  bingsatellites Mostly Ambient
Fritz chaos circuit
Page 9 of 11 [265 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11 Next
loss1234
PostPosted: Sat Mar 01, 2008 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
love those knobs!!
i am trying to get a mixer panel in my synth and then i will get back to working on other things...like patching the ez into the jerkster!!
bearblock
PostPosted: Wed Apr 02, 2008 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
bearblock wrote:
in fact the rate pot seems to be generating a CV... this isn't that far from being a full-on chaotic VCO amirite?
Absolutely! It was designed so you could use a standard expo converter to replace the "Rate" pot. I even put extra holes on the board for mounting a piggyback expo circuit.
I'm now starting to wish my Jerkster LFO had a rate CV input, so I figure I may as well do exactly this and get a weird new audio VCO as well. Specifically, I plan to build the expo converter from your Triangle VCO on stripboard and hook up the current output to the rate pot wiper input of the Jerkster. Is really that all there is to it? Just looking for some reassurance before I buy the parts Wink
loss1234
PostPosted: Wed Apr 02, 2008 4:20 am    Post subject: Reply with quote  Mark this post and the followings unread
that sounds like a great idea!!
i plan on buying a bunch of double well and jerk boards when i get the money from bride chamber and making a big chaos machine
ian, maybe you could design an add on strip or pcb layout, or sell a board, for the expo add on!
frijitz
Audio files: 54
PostPosted: Wed Apr 02, 2008 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
No that is not an appropriate expo converter. You need one to source current into the OTAs. There are quite a few out there. You might be happy with a simple single opamp one like Rene's:
http://www.uni-bonn.de/~uzs159/index.html
Or the fancier T. Henry designs on Scott Stites' page:
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id29.html
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id31.html
(Leave out the linear fm and hft components.)
Ian
Audio files: 51
PostPosted: Sat Nov 15, 2008 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I've designed a stripboard layout of the EZ-Chaos circuit and, with Ian's permission, present it here for anybody to use if interested.
I used 6 op-amps and incorporated a basic indicator for each output. The LEDs are bi-colour, and hopefully will help with adjusting the controls for a decent swing and good placement.
I've laid it out so the pots can be mounted directly on the board (16mm) but you could easily run wires if not. The LEDs should also easily mount through 3 holes drilled between the pots.
I'm in the process of building it up to test, but at this stage it is UNTESTED.
I'll update this status as soon as I can get to my workbench. Rolling Eyes
I'm planning on putting 2 of these on a 1U rack. Or possibly three, normalled to a jerkster on a 3U rack.
Enjoy! Very Happy
 Filesize:  39.35 KB
 Viewed:  206 Time(s)
 Filesize:  37.49 KB
 Viewed:  158 Time(s)
We would lose our friends.
So,.........
frijitz
Audio files: 54
PostPosted: Sat Nov 15, 2008 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great!
Ian
bugfight
PostPosted: Sat Nov 15, 2008 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for sharing that,
if it had come a few months back i would definitely have built it,
but now i gots a bridechamber pcb in the queue...
anywayz, will no doubt help some others get their chaos on and whatnot
fluxmonkey
PostPosted: Sun Nov 16, 2008 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
very cool, thanks for providing another option... keep us posted on a build?
b
www.fluxmonkey.com
frijitz
Audio files: 54
PostPosted: Tue Apr 28, 2009 9:55 pm    Post subject:
Subject description: softsynth version
I now have a version of this system running in ABox using the diff eqn solver. I can't figure out how to post the file, as I get an illegal extension error, but I could email it to anyone who might be interested. (See the ABox thread under Instruments and Equipment --> Soft synths.)
Ian
PostPosted: Tue Apr 28, 2009 10:39 pm    Post subject:
zip it!?
fonitronik at
Audio files: 51
PostPosted: Tue Apr 28, 2009 10:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any illegal extension can just be zipped, as .zip is a legal extension. Wink
Audio files: 51
PostPosted: Tue Apr 28, 2009 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
You just beat me to it Fonik!
frijitz
Audio files: 54
PostPosted: Wed Apr 29, 2009 1:47 am    Post subject:
fonik wrote:
zip it!?
Excuse me??? ... Oh, you mean the file.
Ian
PostPosted: Wed Apr 29, 2009 1:56 am    Post subject:
frijitz wrote:
fonik wrote:
zip it!?
Ian
Embarassed
Excuse me, no offense meant! i am not a native speaker. your reply made me reach for the dictionary - too late, and now i learned a new phrase...
fonitronik at
frijitz
Audio files: 54
PostPosted: Wed Apr 29, 2009 2:25 am    Post subject:
Of course not! It was funny.
