 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
midi timeout with mac osx 10.6.2 snow leopard
Page 1 of 1 [5 Posts]
nisakku
PostPosted: Fri Feb 05, 2010 4:50 pm    Post subject: midi timeout with mac osx 10.6.2 snow leopard Reply with quote  Mark this post and the followings unread
hi there. i'm trying to run nomad under mac osx 10.6.2 snow leopard to control a micromodular (3.03 os), i have the last version of nomad and the last java update, and everything seems to be ok except for the midi timeout message as following:
"net.sf.nmedit.jsynth.SynthException: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:411)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.setConnected(NordModular.java:881)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm.trySetConnectedState(SynthObjectForm.java:958)
at net.sf.nmedit.jsynth.nomad.forms.SynthObjectForm$1$1.run(SynthObjectForm.java:599)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:633)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: net.sf.nmedit.jnmprotocol2.MidiException: timeout: 10000ms (net.sf.nmedit.jnmprotocol2.SynthSettingsMessage) [error=-1001]
at net.sf.nmedit.jnmprotocol2.NmMessageAcceptor.waitForReply(NmMessageAcceptor.java:111)
at net.sf.nmedit.jsynth.clavia.nordmodular.NordModular.connect(NordModular.java:400)
... 11 more"
i have tried with 3 diferents midi interfaces and the problem is the same. i think the main reason is the fact that i have the micromodular clock to internal instead external, but... how could i set to external if i could not access to the synth in the editor ? it is a fact that clavia editor do not run under snow leopard..... so, i do not know exactly what can i do...
any suggestions ? thanks and greetings from barcelona.
nisakku
PostPosted: Fri Feb 19, 2010 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, so many readers but no solution.... at the end went to a friend's house who have a micromodular too and back to external clock with old clavia editor on a pc. now it is works!
the trouble is there is a lot of patches nomad do not recognize.....maybe is there any solution for that ? tks.....
lilrich999
PostPosted: Wed May 12, 2010 3:37 pm    Post subject: snow leopard Reply with quote  Mark this post and the followings unread
My nord micro modular osx editor works under snow leopard. my nomad doesn't yet. I may try the latest java update. Do you know what version of osx editor you are using?
nisakku
PostPosted: Wed May 12, 2010 4:59 pm    Post subject: midi timeout with mac osx 10.6.2 snow leopard Reply with quote  Mark this post and the followings unread
hi there! thanks for the response.... the trouble was solved with a pc editor of a friend of mine... now nomad is working, but actually not so fine......
whit my old mac (G4, mac osx tiger) the editor i used was the last published by clava in the website.... are you running clavia editor under snow leopard ?? mmmm. interesting... could you send me the editor by mail ??? nisakku@yahoo.es
thank you! greetings from barcelona, F>
lilrich999
PostPosted: Wed May 12, 2010 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I Use the first Intel Imac running snow leopard. A midisport 2x2 for my midi and the saffire pro 10's midi interface runs to my micro modulars "pc" input.
I use the beta mac editor. I have emailed that to you.
It does crash but I seem to able to work around it without to many grips.
I just noticed a discussion here about using the free tool virtualxp to run a virtual xp machine in osx running the pc version. I will try this tonight and get back to you on how hard or easy it is to setup and use.
here is the link to that discussion.
http://electro-music.com/forum/viewtopic.php?highlight=virtual+box&t=38246
greetings from New Zealand.
here is a demo track I wrote using mostly micro modular patches.
http://www.findquarks.bandcamp.com
Niio2
