Reichelt warenkorb wanted
Page 1 of 1 [9 Posts]
Floppy
PostPosted: Fri Jan 08, 2010 4:02 am    Post subject: Reichelt warenkorb wanted Reply with quote  Mark this post and the followings unread
hello Klee builders,
im having problems finding some of the parts for the frontpanel and wiring (appendix c)
does anyone have a Reichelt shopping cart for orientation ?
PostPosted: Tue Jan 12, 2010 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i did not create a basket for the klee, since i built it from stock parts mostly. however, what are you looking for? maybe i could take a look at it this week... i am ordering most of my stock parts from 'tante angelika' anyways.
fonitronik at
Floppy
PostPosted: Tue Jan 12, 2010 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
hello fonik,
who is tante angelika ??
the 2 pdfs attached shows the parts that i still need to order.
for the potis there are 4 and 6 mm i guess 6mm is ok ?
i couldnt find connector housings and crimp terminals at reichelt.
the switches :
SPST ON-OFF
SPDT ON-OFF-ON
SPST ON-OFF
SPDT ON-ON
SPST (ON)-OFF
SP8T Rotary
i translated the names with google but im still not certain wich ones i should get.
Pasted Graphic 1.pdf
 Filename:  Pasted Graphic 1.pdf
 Filesize:  43.83 KB
 Downloaded:  147 Time(s)
Pasted Graphic.pdf
 Filename:  Pasted Graphic.pdf
 Filesize:  53.93 KB
 Downloaded:  141 Time(s)
PostPosted: Tue Jan 12, 2010 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Floppy wrote:
hello fonik,
the switches :
SPST ON-OFF
SPDT ON-OFF-ON
SPST ON-OFF
SPDT ON-ON
SPST (ON)-OFF
SP8T Rotary
okay. i will post the links tomorrow. no big deal.
BTW for ON-OFF you can use ON-ON.
concerning the crimp terminals: reichelt also offers a cheap crimp tool that goes with their terminals/housings...
concerning the potentiometers: don't buy the cheap radioohms, they are crap! i'd preferred alpha (banzai) or the alps.
more tomorrow...
fonitronik at
PostPosted: Wed Jan 13, 2010 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
reichelt elektronik GmbH & Co. KG
Geschäftsführerin: Angelika Reichelt
SPDT ON-ON (can be used as SPST ON-OFF as well): MS 500A
SPDT ON-OFF-ON: MS 500C
SPST (ON)-OFF: MS 500B
SP8T Rotary: DS 1 (count of positions can be adjusted, up to 12 positions)
for the crimp connectors there is a problem. here is the link to the article group: Platinen-Steckverbinder.
there are no connector housings for 6 poles, just 2, 3, 4, 5 and 8, and you can't stack them in rows. so maybe 8 pole could do the job for the 6 poles too if there is enough room on the board? anyways, i did not find the appropriate crimp tool anymore, so you might have to give them a call about that (they are very helpful in my experience).
fonitronik at
Floppy
PostPosted: Mon Feb 01, 2010 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you fonik !
PostPosted: Mon Feb 01, 2010 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
today i searched banzai.com for some parts and found crimp connectors, pre-wired. he stocks 6pin too...
http://www.banzaimusic.com/PCB-Connectors/
fonitronik at
wmonk
Audio files: 12
PostPosted: Mon Feb 01, 2010 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those are nice Matthias!
Bought mine at MusikDing ( http://www.musikding.de/forums.html/cat/c158_PCB-connectors.html )
Weblog!
Kits for synthesiser modules in Europe
Floppy
PostPosted: Sun Mar 14, 2010 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
i got them as well from the nice people at banzai.
saves a lot of work and looks so much better than loose cables.
Niio2