Ian
frijitz
Audio files: 54
PostPosted: Wed Apr 29, 2009 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, this should work. ABox download @
http://www.andyware.com/abox2/download/index.html
There's more work needed on scaling, but you should be able to get a good range of patterns at ~1kHz
Ian
EDIT: Replaced with an improved version -- improved scaling and lower levels.
dwelltest03.ABox2
 Filename:  dwelltest03.ABox2
 Filesize:  2.16 KB
 Downloaded:  134 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Wed Apr 29, 2009 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Extension test ...
ok that seems to work.
dwell02.ABox2
 Filename:  dwell02.ABox2
 Filesize:  2.16 KB
 Downloaded:  120 Time(s)
frijitz
Audio files: 54
PostPosted: Wed Apr 29, 2009 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Extension test ...
Worked here for me too. Thanks again!
Ian
Audio files: 116
G2 patch files: 317
PostPosted: Wed Apr 29, 2009 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome Ian.
Audio files: 107
PostPosted: Thu Apr 30, 2009 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just loaded your abox file. It's really interesting but it goes unstable, or should I say stable, when the knobs are turned by someone like me who has no idea how this works.
frijitz
Audio files: 54
PostPosted: Thu Apr 30, 2009 9:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing You should have seen me struggling with it! I've replaced the previous file with an upgraded one in my previous post. This now scales properly with frequency and the amplitudes have been reduced a bit.
There is some general discussion of the analog circuit here:
http://home.comcast.net/~ijfritz/ch_cir1.htm
If the system runs to the rails, then you can increase the damping, or decrease the drive amplitude, or reduce the strength of the nonlinearity.
If the system sits at a point or makes a small orbit, then you can do the opposite of the above, or vary the drive frequency.
In general, you might start with the original settings and look separately at the effects of drive frequency and drive amplitude. Then you can explore the effect of the damping parameter, which determines the overall amount of irregularity. That should give you some feel for the important effects of the main parameters.
Thanks for trying this out!
Ian
scriptstyle
PostPosted: Fri Dec 04, 2009 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey unkle did you ever get around to testing the stripboard layout? I have jus preped a board for population and will be getting to it sometime soon. Also where did you get your dual gang 1m pot?
Thanks
frijitz
Audio files: 54
PostPosted: Fri Dec 04, 2009 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually you can use just about any old dual pot 10k or over. 1M was just what I had on hand.
Smile
Ian
macumbista
PostPosted: Tue Dec 15, 2009 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all... I've been digging into the Dan Slater article mentioned a few times in this thread, and also writing Ian privately about his chaos generators, but I wanted to open the communication up a bit.
The interesting point in the Slater article states that "a chaotic system requires both feedback and nonlinearity". I've been working with FM cross-modulation feedback for some time now. My current setup uses four Thomas Henry XR-VCOs (at LFO rates) cross frequency-modulated through a 4x4 bipolar matrix mixer. The outputs of these VCOs are then used as control voltage for another four XR-VCOs at audio rate.
This setup produces plenty of "chaotic" patterns, and running the modulation feedback through some sort of waveshaper or phase shifter has a strong effect on the modulation. So I'm looking for other nonlinearities which can be introduced into the modulation path to increase the amount of chaos.
I'd like to emphasize that while I am interested in chaotic patterns, I'm not interested in building a single-unit chaos oscillator. I'm more looking for analog-computer-style functions I can "insert" into the feedback paths of what I've been working on already to make it more nonlinear/chaotic. I'm not sure if what I'm doing could be called "chaos" in the mathematical sense, but creatively it's the direction I'm headed in.
My first step will be to make an x³ circuit, which David Dixon and Simon Brouwer on the SDIY list have suggested can be made from four-quadrant multiplier followed by a two quadrant (OTA) multiplier. (or another four quadrant I suppose...) I've also been thinking about the Buchla 257 Dual Control Voltage Processor and the way (I understand) you could "interpolate" between two voltages (help me out here anyone!), which seems very useful as a way to voltage control the amount or type of nonlinearity something like the x³ circuit would introduce into my feedback system.
But I would love to hear any suggestions people might have for other useful or sonically interesting functions. (Also, is the EZ Chaos module the kind of thing that would be useful in my situation, or is it an oscillator by itself?)
Ian has mentioned a few times that he's interested in how people will use these projects, so perhaps my approach is that I have a use and I'm looking for the right kind of nonlinear functions to incorporate into it.
I hope this doesn't sound too vague... one of the frustrating parts of looking into all these documents is the lack of "use scenarios", so it's hard for me to get an idea of what some of Ian's circuits might be used for. Am I reinventing Ian's wheel here, or going down a different path?
Thx+best!
Derek
macumbista.net
frijitz
Audio files: 54
PostPosted: Tue Dec 15, 2009 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
The point of making dedicated chaos modules was to avoid having to set up complicated patches. The systems available each exhibits all the main types of chaotic behavior.
For additional elements in your system you could use the nonlinear x - x^3 circuit on my website. This generates a reasonable approximation using the soft knee of a zener diode as a very simple alternative to actually building complicated and cumbersome polynomial generators.
The doublewell chaos generator is a driven system, so it could be used either as a feedback element or in place of one or more of the LFOs.
Ian
JuneSolstice2013
