Mohoyoho
EmeraldAdrift
Tange
Audio files: 6
Joined: Apr 03, 2004 Posts: 19623 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Jan 02, 2010 7:28 am Post subject:
| EmeraldAdrift wrote: | | Can I get that raised? |
Sure thing! Should be fixed now. _________________ Jan |
shanemorris
Audio files: 83
Posted: Sat Jan 02, 2010 9:00 am Post subject:
Re: NYE streaming event Subject description: Tange - NYE2010 |
| Tange wrote: | Aw ra best furry new wan!  |
indeed ......... i think heheh  _________________ ElectroCasa |
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 1517 Location: Berks County, PA
Audio files: 26
Posted: Sat Jan 02, 2010 11:28 am Post subject:
Subject description: Take Cover |
I finally got around to listening to it, not too many clinkers, so I reckon I'd better post it.
Starts off with Scrabble-to-MIDI with tones generated via the javax.sound.midi library. I started finger picking my Godin xtsa midi guitar about 10 minutes into the game after I had enough Scrabble words to generate a usable rhythm section. Thin processing with a few GR-33 guitar synth effects and Ableton Live delays on the guitar in places, used Live as the mixer as well.
No technical glitches, happily, although I find I get more fumble fingered when I have to take my hands off the strings too often. Good excuse!
OOPS, I've hit my upload limit, no can do! Shall I do some house cleaning, or is an upped limit a reasonable request? I have about 15Mbyte of space left, and this file needs 30. Thanks.
EDIT: Jan! Performance file attached.
| Happy New Year! Getting a little grayer each time around. |
2.22 MB |
| Viewed: |
110 Time(s) |
| "Take Cover" by Dale Parson (Acoustic Interloper) NYE 2009-2010. |
 Download |
| Filename: |
DParsonNYE20092010.mp3 |
29.6 MB |
| Downloaded: |
479 Time(s) |
_________________ "Time is a ruler across the knuckles of eternity."
Dale Parson
"Just say no."
Nancy Reagan Last edited by Acoustic Interloper on Sat Jan 02, 2010 12:03 pm; edited 1 time in total |
Audio files: 116
G2 patch files: 317
Posted: Sat Jan 02, 2010 11:41 am Post subject:
| Acoustic Interloper wrote: | | OOPS |
Upped you. _________________ Jan |
Acoustic Interloper
Audio files: 26
Posted: Sat Jan 02, 2010 12:38 pm Post subject:
Thanks again, Jan! By the way, is the chat log from the event posted somewhere? The missed parts are often a fun read. _________________ "Time is a ruler across the knuckles of eternity."
Dale Parson
"Just say no."
Nancy Reagan |
Audio files: 116
G2 patch files: 317
Posted: Sat Jan 02, 2010 1:13 pm Post subject:
| Acoustic Interloper wrote: | | By the way, is the chat log from the event posted somewhere? The missed parts are often a fun read. |
Can do ... ok .. done ... http://bluehell.electro-music.com/nye/ and go to ChatLog there, the Schedule is also still up ... times in the chatlog are GMT+1, eg offset one hour from (later than) the GMT times in the schedule.
| Code: |
[2009-12-31 12:58:20] * shanester Fastens SeatBelt for a Long Ride :-)
[2010-01-01 13:32:26] |<-- shanester has left irc.blitzed.org (Quit: ChatZilla 0.9.86 [Firefox 3.5.6/20091201220228])
And snow! _________________ Jan |
dalekay
Joined: Nov 16, 2003 Posts: 122 Location: Palmdale CA
Posted: Sat Jan 02, 2010 3:57 pm Post subject:
I am dumping the audio and video now.
I got 44.1KHz 16 bit edcast files (direct to radio.electro-music)(see below on what was used and where), I got a 48KHz 24 bit from the DAT (4 tracks, 2 internal mikes at 90 degrees and 2 sm58's 6 foot high at left and right). Two cameras in stereo. I would say plenty of waves there to re-mix and pull something out.
One camera dumped now, it's in mts h.264 at widescreen, the other is waiting as I started the conversion to mp3 on it already too. I did dump the waves now.
The other camera will be in the same format. I think all 4 waves (left and right) will be at 48KHz at 24 bit too.
