 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
Spectral Vocoder
Page 1 of 2 [30 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Feb 03, 2010 5:10 pm    Post subject: Spectral Vocoder
Subject description: Realtime spectral analysis and additive resynthesis. G2 goes frequency-domain. :)
I've been reading up on DFT and FFT and pondered how much of it could be applied to the G2. It was obvious pretty quickly that a complete frequency-domain representation of a given audio signal and consecutive processing was totally out of the question. However, by severely limiting the amount of frequency bins, simple stuff could be achieved.
My idea was that a monophonic, harmonic and highly periodic signal can be represented by the sum of it's partials and their magnitudes. So, let's say, if I want to graft the spectral information of a source signal onto this monophonic pitch, I only need to extract from the source signal the magnitudes of the sinusoids that directly correspond to the frequencies of these partials. This limits the required frequency bins down to a very small amount -which the G2 can handle. Smile
The result of that idea is this patch, which I call a spectral vocoder. In some ways it is similar to the "classic" vocoder, in other ways not at all. The classic vocoder is based on analysis and resynthesis bandpass filter banks, which arbitrarily filter and process the source and carrier signals without knowing much about them. But in this case I know that the result shall be a pitched monophonic signal, so therefore I know a) exactly which information I want from the source signal (the magnitudes of the sinusoids that correspond to the partials of my monophonic pitched signal), and b)how to best represent this signal: by the sum and magnitudes of it's partials. In other words: by additive synthesis.
Since the standard computer DSP programming approach to measuring the magnitudes of sinusoids in a source signal is impossible to realise on the G2, I opted for an old "analog" technique, which is to heterodyne the source signal with the sine and cosine of the frequency to be measured, and taking the square root of the quadratures of the results. (This actually is nothing else but transforming rectangular coordinates into polar coordinates, with the polar radius being the magnitude of the sinusoid). Quadratures are easy on the G2, and thanks to a building block by Mike Estlick, square roots are possible too.
Patched in the most economical way possible, the process described above uses close to 25% of a DSP. And since I always wanted to build a patch that completely maxes out an expanded G2 Laughing, here finally was the opportunity. Smile But instead of tediously filling up all VA and FX slots with these analysis stages one by one, I used the G2s polyphony feature, each voice conveniently acting as a macro for a single analysis/resynthesis band. These bands are controlled by the FX area via interslot busses. So I get 30 bands in total from an expanded G2, which is as good as it gets. Of course you can use less bands by turning down the voice count (or using an unexpanded G2 Laughing), but the resulting sound will be increasingly dull.
So, at last, a single monophonic voice that maxes out your expanded G2! Laughing
The controls:
INPUT: Select channel for the source audio
INPUT COMP: Compress the source audio to taste
Resp1 and Resp2: Response characteristics of the analysis stages. Controls the sensitivity, speed and immunity to inharmonic frequency content.
FORMANT: Shift formants up and down (simply by offsetting the analysis and resynthesis frequency bands)
HI THRU Freq/Level: Just like classic vocoders, let's you add some high frequency content of the source signal, especially good for sibilants and "air".
KEY PLAY: Attack and Release times of the keyboard envelope.
PRE-ANALYSIS EQ: Tweak the source audio before it goes to the analysis stage.
POST-RESYNTHESIS EQ: Tweak the resynthesized result.
...and there was DSP power left for a delay module (yay! Laughing).
There's a short demo mp3 of this patch too, with me talking into the microphone and playing some keys. G2 goes Antares. Laughing
This is probably as close as you can get the G2 into frequency-domain territory. (But never say never Wink )
tim
SpectraVocoderTK.pch2
Monophonic vocoding by realtime spectral analysis and additive resynthesis. Monophonic monster patch that completely maxes out an expanded G2.
 Filename:  SpectraVocoderTK.pch2
 Filesize:  3.08 KB
 Downloaded:  1899 Time(s)
SpectraVocoder_demo.mp3
Demo of the spectal vocoder patch. G2 goes Antares. :o)
 Filename:  SpectraVocoder_demo.mp3
 Filesize:  657.18 KB
 Downloaded:  1510 Time(s)
jamos
G2 patch files: 39
PostPosted: Wed Feb 03, 2010 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, cool. Very Happy I use on of my G2's primarily for vocal processing, so I'll throw this at my singer and see what he thinks.
Roland Kuit
G2 patch files: 127
PostPosted: Wed Feb 03, 2010 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow....nice 1 tim. thanks for charing
dorremifasol
G2 patch files: 49
PostPosted: Thu Feb 04, 2010 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Impressive!!!
Albert
Wan
G2 patch files: 46
PostPosted: Fri Feb 05, 2010 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Amazing patch again! Shocked
Grtz Wan
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Feb 05, 2010 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad you like it. Smile It was quite an adventure. In the beginning I had a pitch-tracker as well to track the pitch of the incoming signal to extract the partials thereof and port those to the pitch of choice in the additive resynthesis stage. This resulted in the formants being shifted as well, producing the "mickey mouse" effect. However, we all know that the pitch-tracker is so-so, so it caused occasional warbles in the spectral distribution, and anyway -who want's mickey mouse? Wink.
