bbinkovitz
Joined: Jun 12, 2006 Posts: 338 Location: central ohio
Posted: Thu Nov 05, 2009 9:05 pm Post subject:
Suggestions for bending the Yamaha DD-20 drum machine? Subject description: All I know how to do is installing switches on straight wiring. |
I have found a few good bends just with straight wiring between pins on the chip. Are there other ones I should know of?
Does this instrument have an easily accessible bitrate-controlling resistor that I can circumvent with a knob to adjust pitch? I learned to do this to a cheap toy sampler at the e-m event this year but I don't know if more sophisticated circuits have the same feature? _________________ solo: http://www.myspace.com/skippyvodka
member of: http://24hoursthegirl.com
(a subsidiary of: http://ruori.org/ )
distro: http://paperisbad.com/ |
electri-fire
Joined: Jul 26, 2006 Posts: 536 Location: Dordrecht NL
G2 patch files: 4
Posted: Sat Nov 07, 2009 6:50 am Post subject:
Re: Suggestions for bending the Yamaha DD-20 drum machine? Subject description: All I know how to do is installing switches on straight wiring. |
bbinkovitz wrote: | Does this instrument have an easily accessible bitrate-controlling resistor that I can circumvent with a knob to adjust pitch? I learned to do this to a cheap toy sampler at the e-m event this year but I don't know if more sophisticated circuits have the same feature? |
Hey Beth, into circuitbending now. Nice. I don't know the DD20. I have had several Yamaha devices that work with crystal clocks, those are less reactive to pitchbend points.
As we've learned at the "Casperelectronics" Pete Edwards workshop the clockspeed (or pitch) resistor is usually near the CPU, that would be the largest most complicated IC at the board.
When there is a pitch resistor it often reacts to touching it with a damp finger, or touch it while simultaniously touching other parts of the circuit. So you'd be able to find your resistor yourself by touching the board all over. Do this while powering the device ON BATTERIES! Also I recommend touching singlehandedly, so you don't send signals across the body.
The risk of electrocution using an AC/DC adapter is largly exagerated I think, but I broke several adapters by shorting them.
Sending frequencies through the human body affects your fysiology. I have personally experienced turning slightly psychotic by prolonged touchcontacting a toy keyboard and spent hours scratching at the soundnames printed on it to highlight the secret messages that leaped upon me . Running on batteries at least limits the power your device is able to emit.
bbinkovitz
Posted: Sat Nov 07, 2009 8:10 am Post subject:
electri-fire wrote: |
Hi! Actually I started bending this little guy before I came to e-m this year. I thought about bringing it and ended up really wishing I had. I've slowly destroyed a few other Yamaha and Casio products as well... now I'm looking to create some more sustainable bent instruments.
My DD-20 looks exactly like this:
I don't know what "crystal clock"means (I Googled it and only found expensive Waterford mantlepiece clocks that you're supposed to give as a wedding present ) but it seems possible that what you describe might be the case here as well.
Yeah, I've already found the big IC and soldered a few connections to it. Actually in the DD-20 the largest IC and a second, slightly smaller one seem to be wired together such that the pins are pretty much the same. I've looked around both of these but not found anything that looks like a definitive candidate for clockspeed resistor.
I tried this already. With it plugged in, actually. Just stayed away from capacitors and also the left side of the board (where the power comes in) and didn't touch the speaker contacts either. Shorted all the resistors around both IC chips, while running the annoying demo, got nothing.
Woah, that has never happened to me. Sounds like it would save money on drugs. _________________ solo: http://www.myspace.com/skippyvodka
electri-fire
G2 patch files: 4
Posted: Sat Nov 07, 2009 8:21 am Post subject:
Yamaha IC's sometimes have datasheets around somewhere. did you look for them, and if so could you get me a link? |
electri-fire
G2 patch files: 4
Posted: Sat Nov 07, 2009 8:31 am Post subject:
bbinkovitz wrote: | I don't know what "crystal clock" means |
The "crystal clock" has a crystal as a resonator to determine the clock frequency. Crystals have a fixed resonant frequency that can't be easily manipulated. I have the impression a lot of Yamaha's use them, the DD20 also I presume.