So the stuff line up :
Dale
Hardware
DSI Poly Evolver, DSI Special Edition Prophet '08, KORG Extreme (88 key version), KORG MS2000, Alesis ION and Roland JP8000. Pedals and such on some. (using some custom patches there here and there on everything)
Les Paul with gr-3 and it's Roland GR-20.
Cymbals (Sabian pros)
Software
FM8, MMV and Line 6 Gearbox/DI
Lorraine
Yamaha S-80, roto toms, floor tom, cow bell and congas.
Doug Moon
Les Paul and Fender amp. simple and sweet
I used a KSM-27 Shure mike to send to radio.electro-music (placed center). A pair of QSC HPR-153i supplied the main sound out. I am sure the BX8a's found a bit of the way into the mix too as I had them on near me too. Lorraine had her own sm58 beta, her congas and roto toms a sm58 too. No shortage of mikes here.
The win2k system feed the edcast to radio.electro-music. The winxp box did the FM8, MMV and Gear Box. Signal flow was pretty much, synths to sub mixer (Rolls RM203)(I re-routed all of them for this event to one of the two I had to make it easier for me to deal with), that and other mikes feed into the 20 channel Behringer Euro-Rack). The out of all of that into the win2k system via a motu 24i. The Personus Firebox did the sound out from the XP box. All rates at max for clean sound.
I am thinking I should be able to pull off a 5.1 mix out of this too. I will repost a link here off one of my web sites as I am sure it's going to be large on file size. I caught some limits on file sizes on the other posts already.
If the other guests had arrived or shown up at least, I could have hit some of the other table top synths here and reaktor. As it was, I was traveling sometimes between the two three tier stands. As some will point out, it was more then enough already Dale ...
I did want another synth (Oasis), guitar, bass and pedal steel in. Oh well ...
dale
update here is the link to get the mp3
http://www.inquisitorbetrayer.com/radio.electro-music/
Lorraine has pneumonia among other things going on too so her voice, which is normaly soft anyway, is a bit more so. _________________ dale
many links, cd baby or origo planet to find what we have for sale, myspace, facebook or reverbnation to name a few to hear what we are up to current ...  Last edited by dalekay on Sun Jan 03, 2010 9:46 am; edited 3 times in total |
Acoustic Interloper
Audio files: 26
Posted: Sat Jan 02, 2010 5:11 pm Post subject:
| Blue Hell wrote: | | Acoustic Interloper wrote: | | By the way, is the chat log from the event posted somewhere? The missed parts are often a fun read. |
Thanks, Jan! I always enjoy reading down through what I missed in the chat. I keep the stream projecting when I go downstairs, but I miss good chunks of the chat. _________________ "Time is a ruler across the knuckles of eternity."
Dale Parson
"Just say no."
Nancy Reagan |
RFBB
mrcold
Audio files: 31
Posted: Sun Jan 03, 2010 2:54 pm Post subject:
here's my show.. mucho thanks to wmonk for recording it!
RocknRollllll!
also, included a picture of my awesome studio
3.43 MB |
| Viewed: |
111 Time(s) |
 Download |
| Filename: |
NYE - MrCold.mp3 |
26.26 MB |
| Downloaded: |
383 Time(s) |
Inventor
Joined: Oct 13, 2007 Posts: 5966 Location: San Antonio, Tx, USA
Audio files: 258
Posted: Sun Jan 03, 2010 3:05 pm Post subject:
Cody, that studio "rocks"!
ocp
Joined: Sep 14, 2004 Posts: 498 Location: Porto, Portugal
Audio files: 9
Posted: Sun Jan 03, 2010 3:30 pm Post subject:
Here are a few pics and set-up list (mp3 will follow):
Paulo: Classic guitar, portuguese guitar (pictured), electric guitar, voice, percussion, keys;
Zé: Keys, electric guitar, percussion;
Jó: MIDI bass, MacBook Pro, Absynth, Ableton Live;
João: electric guitar, harmonica, percussion, MacBook Pro, Ableton Live, keys.
All recorded in Ableton Live and streamed through Nicecast.
Needless to say we had great fun listening, playing and partying!
