Fixing the 3.5mm stereo output on a Casio MT-205
Page 1 of 1 [4 Posts]
destroyifyer
PostPosted: Thu Dec 31, 2009 2:47 am    Post subject: Fixing the 3.5mm stereo output on a Casio MT-205 Reply with quote  Mark this post and the followings unread
The stereo output is audible only through the left channel- the right channel can barely be heard, panned heavily and turned up very loud. I predict I will have to replace the stereo out... is there anything I can do to avoid this or should I just go ahead and give it a shot? I tried cleaning the jack with a stripped q-tip and some rubbing alchohol... didn't work... don't have any more ideas, really. Any help or suggestions would be slightly appreciated.
Thanks, from Kyle
Danno Gee Ray
PostPosted: Thu Dec 31, 2009 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Might want to check the signal level coming into jack to see if one of the output channels is failing.
imaguitargod
PostPosted: Thu Dec 31, 2009 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds, to me in my limited experience, that the wire going to the right channel peg on the jack is loose. Open it up and check her out. May just need a dab of solder.
Assistant brewer for Hoppin' Frog Brewery
My Noise Project: I Like Pie (MySpace Page)
destroyifyer
PostPosted: Thu Dec 31, 2009 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, thank you I might give this a whirl. If all else fails I suppose I'll rip out the built-in speakers (they sound horrible anyways) and route those to a new jack, maybe to avoid messing with the circuit board.
Thanks, and an interesting and eventful new decade to you all.