A datasheet is helpful to determine the "clock in" pin. Then you could isolate that pin from its components and feed it an clock of your own.
I did that once, it's a bit of a hassleI think. |
bbinkovitz
Posted: Sat Nov 07, 2009 8:32 am Post subject:
electri-fire wrote: | Yamaha IC's sometimes have datasheets around somewhere. did you look for them, and if so could you get me a link? |
It didn't occur to me to Google for the IC data sheet separate from any general circuitry diagram things, I'll look right now.
(Just accidentally typed "yamaha dd-20 IC dada sheet" into Google, that would be quite interesting also if it existed!)
(Found the manual, not very useful but it did let me know that "The DD-20 is the result of passion,
vision, and commitment from people who want you to enjoy
yourself every time you play it." ) _________________ solo: http://www.myspace.com/skippyvodka
bbinkovitz
Posted: Sat Nov 07, 2009 8:38 am Post subject:
electri-fire wrote: | bbinkovitz wrote: | I don't know what "crystal clock" means |
Oh, well do you think it is worth the hassle? Does it make good sounds? _________________ solo: http://www.myspace.com/skippyvodka
bbinkovitz
bbinkovitz
bbinkovitz
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Sat Nov 07, 2009 1:05 pm Post subject:
For what it's worth, it looks like, from the pictures, that the IC on the surface mount side (IC-1) is likely the CPU. The other IC (to which you had wires atached) is probably the ROM where the various drum voices and other data are contained.
It could be interesting to socket the ROM chip and play with the data with an EPROM and programmer..?
Also, the componenets near the CPU may contain a clock circuit for the CPU. I did not notice any crystals. There could be a ceramic resonator in there that might look like a capacitor at first glance, but playing with some of the resistors near the CPU could yield some tasy results. |
bbinkovitz
Posted: Sat Nov 07, 2009 1:11 pm Post subject:
Danno Gee Ray wrote: | For what it's worth, it looks like, from the pictures, that the IC on the surface mount side (IC-1) is likely the CPU. The other IC (to which you had wires atached) is probably the ROM where the various drum voices and other data are contained.
Thanks! I will experiment!
Even if this one doesn't recover from whatever I did to it while I was closing up the case (oh the irony!!!), I will keep all the bends I discover in mind for the next one I find and make diagrams and stuff to share. _________________ solo: http://www.myspace.com/skippyvodka
Danno Gee Ray
Posted: Sat Nov 07, 2009 2:40 pm Post subject:
Cool. |
bbinkovitz
toybox
Joined: Aug 03, 2005 Posts: 176 Location: chicago/peru,illinois usa
Posted: Sun Nov 08, 2009 11:12 am Post subject:
i have a dd-20 also haven't had a chance to open it up yet. it fairly down on the list of projects of mine but some day ill get to it well hopefully.so i hope you get some good stuff from yours id like to see what it is capable of _________________ mY MusIc
http://www.myspace.com/toyboxbastard |
bbinkovitz
Posted: Sun Nov 08, 2009 12:18 pm Post subject:
try the bends that i show in the photos, when you turn the switch back to off, it goes back to clean sound. so you can still use it for the vanilla purposes for which it was intended as well.
er, it's hard to see, i realized.
pins 3 and 8 (from the top) on the left side (white and yellow wires) connecting to 2 and 3 on the right side (orange wires)
so, the yellow wire has a switch for each orange wire. and the white wire has a switch for each orange wire as well. total of four switches, makes interesting permutations. some of the combinations are more than the sum of the individual bends, depending on what kit you have it set on. _________________ solo: http://www.myspace.com/skippyvodka
electri-fire
G2 patch files: 4
bbinkovitz
electri-fire
G2 patch files: 4
Danno Gee Ray
Posted: Sun Nov 08, 2009 6:54 pm Post subject:
3 Legs could be a ceramic resonator (pseudo crystal) and may have a resistor near it which may be slightly bendable...good call. |
howaniec
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Fri Dec 03, 2010 1:54 pm Post subject:
a long time ago, a friend and myself bent the crap out of a dd20. it is easily one of the best bendable toys ever. We some how turned it into an awesome white noise pattern machine with a patch bay that used a game pad for extra control. _________________ home made noise and electronic ill-logic |
