testing your filter/vca's
Page 1 of 1 [11 Posts]
sunny pedaal
Audio files: 12
PostPosted: Thu Nov 18, 2004 3:32 pm    Post subject: testing your filter/vca's Reply with quote  Mark this post and the followings unread
i made this patch when experimenting with the boundaries of myA6.
it seemed that there were big diffenerences between the different filter/vca chips. how exactly it works i'm not sure of, however changing some of the chips solved the "problem".(adjusting the filterfeedback per voice also reduced the differences)
*just play the patch and eventually monitor the different voices by :global/voxmon.*
094 testfiltvca.syx
simple testpatch for filter/vca's with high resonance/fb demand
 Filename:  094 testfiltvca.syx
 Filesize:  2.29 KB
 Downloaded:  270 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Sat Nov 20, 2004 4:13 am    Post subject: envelops Reply with quote  Mark this post and the followings unread
today is saterday ,so no new patch (by the way where are yours patches, just drop one and let us enjoy them too )
instead of a patch some, previously made, grafic picture of the different envelope slopes of the a6 ( nice for above the bed or anyother wall)
as comparison i also incuded a grafic of the roland analog system100m. as you can see lin. or exp. are best suited for attack and log1 or log2 for decay and release when reproducing the system100 envelopes. these are what i use mostly for my analog patches b.e. the crumar ds2 / analogsynth default patch on this site.
A6, grafic representation of whitenoise with Attack or Decay set on ca 0.5 sec
(for comparising:rightunder :2 examples of roland modular system 100m decay)
 Filesize:  175.39 KB
 Viewed:  6844 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Sun Nov 21, 2004 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i forgot to mention that infact the envelops of the A6 can be too fast !
for a normal analog synth a minimumvalue of 6-8ms mostly suits better.
sunny pedaal
Audio files: 12
PostPosted: Fri Nov 26, 2004 4:19 am    Post subject: the oscilators Reply with quote  Mark this post and the followings unread
osciloscoop
(square wave's pulsewidth is set to 52 instead of default to produce more accurate squarewaveform)
grafic display of the basic waveforms of the a6
 Filesize:  93.91 KB
 Viewed:  6798 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Nov 26, 2004 4:32 am    Post subject: tuning the oscilators Reply with quote  Mark this post and the followings unread
(this patch is also usefull when wanting to test your oscillators)
the autotune of the A6 works reasonable, just that
even after repeated autotune differences of up to +/- 4cents can be found (measured at A440, with peterson vs1 strobetuner)
to make tuning more noticable i use the following defaultpatch.
1 after warming up ,ca15minutes, press autotune ,switch voxmonitor on and press A4 repeatetly.
2 when voices sound oke, switch them of temporary.
3 then renew tuning for the remaining patches by pressing "oscfreq tune"
4 repeat stage 2 and 3
5 after all voices have been properly tuned, turn them all on again , and voila, a tuned A6!
000default.syx
patch i use for tuning my A6 oscilators, read tuningprocedure above
This patch is also useful when you want to test your oscillators, just connect a tuner and measure !
 Filename:  000default.syx
 Filesize:  2.29 KB
 Downloaded:  214 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Nov 26, 2004 4:40 am    Post subject: tuning oscilators 2 Reply with quote  Mark this post and the followings unread
for those not used to tuning oscilators or those simpy wanting to hear the differences between the oscilators i made the following little tunegame.
switch voxmonitor on (under globals)
put ribbon on hold
play a key and adjust the tuning of oscilator two by moving along the ribboncontroler.
125 Draaien.syx
small" tunegame"
put ribbon on hold , watch voices by voxmonitor.
get the oscilators tuned by moving along the ribbon
 Filename:  125 Draaien.syx
 Filesize:  2.29 KB
 Downloaded:  174 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Dec 10, 2004 5:00 am    Post subject: testjunky Reply with quote  Mark this post and the followings unread
everything in tune?
then this patch could be too
090testjunky.syx
everything in tune?, then this patch too
characteristics: resonance set high, ribbon,modwheel and sustainpedal can be adjusted to taste, apergiator included to make it more comfortable
 Filename:  090testjunky.syx
 Filesize:  2.29 KB
 Downloaded:  187 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Fri Dec 10, 2004 5:14 am    Post subject: my default Reply with quote  Mark this post and the followings unread
don't like the a6 default patch so modified it a bit.
differences are b.e. :controlrouting of modwheel to lfo2mod's (they are more flexible then the lfo 1), waveform , filtersettings, env's and div other settings are adjusted to quicker start from a reasonable sound when tweaking. ( at least that's my opinion, always open for suggestions)
one last remark: in general , when switching external audio-in: turn levelnoise/ext to 5 or less afterwards to avoid distortion, i couldn't implement this so hereby as tip.
035default3.syx
adapted defaultpatch, for (in my opinion) quicker tweakresult
 Filename:  035default3.syx
 Filesize:  2.29 KB
 Downloaded:  241 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Wed Feb 02, 2005 6:21 am    Post subject: analog + analog ? Reply with quote  Mark this post and the followings unread
couldn't leave it:
elaborate photo session of the inside of the A6:
http://www.deepsonic.ch/2003/htm/alesis_a6.php
Audio files: 107
PostPosted: Wed Feb 02, 2005 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting the pics, Sunny. Very interesting...
sunny pedaal
Audio files: 12
PostPosted: Sat Aug 11, 2012 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
just to update, the inside pictures on the deep sonic net link have been removed, therefore this place to watch :
http://electro-music.com/forum/viewtopic.php?highlight=show+guts&t=5257
AmbiphonicDSP