Thank you all for making this possible
193.12 KB |
| Viewed: |
110 Time(s) |
| New York is just across... |
82.47 KB |
| Viewed: |
118 Time(s) |
| playing the portuguese guitar (mostly used in traditional fado) |
206.21 KB |
| Viewed: |
111 Time(s) |
224.67 KB |
| Viewed: |
115 Time(s) |
190.52 KB |
| Viewed: |
112 Time(s) |
_________________ http://joaoricardo.org | http://pygar.pt.vu | http://myspace.com/boiar | http://doporto.pt.to | http://myspace.com/fanfarraimprovisada Last edited by ocp on Sun Jan 03, 2010 3:56 pm; edited 1 time in total |
nobody
Posted: Sun Jan 03, 2010 3:51 pm Post subject:
Re: Post your NYE streaming event sets here! Subject description: ...or links to it |
| Muied Lumens wrote: | Title says it all, upload or post links to the set that you did on the electro-music NYE streaming event, so that they are all in one place. :
Here is my set, not properly listened to yet and a little longer than 30 minutes.... |
Love it! My favourite part came in around 20 or 25 minutes. I had to turn it down in the middle where it got either noisy or too high-freq-ish, I coudn't tell which. |
Acoustic Interloper
Audio files: 26
Audio files: 22
Posted: Sun Jan 03, 2010 5:54 pm Post subject:
These photos are great !! Thanks.
Bill |
Muied Lumens
Joined: Apr 24, 2009 Posts: 1337 Location: Bristol UK
Audio files: 209
Posted: Sun Jan 03, 2010 8:35 pm Post subject:
| audiodef wrote: | | Muied Lumens wrote: | Title says it all, upload or post links to the set that you did on the electro-music NYE streaming event, so that they are all in one place. :
That would be both.
And thank you very much for liking it! _________________ robsol
Muied Lumens Base Star |
EmeraldAdrift
Posted: Mon Jan 04, 2010 7:32 am Post subject:
Here's an MP3 of my New Year's performance.
Equipment used:
- Cookie-tin synth (given to me a few days prior and making its broadcast debut -- see pics below)
- Native Instruments Reaktor (2 instances open)
- Camel Audio Cameleon 5000 (1 instance open)
- Digital Performer 5 (host app, FX processing, and level mixing)
- Suzuki KM-88 Keyman digital piano + Fatar VFP1 sustain pedal (MIDI controller for softsynths)
For the sequencer section in the last few minutes, I also added:
- Waldorf Edition PPG Wave 2.V (2 instances open)
- Korg Legacy M1 (2 instances open)
| Cookie-tin synth: panel close-up |
175.08 KB |
| Viewed: |
90 Time(s) |
175.38 KB |
| Viewed: |
90 Time(s) |
Emerald Adrift - Electro-Music New Year's 2010 performance - circa 59 min. - © 2010 David Herpich - (Feel free to direct anyone to this link, but please don't re-post or host the MP3 elsewhere without prior permission.) |
 Download |
| Filename: |
Emerald_Adrift__Live-Jan-01-2010_160kbps.mp3 |
66.78 MB |
| Downloaded: |
445 Time(s) |
_________________ Emerald Adrift
http://soundcloud.com/emerald-adrift
Free albums at the Internet Archive |
nobody
Posted: Mon Jan 04, 2010 8:10 am Post subject:
| What's the cookie-tin synth and how does it work? It looks fascinating! |
EmeraldAdrift
Posted: Mon Jan 04, 2010 9:29 am Post subject:
| audiodef wrote: | | What's the cookie-tin synth and how does it work? It looks fascinating! |
It's a DIY unit built into a cookie tin by Damon Mar. Not being a DIY builder myself, I'm pretty ignorant about specific details of the design and fabrication, but I can explain the basic functions of the synth from an end-user's point of view.
There are four square-wave oscillators. Each has a course frequency pot (the top row of pots) and a mix level pot (the lower row). These four oscillators can optionally be sync'ed in pairs (the 2nd and 5th switches along the bottom).
Each of the oscillators can be set (using the other four switches in that bottom row) to respond to frequency modulation from light sensors (the four small circles along the bottom, which may be a little hard to see in the pics).
Each osc also has an indicator light above its control pots. My inference from using the unit is that the lights are triggered at the cycle rate of the oscillators, though I may be wrong on that point.
Then there's a master volume pot towards the bottom, and across the top are the power input, the master power switch, and the signal output jack.
Inside the tin there's a 9v battery jack (how it's currently being powered) and plenty of open space -- which I have to admit I've not yet used to store any actual cookies or post-gig snacks.  _________________ Emerald Adrift
RFBB
Audio files: 116
G2 patch files: 317
Mohoyoho
