 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
midi controller problem
Page 1 of 1 [2 Posts]
microbat
PostPosted: Mon Feb 22, 2010 5:29 pm    Post subject: midi controller problem
Subject description: korg microkontrol won't start 'TestV003' message
I bought a Korg MicroKontroller a couple of years ago but couldn’t get it to work. The problem was user based. I didn’t understand enough to get me started. Now I do but my midi controller won’t start properly stopping me from learning how to create electronic music which is a pain. It only shows ‘TestV003’ unlit in the dial display, ‘01.03’ in controller 1 display, ‘00 7D F7’ in controller 7 display and ‘13 80 F7’ in controller 8 display. This happens for both the usb and ordinary power supply start up. It will start if I hold down either the message or exit button as I turn the device on. I think it may have suffered from lack of use, dust getting in the connections or even corrosion but I don’t know. Any techies out there who could explain this problem and offer a solution? I'd really appreciate it.
rAC
PostPosted: Fri Dec 31, 2010 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Noting how old this is you may have solved it already but as a suggestion look at the Micro Kontrollers' handbook and see if there is a battery in it - it may need replacement.
