KLEE PCB dimensions.
Page 1 of 1 [4 Posts]
theglyph
PostPosted: Sat Jan 09, 2010 3:49 pm    Post subject: KLEE PCB dimensions. Reply with quote  Mark this post and the followings unread
I'm planning on mounting my KLEE PCBs parrallel to the front panel but I need the dimension between the centers of the corner holes to specify the points on the panel in FPD. Are these measurements available? Thanks in advance for any help!
zthee
PostPosted: Mon Mar 08, 2010 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to know this as well!
theglyph
PostPosted: Mon Mar 08, 2010 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I measured it by hand and used the dimensions to line up the holes in my FPD. It worked out great.
You can see it here:
I wrote them down somewhere so I'll post back when I find them.
Audio files: 22
PostPosted: Thu Apr 01, 2010 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Just in case anyone else would like to know, I have attached a PDF drawing of the Klee analog and digital board mounting hole dimensions. Ignore the smaller board at the bottom. This is an expansion I did fro a customer.
Larger board is the didigtal card (top) and the smaller (middle) is the analog card.
Bill
KLEE BOARD MOUNTING.pdf
 Filename:  KLEE BOARD MOUNTING.pdf
 Filesize:  59.72 KB
 Downloaded:  221 Time(s)
