying it is not connected...
How do I 'update' the OS from 1.62 to 1.40 on an Intel Mac?
*ADDENDUM*
I updated the OS to 1.40 using my MacBook Pro (I don't know why the Mac Pro wouldn't see it)... However, the patch will still not load on editor 1.62...
LektroiD
mrdos
PostPosted: Thu Aug 13, 2015 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Best
Gomi
*ADDENDUM*
Hey friend, could you tell me how you downgraded the G2 OS to 1.40 using your Macbook Pro? Was this when OS X still supported Rosetta? Looks like it was 2013 so I thought support was dropped at that time. The only 1.40 updater I can find is for PowerPC, so I cannot run it.
I am stuck at 1.62 because the 1.40 Updater (nor the Editor) in Windows XP (in Parallels) cannot "see" the G2 (though Windows sees it, and the driver from Clavia is installed).
Gothboy
PostPosted: Wed May 17, 2017 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
What about the Mac version for Micro modular? Is it still just this http://www.nordkeyboards.com/downloads/legacy/nord-modular or is there now an update to take it to Mountain Lion at least?
Apple Mac Pro 3.1 2.88 GHz. Intel Xeon Quad
16 GB Ram
10.8.5/El Capitan
Novation SL49/Remote Zero
Mopho Desktop, Nord Lead 2, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland D-50, Alesis QS6, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
