Joined: Feb 04, 2005 Posts: 2130 Location: Nottingham, UK
Audio files: 150
Posted: Sat Oct 10, 2009 8:56 am Post subject:
| EdisonRex wrote: | Dark and ambient, but very satisfying.  |
Thanks Paul
It was literally an 'adventure in sound' for me  _________________ Jez
music | adventures in sound |
Audio files: 150
Posted: Wed Oct 14, 2009 2:13 pm Post subject:
any clues as to what might be on tonight's show Rob? _________________ Jez
Muied Lumens
Joined: Apr 24, 2009 Posts: 1322 Location: Bristol UK
Audio files: 204
Posted: Wed Oct 14, 2009 2:19 pm Post subject:
Tonight is one song, the exploration of small things, lingering on the spot, and possibly moving a little here and there too. _________________ robsol
Muied Lumens Base Star |
Audio files: 150
Posted: Wed Oct 14, 2009 2:20 pm Post subject:
| Muied Lumens wrote: | | Tonight is one song, the exploration of small things, lingering on the spot, and possibly moving a little here and there too. |
'sounds' interesting  _________________ Jez
shanemorris
Audio files: 83
Posted: Wed Oct 14, 2009 5:05 pm Post subject:
Cool Stuff Rob! Great #2!  _________________ ElectroCasa |
Joined: Apr 03, 2004 Posts: 19599 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Wed Oct 14, 2009 5:36 pm Post subject:
Great adventure, some cool stuff - the singing was nice! _________________ Jan |
Muied Lumens
Audio files: 204
Audio files: 215
G2 patch files: 92
Posted: Fri Oct 16, 2009 3:51 am Post subject:
Just listened through it (unfortunately Jez And Rob's adventures is a little too much past bedtime for me to listen live) - marvellous! That blackbird was pretty eerie.
@soundcloud @Flattr @myspace A blog home - you can't explain music |
Muied Lumens
Audio files: 204
Posted: Fri Oct 16, 2009 6:13 am Post subject:
Thank you Antimon.
After Jez' show next week, Sweden will turn the clocks back one hour for daylight saving hours (25th of October), so the show will be one hour earlier. Maybe that will help? _________________ robsol
EdisonRex
Joined: Mar 07, 2007 Posts: 4449 Location: London, UK
Audio files: 168
Posted: Fri Oct 16, 2009 6:18 am Post subject:
Yes, Rob, I listened to it. I really enjoyed the show. I wonder where you get your inspirations?  _________________ Garret: It's so retro.
Muied Lumens
Audio files: 204
Posted: Fri Oct 16, 2009 6:42 am Post subject:
| EdisonRex wrote: | I wonder where you get your inspirations?  |
Big influence from you! I tried to do some solos, but I desperately need to work on my timing and keyboard work. I had some inspiration in the structure of how the shows are set up as well, and the pad sounds you use.
Les' vocoder gave me some ideas, as did Jez' tweakings, Jan's noodles and Shane's Space Port. The radio is so full of talent (not to mention knowledge and skills!) that that it makes me feel all warm and fuzzy inside being part of it.  _________________ robsol
Audio files: 215
G2 patch files: 92
Posted: Fri Oct 16, 2009 6:50 am Post subject:
| Muied Lumens wrote: | Thank you Antimon.
After Jez' show next week, Sweden will turn the clocks back one hour for daylight saving hours (25th of October), so the show will be one hour earlier. Maybe that will help? |
Yeah, it's that time of year again. I think I'll try to do a couple of late night wednesdays...
