Floppy
Posted: Fri Jan 08, 2010 4:02 am Post subject:
Reichelt warenkorb wanted |
hello Klee builders,
im having problems finding some of the parts for the frontpanel and wiring (appendix c)
does anyone have a Reichelt shopping cart for orientation ? |
Posted: Tue Jan 12, 2010 8:29 am Post subject:
i did not create a basket for the klee, since i built it from stock parts mostly. however, what are you looking for? maybe i could take a look at it this week... i am ordering most of my stock parts from 'tante angelika' anyways. _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
Floppy
Posted: Tue Jan 12, 2010 11:33 am Post subject:
hello fonik,
who is tante angelika ??
the 2 pdfs attached shows the parts that i still need to order.
for the potis there are 4 and 6 mm i guess 6mm is ok ?
i couldnt find connector housings and crimp terminals at reichelt.
the switches :
SPST ON-OFF
SPDT ON-OFF-ON
SPST ON-OFF
SPDT ON-ON
SPST (ON)-OFF
SP8T Rotary
i translated the names with google but im still not certain wich ones i should get.
| Description: |
 Download |
| Filename: |
Pasted Graphic 1.pdf |
| Filesize: |
43.83 KB |
| Downloaded: |
147 Time(s) |
| Description: |
 Download |
| Filename: |
Pasted Graphic.pdf |
| Filesize: |
53.93 KB |
| Downloaded: |
143 Time(s) |
Posted: Tue Jan 12, 2010 12:12 pm Post subject:
| Floppy wrote: | hello fonik,
the switches :
SPST ON-OFF
SPDT ON-OFF-ON
SPST ON-OFF
SPDT ON-ON
SPST (ON)-OFF
SP8T Rotary
i translated the names with google but im still not certain wich ones i should get. |
okay. i will post the links tomorrow. no big deal.
BTW for ON-OFF you can use ON-ON.
concerning the crimp terminals: reichelt also offers a cheap crimp tool that goes with their terminals/housings...
concerning the potentiometers: don't buy the cheap radioohms, they are crap! i'd preferred alpha (banzai) or the alps.
more tomorrow... _________________
fonitronik at
Posted: Wed Jan 13, 2010 2:05 am Post subject:
| Floppy wrote: | | who is tante angelika ?? |
reichelt elektronik GmbH & Co. KG
Geschäftsführerin: Angelika Reichelt
SPDT ON-ON (can be used as SPST ON-OFF as well): MS 500A
SPDT ON-OFF-ON: MS 500C
SPST (ON)-OFF: MS 500B
SP8T Rotary: DS 1 (count of positions can be adjusted, up to 12 positions)
for the crimp connectors there is a problem. here is the link to the article group: Platinen-Steckverbinder.
there are no connector housings for 6 poles, just 2, 3, 4, 5 and 8, and you can't stack them in rows. so maybe 8 pole could do the job for the 6 poles too if there is enough room on the board? anyways, i did not find the appropriate crimp tool anymore, so you might have to give them a call about that (they are very helpful in my experience). _________________
fonitronik at
Floppy
Posted: Mon Feb 01, 2010 11:42 am Post subject:
| thank you fonik ! |
wmonk
Joined: Sep 15, 2008 Posts: 483 Location: Enschede, the Netherlands
Audio files: 12
Floppy
Posted: Sun Mar 14, 2010 3:56 am Post subject:
i got them as well from the nice people at banzai.
saves a lot of work and looks so much better than loose cables. |
