G2 editor plugin
Page 1 of 1 [6 Posts]
aMUSEd
PostPosted: Thu Jun 09, 2005 12:29 pm    Post subject: G2 editor plugin Reply with quote  Mark this post and the followings unread
I wish Nord would bring out a version of the editor that functioned as a plugin (VSTi say) in a similar way to the new virus TI so you could integrate it better into sequencers etc.
http://fingermarks.co.uk/music.htm
atari
PostPosted: Thu Feb 05, 2009 6:26 am    Post subject: Re: G2 editor plugin Reply with quote  Mark this post and the followings unread
+1[/u][/quote]
ark
G2 patch files: 31
PostPosted: Thu Feb 05, 2009 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't see why it's necessary. Any time you change configuration with the editor, the sound stops; so I can't imagine wanting to do so quickly as part of a plugin.
If you want to change parameters in a patch, you can change just about anything with MIDI CC assignments, which also don't require a plugin.
If you want to switch from one patch to another, you can do that with a Midi Program Change message.
Finally, you can even replace an entire patch wholesale by dumping the patch into a file and sending the contents of the file later.
So I don't quite understand what a G2-specific VST editor would buy.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Fri Feb 06, 2009 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
if it autosyncs with cubase would be ok. I can't think of any more advantages.
ekeaze
PostPosted: Sun Jan 03, 2010 3:15 am    Post subject: Re: G2 editor plugin Reply with quote  Mark this post and the followings unread
Yes that will be realy great !
but will be too much better if they release standrad VSTi plugin like Waldorf Largo.
I think before years I tried Demo of Modular on PC it was sounds realy great but it was only demo and standalone...
Hope in future
Eigenfrequenz
PostPosted: Thu Jan 07, 2010 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check this Cool
Build your own Plugin:
http://code.google.com/p/ctrlr/