Edit: removed imposing picture to keep the thread focus
@soundcloud @Flattr @myspace A blog home - you can't explain music Last edited by Antimon on Wed Oct 21, 2009 11:20 pm; edited 1 time in total |
Audio files: 150
Posted: Wed Oct 21, 2009 1:06 pm Post subject:
Tonight's show will feature some improvised kaossillations and some microkorg and will be a sort of companion piece to my last show as it features the other half of the equipment I will be taking to EM-2009 _________________ Jez
Audio files: 150
Audio files: 116
G2 patch files: 317
Posted: Fri Oct 23, 2009 5:46 pm Post subject:
| modulator_esp wrote: | I enjoyed it  |
You were not alone in that  _________________ Jan |
Audio files: 150
Posted: Fri Oct 23, 2009 5:52 pm Post subject:
| Blue Hell wrote: | | modulator_esp wrote: | I enjoyed it  |
You were not alone in that  |
Thanks Jan
and thanks for listening _________________ Jez
Muied Lumens
Audio files: 204
Posted: Wed Oct 28, 2009 12:25 pm Post subject:
Tonight is a little bit of a stunt, using only images to create sound. Attached is a long image that does not only represent the audio you are hearing in tonight's show, it is the composition itself, which has been used directly to create what you hear.
To read it, start from left and work your way through to the end. Horizontal lines convert into tones, while big bright areas convert into noise. Top is high frequencies and bottom is low frequencies. Brightness indicates loudness, and colour has no effect, apart from making it a little bit more interesting to look at.
It may be difficult to follow exactly what is happening, because the image is linear (in terms of frequency) while the sound itself is logarithmic. Therefore, a lot of frequency information lies in the bottom tenth of the image... If you have problems following the score, log into the chat and I'll give you a pointer as to where we are.
The image below was converted to sound using Adobe Audition 3, and edited in Gimp. There is a lot of scope for more experimentation, as you can also export audio from AA3, but I have restricted myself to only going one way this time.
All the effects that you hear in the track are from the image editing. I did some subtle tweaking after converting the image to sound, notably making it stereo and adjusting levels a bit.
I hope you enjoy it.
Oh, and the image may take some time to load, even though I have tried everything in my power to make it as light as possible. (The original image is similar in size to the audio file...)
Edit: I have updated the image with time cues every 2.5 minutes so it is easier to follow where you are. They are not exact to the second but they are close enough for the purpose they hold. Know that the blue vertical lines and the time indicators are not part of the sound (everything else in the image is). The sound file has also been attached to this post.
| The "score" for AIS image to sound project 28th of October 2009. Follow this while listening to the sound file AISsound6. |
7 MB |
| Viewed: |
158 Time(s) |
| The sound for AIS image to sound project 28th of October 2009. If you are interested, the image that was used to create this track is AISscore6.jpg. |
 Download |
| Filename: |
AISsound6.mp3 |
55.71 MB |
| Downloaded: |
480 Time(s) |
Muied Lumens Base Star Last edited by Muied Lumens on Thu Oct 29, 2009 1:59 pm; edited 3 times in total |
Muied Lumens
Audio files: 204
Posted: Wed Oct 28, 2009 2:32 pm Post subject:
Also note that the show starts one hour earlier tonight, in countries which changed from summer to winter time this weekend. _________________ robsol
Audio files: 150
Audio files: 150
Posted: Tue Nov 03, 2009 4:51 pm Post subject:
listened to it last night, sounded good with the planes flying over  _________________ Jez
Audio files: 150
Posted: Tue Nov 03, 2009 4:52 pm Post subject:
I've spent a lot of today putting my episode together
It's a sonic travelogue made up of field recordings with added stuff _________________ Jez
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1332 Location: Telford, PA USA
Posted: Tue Nov 03, 2009 7:39 pm Post subject:
| Any crickets? |
Audio files: 150
Posted: Tue Nov 03, 2009 7:53 pm Post subject:
| Danno Gee Ray wrote: | | Any crickets? |
Oh yes, there certainly is, many thanks for telling me about him, as well as the cricket there's some other stuff from Star Lake, including the infamous door slam and some rain and even a couple of guest speakers, but they got a bit buried in the mix. _________________ Jez
Danno Gee Ray
Posted: Tue Nov 03, 2009 8:22 pm Post subject:
| cool. |
Audio files: 150
