SDS3 Single Voice PCB Run
Page 9 of 10 [245 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10 Next
mono-poly
PostPosted: Sun Dec 06, 2009 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
The project seems death Sad
PostPosted: Sun Dec 06, 2009 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
i am not able to contribute much these days. however, anyone could chime in any time...
diablojoy
PostPosted: Sun Dec 13, 2009 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Sad
fonik , the cct works from what i gather from previous posts
concern is only noise issue on the bread boarded cct
unfortuantly i don't use eagle to design boards in , so i fear that i may be of little help as i would be starting from near scratch with that program and also have few hours available. would eagle light be ok. ? if not i would probably have to redo it in my normal program , I may be able to find some time near the end of january and finances should improve a bit by then, but can make no promises. if you think this is ok send me what info you can, and i will give it a go.
cheers
denis
mono-poly
PostPosted: Sun Dec 13, 2009 6:32 am    Post subject:   Reply with quote  Mark this post and the followings unread
Surprised
PostPosted: Sun Dec 13, 2009 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
i actually handed over all i've done so far to sciptstyle. he will get even my proto PCB (maybe it is of some use).
the eagle files are too large for a light version.
scriptstyle
PostPosted: Sun Dec 13, 2009 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i have had a little extra time over the past few days, i was able to compare the old schemo to the new. just about all seems in order so far.
patiently awaiting the proto board now, im off work till after the new year so i am hoping to move this project along over the next month.
diablojoy
PostPosted: Sun Dec 13, 2009 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok that is very good news Very Happy
yes i thought that might be the case the light version is very limited,
lucky then that scriptstyle will do this, i would have taken a lot more
time.
denis.
PostPosted: Sun Dec 13, 2009 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello scriptstye, check PM.
scriptstyle
PostPosted: Tue Dec 22, 2009 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
A little update, I received the board a few days ago, and as of now it's wired up on my desk making sounds. I haven't had much time with it yet but it seems like we should have a pcb run coming in 2010 Cool
Im going to be real busy over the next few days with my 2 special ladies. So hopefully I will have more news next week.
Happy holidays!
PostPosted: Tue Dec 22, 2009 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
useful sounds, i hope? anyways, great news. i am looking forward to hear about your work on the proto...
Happy holidays!
have fun!
Dego
PostPosted: Tue Dec 22, 2009 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
good x-mas news!
mono-poly
PostPosted: Tue Dec 22, 2009 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Happy holidays!
Very Happy awesome!
scriptstyle
PostPosted: Wed Jan 06, 2010 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok so i have had some time to test this. i have a few questions for anyone who has owned the original sds3. or has knowledge of using ladder filters as oscillators.
the noise to tone control, was this control very touchy? as of now the noise sounds great but a 1/4 of the way towards tone it goes into this death bass then straight into very high pitched rough pulsations. my understanding is that the tone is derived from a ladder filter, i have been reading the old thread when Randaleem was working on a pcb. he mentioned
But there's a problem with this two-timing,(Isn't there always!) and it's that we have to choose to emphasize EITHER tone or filter, and as we move towards one end of the frequency scale or the other we can only get what' left at that end as the filter has done away with the rest!
So our filter plays VCO and goes into oscillation to give us tone, and the AR EG sends the filters center/cutoff frequency up or down on attack to take care of both head stretch and stick impact. As long as we're in Toms, or Bass we're okay. Try to get a snare sound? As you increase toward noise with the filter, now we don't have any tone and cannot sharpen the filter response enough to get any click!
on the original schematic there is a side note about noise bleed through, i tried this and it just made things worse.
i also discovered that the sds3 has been successfully cloned already.(so it must be possible) Laughing
http://simmonsmuseum.wordpress.com/2009/10/10/analog-bbq/
the original cct doc: http://www.simmons.synth.net/sds34/docs/sds_3_service_scoops.pdf
my most recent effort has been tracing the signal before and after the filter. it seems that i am getting this signal before Q1-bc557
honestly i would think that this would be good for a drum module? after Q1 and Q2 noise appears.? once this signal has gone through the ladder and out IC3 i am getting this signal on PIN1 of IC3.
this is a harsh output.
also im wondering what exactly did the pitch control do? i am expecting it to change the timbre. but it seems to react to the lfo only(in a gating manor)???
i can clearly see that this module has great potential.
garret
mono-poly
PostPosted: Fri Jan 08, 2010 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Good to see you back on it.
Hopefully someone can answer your questions.
I think Lars got the sds4 if i'm right.
What i like about the sds3 clone on the page is that it got the modulator already build in.
mono-poly
PostPosted: Sat Jan 09, 2010 8:32 am    Post subject:   Reply with quote  Mark this post and the followings unread
I've been in cotact with Michael who designed the clone in the last post.
He is working on the design a little more and it seems he is gonna share it here with us.
mono-poly
PostPosted: Sat Jan 09, 2010 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
And i got another email from Michael and this gives good hope.
One channel needs three boards: The reason is, that the cymbals have another sound source and the envelope generator is also used in other projects. And: To search a fault is much easier. I like the design with the pots fixing the whole thing to the front panel.
Also the newest version needs three boards: The moog filter on board 1, the envelope and VCA on board 2 and noise generator and LFO on board 3. To be flexible, the RUN generator is also on an extra board.
 Filesize:  211.46 KB
 Viewed:  208 Time(s)
scriptstyle
PostPosted: Sat Jan 09, 2010 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
this is good news i am a bit fed up troubleshooting this. last night i spent 3hours trying to minimize LFO bleed through. Mad
ericcoleridge
PostPosted: Mon Feb 22, 2010 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm hoping this project will come up again in 2010. There's obviously tons of drum synth projects around, but I haven't found one that suits me yet. Seems like many are super simple, and without noise source/modulation (coron, cgs drum sim) or quite a bit more complicated than what I like (clangora, mega, cynare).
I have an old broken down Synare that I really love, but I've repaired it so many times that it's just too fragile to play now. Would like something similar to replace it, without having to spend $300-$400 on a new one.
I also like that this clone uses a filter for it's osc/sound source; In my experience sine waves create the punchiest percussion sounds
mono-poly
PostPosted: Mon Feb 22, 2010 11:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll visit my technican this friday and ask him to build the proto boards i got.
After that i havet to ask the guy who started this to do a run of pcb's here.
TekniK
PostPosted: Tue Feb 23, 2010 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
its confusing when u mix up 2 projects in one topic,maybe just start another one.
PostPosted: Tue Feb 23, 2010 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
we are still talking about a SDS3 PCB, i would think.
TekniK
PostPosted: Tue Feb 23, 2010 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't follow, i read that there is some guy working on 'some 'clone' project ,consisted of 3 boards and with a 'moog' filter into it.
and seem another guy is still concentrate his efforts on the first real clone all on one board project that this topic started with.
So its 2 different projects or am i wrong and both guys work together?
PostPosted: Tue Feb 23, 2010 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
i think you're right. i missed scriptstyles post... Embarassed
mono-poly
PostPosted: Tue Feb 23, 2010 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
The 3 boards is the sds3 circuit with some minor changes.
And yes the moog vcf as oscilator just like the real sds3.
All other atemps to clone the unit basicly died.
TekniK
PostPosted: Tue Feb 23, 2010 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
All other atempts to clone the unit basicly died.
Ok,is there a plan all will be merged onto 1 pcb?
Can't immagine if u have to built an 6 channel unit with all those little pcb's,6x3 (or 4 if i did read well) pcb's,also cost would be much much higher.
