VCA troubles
Page 1 of 1 [7 Posts]
Aottens
PostPosted: Sun Mar 14, 2010 4:17 am    Post subject: VCA troubles
Subject description: Having troubles getting my VCA to work
Hello everyone, this is my first post here on the forum. I've looked around here for several months, and now I decided to create an account Smile.
At first I want to thank Yves for al the work he put in his modular system, and sharing it with the world. I've got 1 YuSynth VCO working and it sounds wonderfull.
I've now built a VCA but something is not going the way I want it during calibrating. I'm following the steps on the website, but it wont work for me. I'm starting with P2 and P3 input lvl and cv fully open, P1 is closed. Then I make the sinewave simmetrical with the trimmer. So far so good. But than I have to close P3, cv, and it should mute the signal. But nothing is happening here. The sinus is not getting muted or anything. Maybe I am interpreting the calibration process wrong.
Oh, and if I connect my sinewave generator to my 2nd input the green led stays lit, guess this is not a good thing. Maybe its in the wiring but I checked everything, and i'm pretty sure the wiring is done o.k.
All help is apreciated.
yusynth
PostPosted: Mon Mar 15, 2010 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's due to a typo , on step 7 one must read P2 not P3.
Sorry about that. I will correct that ASP
Yves
Yves
Aottens
PostPosted: Tue Mar 16, 2010 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Yves,
This indeed solves the problem for the left side of my ins and outs. But when I connect my sinewave generator to my 2nd input, the led stays on. This isn't right I guess. Must be something in the wiring than.
yusynth
PostPosted: Tue Mar 16, 2010 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Aottens wrote:
thanks Yves,
No it is normal, input 2 is not attenuated (no pot) and the values of the LED circuit are set such that the LED starts to lit for a 8Vpp signal.
Yves
Aottens
PostPosted: Tue Mar 16, 2010 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Got a few more questions left. P1 P2 and P3 are not the pots on the silk screen, like from top to bottom? Couldn't find it in the schematics.
What type of Gate signal are your modules using? My doepfer MCV4's factory preset is +5V is this ok? Or should it be higher.
Audio files: 42
PostPosted: Tue Mar 16, 2010 4:26 am    Post subject: Re: VCA troubles
Yes, indeed. From Yves' instructions one could build an entire synthesizer. I've already built a couple of his modules and there are many more on my to-do list.
Aottens, welcome to electro-music.com. welcome
yusynth
PostPosted: Tue Mar 16, 2010 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
P1, P2 and P3 are panel potentiometers, they are not trimmers (which are on the PCB). P1,P2 and P3 are shown on the left part of the schematic and are located just after the input and CV jacks. They are also shown on the wiring diagram and labelled after their respective functions.
A 5V GATE signal is OK for triggering yusynth modules
Yves
