ssprod
Posted: Mon Feb 18, 2008 6:12 pm Post subject:
Why is my Master Volume so low?? Subject description: can't get the volume to get any higher on Andromeda |
the volume on my Andromeda is very low...even with the master volume knob at max level. The headphone volume is also low.. so, I figure it must be some internal setting. I've done the hard reset (soft key 3 while powering up), but nothing. I tried taking out the 1/4" plugs and putting them into my Triton, and it's fine there, so it's not the cable. Any ideas?? |
edtumog
Posted: Sat May 03, 2008 10:12 am Post subject:
Low volume |
Hey just posted the same question on this forum !
Have you had any luck ? |
Divyx
Joined: Jan 23, 2008 Posts: 27 Location: Tampere, Finland
Posted: Wed May 07, 2008 2:57 am Post subject:
Hi folks.
You have checked where andro outputs it's sounds? Main outs or individuals? Otherwise, i had this problem too and unfortunately i had to send it to guarantee repairement. Took only around 3 weeks.
It's coming back this week from germany ( alesis own repairment service fixed it ). I hope they really fixed it. It's remains to be seen.
However, i don't have yet a full knowledge what was broken and if they didn't include explanations of what they fixed, i never know.
In any case, if the outputs are directed right, then i hope you have guarantee left in your A6.
Br, Divyx |
giammy81
Posted: Sun Apr 19, 2009 3:03 pm Post subject:
Hi, I am Italian and I write very little in English. I believe to have the same problem, the out outs, aux and phones they are lowered as. The direct outs (voice out) instead I believe works in way corrected. I don't have the keyboard in guarantee because I bought it used, and it has never fallen, has suddenly happened, I have not gotten off her yet. Who has made it mend he can tell me if he has known in what the problem consisted? I have not opened her yet, and I wondered me if it were repairable or there is need to change some card. You can tell more me on the technical support in Italy, Alesis have told me "Esound to Recanati" but they anchors I have not received an answer away mail.
Thanks, kindest regards |
Finder
Posted: Sat Oct 31, 2009 12:30 pm Post subject:
If you have this problem don't panic, it can be fixed easily, you will need to unsolder mute-transistors. PM me if you have this problem I will tell you what to do. |
sunny pedaal
Joined: Nov 16, 2004 Posts: 727 Location: netherlands
Audio files: 12
Posted: Sat Oct 31, 2009 2:22 pm Post subject:
i had it on one side of the stereo only, in both aux and main outputs.
after the outputboard was replaced it was solved |
The Real MC
Joined: Jun 20, 2008 Posts: 62 Location: Painted Post NY
Posted: Tue Nov 03, 2009 9:28 pm Post subject:
You may have a broken volume pot. I had a similar problem. The aux output bypasses this pot so you can try a quick check by assigning audio to aux outputs instead of main.
The master volume and filter cutoff pots are stereo ganged pots and unfortunately not very rugged. Try not to be rough on them.
If you are the type that likes frequent filter sweeps, use the ribbon. |
tmste
Posted: Thu Nov 12, 2009 4:33 am Post subject:
I had the same problem
Your Output transistors Q1-Q2-Q3-Q4 need to br replaced
Stef |
Finder
Posted: Thu Nov 12, 2009 4:36 am Post subject:
you can also just take them out, I mean Q1-Q2-Q3-Q4 |
giammy81
Posted: Mon Nov 16, 2009 8:03 am Post subject:
Thanks! |
Onyx
Joined: Nov 19, 2008 Posts: 8 Location: United States
Posted: Mon Dec 07, 2009 6:36 pm Post subject:
Would this fix also apply to the left main being much lower than the right?
The headphone output has the same issue but the auxs are balanced perfectly.
At the moment I am using my firewire mixer to balance the levels but I am curious if anyone knows if these issues are related or if my audio board is shot.
Thanks,
Onyx |
sunny pedaal
Audio files: 12
Posted: Tue Dec 08, 2009 12:50 am Post subject:
i had the same, output board changed solved the problem |
Jaxson
Posted: Fri Oct 01, 2010 1:42 pm Post subject:
Hallo!I bought yesterday a used Andromeda.He have this "too low volume"problem on the Mainouts and phones....can someone tell me the way to make it work right?Do you know how to open the Andro?
Thank you in advance:-) |
sunny pedaal
Audio files: 12
Posted: Fri Oct 01, 2010 4:57 pm Post subject:
there's a very good service centre in germany of alesis numark.
i would take him there ( somewhere koeln enviroment , maybe even more ..) |
Peake
Joined: Jun 29, 2007 Posts: 1112 Location: Loss Angeles
Posted: Wed Oct 20, 2010 9:56 pm Post subject:
Yes, that has been seen before; the mute circuitry can need to be replaced. _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
Finder
Posted: Mon Nov 22, 2010 5:59 pm Post subject:
Well I just removed Q1-Q2-Q3-Q4 transistors on my synth and the problem was solved. |
bamboo123
Posted: Sun Nov 25, 2012 1:42 pm Post subject:
andromeda low volume |
tmste wrote: | I had the same problem
Stef |
how can i do this replacement please???
stephane |
peabreu
Posted: Mon Nov 26, 2012 3:41 pm Post subject:
Also, make sure that the volume pot at the left side of keyboard is up...seen this...happened to me after some months without touching the A6... I completely forgot about this pot at the left side of the keyboard and was just trying to control volume with the main volume (pot at the right side)... I know this is ridiculous but as I said, it happened to me.... |
