 Forum index » Instruments and Equipment » Soft synths
FM7 "chorus" problems when using sustain pedal ?
Page 1 of 1 [3 Posts]
Patchmouse
PostPosted: Wed Nov 18, 2009 9:15 am    Post subject: FM7 "chorus" problems when using sustain pedal ? Reply with quote  Mark this post and the followings unread
Hi all, I'm using NI FM7 with an E-MU Xboard, and Reaper. For some strange reason I get a sort of chorus effect on repeated notes when using the sustain pedal on FM7 patches that use vibrato. This never used to happen on my DX7 with the same sounds ?
Any ideas where to look ?
Thanks...
PM.
Audio files: 218
G2 patch files: 93
PostPosted: Wed Nov 18, 2009 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know how everything you've got works - are you running the softsynth inside Reaper? Chorus-like effects can appear if you are somehow montoring two source with different latencies at the same time.
/Stefan
Patchmouse
PostPosted: Thu Nov 19, 2009 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'm using FM7 as a DXi plug-in, in Reaper. The chorus effect only happens when I use the sustain pedal ! on repeated notes, when vibrato is activated via the mod wheel. I know that sometimes if you have more than one LFO going at different rates or FM operators that aren't in sync they can cause this effect, but I've checked all that and those parameters are OK.
I know that latency effect you are talking about, I used to get that in Reason, but as you say, it's the monitoring, and I sorted all that out.
PM.
JuneSolstice2013
