<on air> electro-music.com June Solstice Concert Various artists
 Forum index » DIY Hardware and Software » Supercollider
This code won't work?!
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [5 Posts]
Pseudo_Pseudo
PostPosted: Wed Oct 28, 2009 6:19 am    Post subject: This code won't work?! Reply with quote  Mark this post and the followings unread
Hey,
This is probably a noobie question but I have no idea why this code won't work:
b=Buffer.read(s,"F:/Samples/verbsnare.wav");
{PlayBuf.ar(1,b, BufRateScale.kr(b)*SinOsc.ar(0.25,0,100,100), 1, 0, 1)}.play
There seems to be no mistakes according to my SC post window- when I run the code it says that it's playing except there no sound?
Any help would be greatly appreciated.
dewdrop_world
PostPosted: Sun Nov 01, 2009 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is the server booted? (I suppose it must be... I think there's a warning message for that case.)
If so, try running the playbuf synth this way:
Code:
a = {PlayBuf.ar(1,b, BufRateScale.kr(b)*SinOsc.ar(0.25,0,100,100), 1, 0, 1)}.play;
Then you can do (after playing):
Code:
a.trace;
What's the output of that command?
Playback rate will range between 0 and 100x normal speed this way - is that what you wanted?
James
dewdrop_world
PostPosted: Sun Nov 01, 2009 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also be sure you're using the right key command to run code. See the main Help.html file:
To execute code, use the keyboard shortcut: Enter (not Return), ctrl-Return, Ctrl-c, fn-Return, or Shift-Return (OS X, SCapp), Ctrl+Enter (Windows, PsyCollider), Ctrl+c Ctrl+c (Emacs), F5 (vim), Ctrl+e (gedit/sced). For key commands, also see Shortcuts.
It's a very common error to use plain <return> and expect that to run code, but it doesn't (by design, to allow entering multi-line blocks of code).
James
dewdrop_world
PostPosted: Sun Nov 01, 2009 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, never mind, it's something else entirely.
PlayBuf doesn't like an audio-rate input for the rate argument. Change SinOsc.ar to SinOsc.kr and it should work.
(I'll raise this on the developer list as a potential bug, or at least limitation that should be noted in the documentation.)
James
Pseudo_Pseudo
PostPosted: Mon Nov 02, 2009 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thats fixed it, thanks man! Very Happy
