funkyfarm
Posted: Mon Dec 22, 2008 1:23 pm Post subject:
sorry, i meant, assuming this 208 pseudo random thing to be driven by a VC-CLOCK (-10v into any vco), if you use the same signal (1V/oct, velocity...) for controlling both clock rate and Portamento/ 218 slew cv input, you have correlation between speed and slew.
sounds are sharper as rythm increases. |
funkyfarm
Posted: Fri Mar 13, 2009 5:42 pm Post subject:
Here's what i mean (the fx is a little excessive) :
208 218 lfo saw control sample on http://sslstudiodesign.free.fr/218/
A descending ramp (saw lfo) controls both clock rate (wogglebug NE555) and CV IN on 218 slew.
First 208 output is processed trough this latter.
There is four sequences, i've cut control for 218 on the last. (ie all notes are fully slewed even at high clock rate)
I'm sure you could get cool patches with one or two (oncoming) Dunsel circuits here...
208 outputs have a big big range ; it can be too much if you processed them via reversible attenuator (half curse) or use them for VCO.
I've put two voltage dividers (for 5V or so) on the two first outputs.
The two last are used for buchla (292 cv in, vactrol panner/xfader...)
Thank you for these pcb vtl5c3 |
vtl5c3
Posted: Sat Mar 14, 2009 7:50 pm Post subject:
Hi FUnky,
What is the Dunsel circuit?
Vtl.5c3 |
Photon
funkyfarm
Posted: Sun Mar 15, 2009 10:10 am Post subject:
you can get the positive part of any signal on a socket, and the negative part on another separate output socket (with no 0,7v drop...) |
Funky40
G2 patch files: 5
Posted: Sun Mar 15, 2009 12:22 pm Post subject:
wow, i wish to have such a board,
what's missed is -A +5V,
has anybody n advice how to do this
ahh ok, i think i just have to come with +A instead of -A for the offset block, right ? ( see A+5 schematic top right ) |
funkyfarm
Posted: Sun Mar 15, 2009 1:17 pm Post subject:
yes !
A-5 = - (-A+5) = -(-A)-5
A+5 = - (-A-5) = -(-A)+5 |
Scott Stites
Audio files: 96
Tasmanian Alkaloid
Joined: Jun 29, 2008 Posts: 116 Location: Isle De Mort
Posted: Sun Mar 15, 2009 10:47 pm Post subject:
Hi Romeo,
i'm planning to build 2 of these, but as i wrote up a parts list, i was unsure what 'FB' stands for (on the parts layout pdf). |
numbertalk
Posted: Mon Mar 16, 2009 6:25 am Post subject:
Tasmanian Alkaloid wrote: | Hi Romeo,
Ferrite Bead? |
vtl5c3
Posted: Mon Mar 16, 2009 8:21 am Post subject:
Yep. Ferrite Bead.
numbertalk wrote: | Tasmanian Alkaloid wrote: | Hi Romeo,
Ferrite Bead? |
Tasmanian Alkaloid
Posted: Mon Mar 16, 2009 7:44 pm Post subject:
Thanks guys! |
funkyfarm
Posted: Wed Mar 18, 2009 4:51 pm Post subject:
Scott Stites wrote: | Quote: | you can get the positive part of any signal on a socket, and the negative part on another separate output socket (with no 0,7v drop...) |
What you've just described is an ideal diode circuit. This is an exceedingly useful device for synth circuit design. If anyone hasn't already, be sure to check out Jim Patchell's write-up on it here:
http://www.uni-bonn.de/~uzs159/diode_tutorial/index.html
That's it ! IDEAL diode with no voltage drop.
I've build Patchell's too, with a -VBreak pot ; but i can remember outputs need to be buffered for multiple use.
Or maybe my two LED drivers need to be buffered...
The Dunsel module also have a FWR from these two outputs !?
Don't think about its use already...
LetterBeacon
Posted: Tue Jun 30, 2009 7:34 am Post subject:
What type of capacitors would be appropriate for this circuit? I was planning on just using ceramics throughout as I have a lot of 0.1uF ceramics lying around. That should be fine, shouldn't it? |
vtl5c3
Posted: Tue Jun 30, 2009 8:00 am Post subject:
Yep, ceramics should be fine. They're mostly there for supply decoupling, which ceramics do pretty well. The board has spots for 10uF caps at the supply inputs, but you can probably leave those out.
Romeo
LetterBeacon wrote: | What type of capacitors would be appropriate for this circuit? I was planning on just using ceramics throughout as I have a lot of 0.1uF ceramics lying around. That should be fine, shouldn't it? |
LetterBeacon
Posted: Tue Jun 30, 2009 8:12 am Post subject:
Great, thanks a lot! |
Photon
Posted: Sat Aug 08, 2009 6:35 am Post subject:
Finished this recently. The most fun per rack unit in my whole system. thanks Romeo, Scott, and of course Mr. B. |
vtl5c3
Posted: Sat Aug 08, 2009 9:50 am Post subject:
Thanks for the photo. Makes me feel warm and fuzzy on the inside seeing that! |
pcp2020
Posted: Sun Aug 09, 2009 2:07 pm Post subject:
I noticed that Scotts schematic wants 15 volts. would this work on 12? |
Photon
davemoog
Posted: Tue Nov 03, 2009 11:13 pm Post subject:
4015 locking up? |
Has anyone had problems with the 4015 locking up and then no random CVs are produced? Powering off then on again will restart.
Thanks Dave |
fluxmonkey
Posted: Tue Nov 17, 2009 11:22 am Post subject:
i have a couple extra boards coming from ExpressPCB... if anyone would like them at cost + postage please drop me a PM with your email address.
thx
bbob _________________ www.fluxmonkey.com |
jooks
Posted: Tue Nov 17, 2009 2:08 pm Post subject:
Quote: | have a couple extra boards coming from ExpressPCB... if anyone would like them at cost + postage please drop me a PM with your email address. |
PM sent. |
valis
Joined: Sep 16, 2008 Posts: 121 Location: Oregon, USA
Audio files: 6
Posted: Thu Nov 19, 2009 9:23 pm Post subject:
bbob wrote: | i have a couple extra boards coming from ExpressPCB... if anyone would like them at cost + postage please drop me a PM with your email address.
thx
bbob |
I sent you a PM yesterday.. |
janvanvolt
Joined: Nov 24, 2005 Posts: 285 Location: Mainz, Germany
