YuSynth Minimoog Filter demo sequence
Page 1 of 1 [9 Posts]
Scot Solida
PostPosted: Mon Dec 14, 2009 7:26 pm    Post subject: YuSynth Minimoog Filter demo sequence Reply with quote  Mark this post and the followings unread
I took a short break from re-wiring my clock divider to build the YuSynth Minimoog filter. I etched the board using Press n Peel and I ordered the Bridechamber component kit just to speed things up. This was sort of an impulse project. I am quite pleased with how it turned out. It worked from the start with no troubleshooting necessary. Once I got it calibrated to my liking (I just matched it by ear to my Minimoog), I installed it into my big Synthesizers.com system and whipped up a simple sequence to show off what it can do. It sounds fantastic! The patch was super-simple. I used three Dotcom oscillators, sequenced with the Q-960. The oscs were sent into a four-channel mixer and then off to the YuSynth Minimoog filter before being spat out the VCA. I used an ADSR to modulate the filter cutoff and the whole thing got a slathering of Echoplex tape delay. I manipulated the filter's parameters while the sequence played.
http://www.olscratchrecordings.com/Sounds/MiniFilter.mp3
Thalassa
PostPosted: Tue Dec 15, 2009 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice demo Scot, one question... from where you get the dotcom panel? did you make it yourself? is it skilscreened? ( at the end were thre questions Wink )
Scot Solida
PostPosted: Tue Dec 15, 2009 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Thalassa. I had a blank DotCom panel that I bought some time ago. I screenprinted it myself using vinyl ink of the sort used with bumper stickers... that stuff is very durable, if a bit noxious! I used to own a screenprint business and still have the inks and equipment left over from that. It'd probably be better to use acrylic inks for this, but I have a lot of these vinyl inks left, so I used that instead.
Thalassa
PostPosted: Tue Dec 15, 2009 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I've used similar techniques with polyester paper and the results are quite good. For me the vinyl/polyester front panels are the best solutions if not silkscreened panels are available.
yusynth
PostPosted: Tue Dec 15, 2009 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Bravo Scott !
Enjoy it !
Yves
Scot Solida
PostPosted: Tue Dec 15, 2009 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
yusynth wrote:
Bravo Scott !
Enjoy it !
Thanks, Yves! I am indeed enjoying it. It's a terrific design and really sounds fantastic. Thanks for making it available!
emdot_ambient
PostPosted: Tue Dec 15, 2009 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
afro Sounds pretty authentic to me...I really need to whip my mini into shape but it's the power supply, I fear, and so it'd have to be off to the synth hospital.
Gettin' my TD (Heldon actually) groove on here: dancing
Great job, Scot & YuSynth!
Scot Solida
PostPosted: Tue Dec 15, 2009 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! The influence Heldon had on me cannot be overstated. Coincidentally, I was listening to Pinhas' East/West and DWW while I built this filter...
Man, get that Mini fixed! There's nothing sadder than a neglected Minimoog. I had mine restored by Wes at www.analogics.org. It's played like new since.
TekniK
PostPosted: Tue Dec 15, 2009 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
it sound nice but not like a minimoog filter at all.
