jamos
Joined: Jun 01, 2004 Posts: 421 Location: Eugene, Oregon, USA
G2 patch files: 32
Joined: Apr 03, 2004 Posts: 16134 Location: Netherlands, Enschede
Audio files: 75
G2 patch files: 307
Posted: Sat Nov 21, 2009 1:39 pm Post subject:
Nice idea!
I patched it up and some quantization does seem to occur to me, although glides are not fully eliminated ...
BTW, couple of weeks ago I was listing to autotuned singing with gypsy scales .. used in hip hop like music ... I liked that  _________________ Jan |
jksuperstar
G2 patch files: 18
Posted: Sat Nov 21, 2009 3:05 pm Post subject:
| Interesting! I've had this type of thing on my idea-plate for a while. I wanted to play a didgeridoo, but send in a sequence to pitch shift it, but do it based on the difference between the didge sound and the sequence. Very similar! I'll try to play with it tonight. |
Audio files: 32
G2 patch files: 74
Posted: Sun Nov 22, 2009 5:30 am Post subject:
Why are you taking the difference between the original signal and the note quantized one? When I've tried my hands at this I've taken a pitch detector, note quantized its output and then plugged that straight into an oscillator pitch input, which then goes into a vocoder. I've had varying results (it's really tricky to get the pitch to "stay on target" for me), but I don't usually have any problem with the pitch itself.
/Stefan _________________ @myspace @virb A blog home - in Cyberspace no one can hear you SEGV |
tim
G2 patch files: 169
Posted: Sun Nov 22, 2009 7:30 am Post subject:
Auto-Tune, an interesting subject. Hope nobody minds if I chime in.
AFAIK there is already a patch in the factory preset bank called "pitch correct" (or something like that) which does this kind of thing.
However, keep in mind that the pitch-shifter is based on a delay line, and therefore naturally has an amount of latency. This causes slurs and other artefacts when correcting notes. The patch mentioned above also suffers from this.
Some time ago, I attempted to build a pitch correction patch that is based on a different approach, extracting individual wavecycles of the incoming signal, pitching them according to the correction scheme, and redistributing them along the time-axis, which results in an artefact-free pitch shift (under the condition that the incoming signal is strictly monophonic and periodical).
The basic pitch shifter circuit:
http://www.electro-music.com/forum/topic-27228.html
The concept of the auto-tuner itself works, but the pitch detection isn't bullet-proof. I've since attempted to design the "maximum zero gradient" pitch detection algorithm on the G2, but got fed up with it at a certain point. That technique isn't optimal for voice anyway. The best would be AMDF, but that is simply impossible to patch on the G2.
Here's the first version. It has some issues (mentioned above), but anyway...
http://www.electro-music.com/forum/topic-26222.html
I made another one, based on a similar idea. This works better:
http://www.electro-music.com/forum/topic-26247.html
Maybe this is of use to someone.
t |
jamos
G2 patch files: 32
Posted: Sun Nov 22, 2009 1:39 pm Post subject:
| Antimon wrote: | Why are you taking the difference between the original signal and the note quantized one? When I've tried my hands at this I've taken a pitch detector, note quantized its output and then plugged that straight into an oscillator pitch input, which then goes into a vocoder. I've had varying results (it's really tricky to get the pitch to "stay on target" for me), but I don't usually have any problem with the pitch itself.
/Stefan |
It's because I'm using the pitch shifter, rather than an oscillator and vocoder (though I think I will try that as well). The idea being that when the pitch matches the quantized value, there is no pitch shift; but when the pitch is off, it is shifted to compensate. |
jamos
G2 patch files: 32
Posted: Sun Nov 22, 2009 2:25 pm Post subject:
| tim wrote: | Auto-Tune, an interesting subject. Hope nobody minds if I chime in. |
Chime away!
Yes, I guess the delay line could cause slurring which would mask the steps. I'd still think I'd hear a bit more in the way of stepping, but..
Your intonation patch is sweet. Lots of control and sounds good. I'll try adapting that and see what I get. Thanks x 10^6!
Jim |
Audio files: 32
G2 patch files: 74
Posted: Sun Nov 22, 2009 2:48 pm Post subject:
| jamos wrote: | | Antimon wrote: | Why are you taking the difference between the original signal and the note quantized one? When I've tried my hands at this I've taken a pitch detector, note quantized its output and then plugged that straight into an oscillator pitch input, which then goes into a vocoder. I've had varying results (it's really tricky to get the pitch to "stay on target" for me), but I don't usually have any problem with the pitch itself.
/Stefan |
Ah of course, sorry and thanks for explaining. I agree, it's a neat idea!