It was so obvious to extract the sinusoid magnitudes from the input signal directly (without pitch-detection) that I didn't think of it doh -hence porting to the desired pitch only those magnitudes that correspond to it's partials, and therefore retaining formants. Easier this way, no pitch-track warbles, and no mickey-mouse.
You can hear the high-frequency partials ring a little bit, which makes it sound more artificial than it should. This is due to the square root function being based on feedback, which is noticeable especially in the higher partials which have high frequency and low amplitude. There's no way around this unfortunately. It would sound better otherwise.
cheers,t
EDIT: If you want some fun, try twiddling the partial quantizer module, which defines the partial spacing. You can tweak it eg. to only odd harmonics, sounds pretty weird. Laughing
fairplay
PostPosted: Fri Feb 05, 2010 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
...that's embarrasing! - how do you make things like this? - all the time?? - again and again???...i feel pretty depressed now {being unable to do things like this myself}...
Wink
...thank you for sharing!...
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Feb 05, 2010 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Too much spare time I guess Rolling Eyes Embarassed ...Laughing Wink
klangumsetzer
PostPosted: Fri Feb 05, 2010 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
tim wrote:
(...) It was so obvious to extract the sinusoid magnitudes from the input signal directly (without pitch-detection) that I didn't think of it doh -hence porting to the desired pitch only those magnitudes that correspond to it's partials, and therefore retaining formants. (...)
This is due to the square root function being based on feedback, which is noticeable especially in the higher partials which have high frequency and low amplitude. (...)
obvious? Shocked uh, hm, what was that middle part again? Laughing
thanks for sharing, tim. keep up the excellent work!
best regards
eike
3phase
G2 patch files: 141
PostPosted: Tue Feb 09, 2010 4:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Audio files: 231
G2 patch files: 319
PostPosted: Tue Feb 09, 2010 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
3phase wrote:
Shocked
Well this sounds great, and i don't understand a bit of it either
Shocked
Inventor
Audio files: 267
PostPosted: Tue Feb 09, 2010 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
The main part that I don't understand is how does the patch determine what the fundamental frequency of the voice is? I don't know the G2, so looking at the patch won't help me there. Anyone understand that part of it?
Les
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Feb 10, 2010 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
3phase wrote:
Shocked
Shocked
that's encouraging Shocked anyway I will soon post a song featuring it Wink
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Feb 10, 2010 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, all these "shocked" emoticons... what did I do. Embarassed Laughing
It doesn't. Smile That's the whole point. Smile It extracts from the source signal only the sinusoid magnitudes that correspond to the harmonic series of the monophonic destination pitch. This is then synthesized from these magnitude measurements via additive synthesis.
It's a bit expensive for only one resulting voice (to put it mildly Laughing) from an expanded G2, so almost posted it in the "experimental" subsection. Laughing It's just that when I read up on DFT, I thought "Come on, the G2 must be able to do this, if only a very little bit." It worked out. Smile Glad you like it.
Audio files: 231
G2 patch files: 319
PostPosted: Wed Feb 10, 2010 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked you brought some life here, thats a good thing Exclamation
Cool
drapdap
PostPosted: Sat Feb 13, 2010 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
this one is so much fun, thanks Tim!
i made my engine boot with this one for now... Very Happy
it was just what the doctor ordered, as i added an xlr input recently with a knob, so i can vocode with just a mic and the engine. and a keyboard, erh, you lucky G2 key owners.
thanks again, Tim...
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Feb 14, 2010 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
arrow http://www.seraph.it/dep/det/TheSingingAlchemist.mp3
read blog for more informations Very Happy
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Feb 15, 2010 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Carlo. Seeing/hearing ones patches used for artistic expression is the ultimate compliment.
t
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Feb 16, 2010 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
t
Tim,
I gave credit to you, on my blog entry, for the Spectral Vocoder. It's easy to use a patch like yours "for artistic expression" when they are so beautifully built Exclamation
Thanks to you Very Happy
Inventor
Audio files: 267
PostPosted: Wed Feb 17, 2010 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I played Carlo's song on my radio show and mentioned the g2 patch of tim's after the song. You guys are collaborating so well it makes for great radio!
Les
iPassenger
G2 patch files: 78
PostPosted: Wed Feb 17, 2010 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
This is great. Smile Love the oboe-ish sounds and the delicate percussion is sublime. I presume you have some kind of custom tuning set-up.
iP (Ross)
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Feb 17, 2010 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks and yes, you are right Exclamation check out my blog for more informations Wink
G2egory
PostPosted: Wed Feb 17, 2010 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Spectral Vocoder is dynamite. Thanks for sharing the patch.
peterkadar
PostPosted: Thu Feb 18, 2010 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, this is incredible! Thanks so much for all your hard work, and for sharing it with the rest of us.
Your Kung Fu is strong!!
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Feb 28, 2010 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
one more example of microtonal spectral vocoding using Tim's patch Very Happy
