 Forum index » Online Music
A Synthesizer work played on the filter
Page 1 of 1 [13 Posts]
Audio files: 27
PostPosted: Fri Feb 05, 2010 7:57 pm    Post subject: A Synthesizer work played on the filter
Subject description: Inspired by JovianPyx
Have you followed the thread by JovianPyx? He has developed a synthesizer that uses filters as the sound source --- no VCOs. He posted some tracks that demonstrate this and it has a wonderful, almost organic, sound.
I liked the idea so much that I decided to try it on the Aries synth. Unlike JovianPyx's synth, the Aries is monophonic so I did some looping.
The only sound sources I used was the noise generator and the AR-339 filter. None-the-less, it is tonal music.
JovianPyx's thread is here: http://electro-music.com/forum/topic-38538.html
My track is below:
FilterPlay160.mp3
FilterPlay -- live looping with the Aries Synthesizer noise source and filter.
 Filename:  FilterPlay160.mp3
 Filesize:  7.13 MB
 Downloaded:  620 Time(s)
JovianPyx
Audio files: 138
PostPosted: Fri Feb 05, 2010 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's very nice! I really like that!
FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff
I am formerly known as ScottG here
Time flies like a banana.
If butts had nipples, why have tits?
Audio files: 27
PostPosted: Fri Feb 05, 2010 9:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, thank you, JovianPyx... and thank you for sharing your ideas.
nobody
PostPosted: Sat Feb 06, 2010 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool. I haven't listened yet, but I will today. I'll have to use this idea in a composition I'm currently working on.
Audio files: 116
G2 patch files: 317
PostPosted: Sat Feb 06, 2010 10:08 am    Post subject: Re: A Synthesizer work played on the filter
Making noise bursts with an envelope generator?
Sounds really nice!
nobody
PostPosted: Sat Feb 06, 2010 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Lovely tones. If you use a noise generator, though, can you say you've used only a filter as the source? Wouldn't that be ringing the filter, and then maybe combining and filtering that with other ringing filters?
Could use a bit of companding on the mix. Had to ride the gain a bit. But this is really good! Cool
JovianPyx
Audio files: 138
PostPosted: Sat Feb 06, 2010 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
If he put the noise through a VCA modulated by an EG, that could send a short "wad" of noise to the filter, it should then resonate until it dies out exponentially. The filter Q will determine the sustain time.
In fact, he should be able to excite the filter with just the EG. That is the way I did it in the PolyDrum.
Not exactly sure what Kevin did, but I am interested to read what he has to say.
FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff
nobody
PostPosted: Sat Feb 06, 2010 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
++! Tell us, Kev!
Audio files: 27
PostPosted: Sat Feb 06, 2010 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
To answer your question...
I patched the noise through a VCA and then into the filter. ADSR #1 controls the noise and, indeed, I little burst of noise rings the filter. I varied the ADSR settings to, at times, make the noise audible.
The filter Q can control the decay -- though this particular filter will self-oscillate at the highest Q setting. Thus, the filter output is patched through a separate ADSR/VCA pair.
I twirled knobs in the process of recording this to vary the amount of noise, the length of the initial noise burst, the filter Q, and the final Envelope generator. I controlled the filter frequency from the Aries keyboard.
Thanks for listening! Smile
destroyifyer
PostPosted: Sat Mar 27, 2010 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I as well enjoyed this one, quite a unique sound to this melody.
ultraultralite
PostPosted: Sat Mar 27, 2010 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very well done! i like the sound a lot Rolling Eyes
loving music sometimes is impossible
Audio files: 27
PostPosted: Wed Mar 31, 2010 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you -- glad you enjoyed the music. Smile
Johan Zwart
PostPosted: Tue Apr 20, 2010 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Likable. Smile
www.jzwart.eu www.myspace.com/johanzwart www.myspace.com/themissinghiggs
mps board
