klee running great, but voltages not consistent/no glide
Page 1 of 1 [7 Posts]
goiks
PostPosted: Sat Feb 06, 2010 6:25 pm    Post subject: klee running great, but voltages not consistent/no glide Reply with quote  Mark this post and the followings unread
i have searched though all the other threads here and haven't seen anyone with the same problem. i haven't calibrated the analog board yet, and am stuck in the startup checks in the build doc.
when all my pots are counterclockwise, sequencing with one bit active on the seventh rotary switch setting, i get a few small variations in voltage out of the outputs. i have to turn the pots halfway up before they start to affect voltages. also, glide doesn't work on any of the outputs.
any suggestions on where to start looking would be much appreciated
EdisonRex
Audio files: 168
PostPosted: Sun Feb 07, 2010 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
This could be more than one problem, but here's some things to look at.
U7 on the analog board is the scaler. Check the voltage reference coming from the 10V regulator U5. That should be 10V on pin 3. Each of those trimpots should be at the voltages indicated. Assuming they are, the next place to look would be U6, pin 1. I'm guessing that the voltage reference is not where it should be, offhand, especially if you aren't getting anything from the variable range pot (anything significant anyway). See page 2 of the analog board schematic for this section.
The glide is U8, U9, U10, but remember the glide pot works backwards, meaning when you have it clockwise, there is no glide. I'd say fix the max voltage references first, so that the step mix outputs from U8 and U9 pin 1 are working as expected.
Hope this helps.
Garret: It's so retro.
goiks
PostPosted: Mon Feb 08, 2010 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks edisonrex. i posted prematurely. after checking the voltages like you recommended with everything looking ok, systematic elimination of the easy stuff (weird linear pots hooked up wrong, glide output switched with direct out) got me there, but i appreciate your reply. i have a video uploading to vimeo right now, i'll post it when done - another klee is born!
goiks
PostPosted: Mon Feb 08, 2010 10:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
video here: http://vimeo.com/9313439
(upside down, an issue with iphone videos going uploaded to vimeo, hopefully fixed soon)
Audio files: 51
PostPosted: Tue Feb 09, 2010 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
My glide pots don't go backwards!
How did you manage to do that Edison?
(Ah,.... Glide Slow/Fast, as compared to Glide Short/Long,.... okay. Wink )
We would lose our friends.
So,.........
EdisonRex
Audio files: 168
PostPosted: Tue Feb 09, 2010 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Shocked
Did you write that part of the manual? Laughing It had me confused back when I built and tested too.
Audio files: 51
PostPosted: Tue Feb 09, 2010 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nah,..... wasn't me.
Must have been our fearless leader! Laughing
So,.........
Niio1
